RAZER BLADE 15 2021 MODEL, No power, shorted rails.
  • chickenhawk88
    • May 2024
    • 86
    • US
    The laptop I am working on is RAZER BLADE 15 , RZ09-0369, the motherboard is DA560 VER 4.0. The original fault was it powered up with keyboard rgb on and no video on screen/hdmi. I found corrosion on memory module that leaked onto the memory socket. I cleaned the memory socket and was able to boot normal with other memory socket with good memory. I really should have stopped at this point as everything was working except for the one bad memory slot.
    I wanted to find out what was wrong with the other memory slot. I replaced a 330uf cap, a buck converter on back of board and when i put everything back together to test I plugged in the power adapter and then a loud pop and smoke. There was damage ZSAO 128 A9OR CHIP AND 22976 TI 038 A53L CHIP that I replaced with no help. Then I noticed L9 diode bad but have not replaced cause rails are still shorted to ground ( i did diode mode check - red probe on ground and black probe on cap + )
    I took diode measurements and resistance measurement to ground and wrote the values on the attached pictures. The vcore lines are showing short to ground if im reading it right. Is this mean cpu/ gpu / pch dead ? how do I double check ? should i left up the side of inductor facing towards cap to see if one driver chip went bad ? I have worked on other electronics like nintendo switch but have not done much motherboard repair. Looking for some guidance/help here. Thanks in advance.
  • reformatt
    • Feb 2020
    • 1415
    The caps above the DRMOS for the CPU are shorted to ground? That will be your main +19V power rail so you need to locate the source of that short.
    The coil next to the PCH is also short to ground? That's likely your +1.05V rail so your PCH is probably damaged. I suspect you have had +19V go directly into one of the sub-rails from your description.
    • chickenhawk88
      • May 2024
      • 86
      • US
      I found a bad dual mosfet by 19v input for 19v rail short. No longer pulling the bench power supply down. The 19v rail is now reading .032v for diode reading. I tried looking around for what diode reading i should be reading on these rails. I really hope the pch/cpu/gpu is ok
      The 3.3v rail is reading .004v on diode reading.
      I put the bench power on 3.3v rail with 3.1v with 1 amp limit and draws .700amp. There are some small smd that im still figuring what it is and super io chip is getting pretty warm.
      • reformatt
        • Feb 2020
        • 1415
        3V @ 700ma is about 2W. That should be hot enough to locate the source of that with just IPA. Given that your coil next to the PCH is short as well, I'd be checking that first with voltage injection and thermal camera or IPA. The EC is usually fed off the LDO voltage from the 3.3V controller chip - if that IC is destroyed, it generally takes down the EC and PCH simultaneously.
        • chickenhawk88
          • May 2024
          • 86
          • US
          I pulled the super i/o off , 2 chip with marking "VE" , a chip with marking "FA7808 2039CC" and chip with marking "bPCXN" . The 3.3v rail is now at .062v diode reading and the 5v rail is at .161v diode reading.
          The PCH never got warm at any point, just the ones I pulled off. The super i/o chip was the last one i pulled off. But I think there are still small part that is shorted though as I check around the area where vin of chip is showing short.
          • BalkanBoy
            Dead Razer Blade 14 2022, shorted CPU?
            by BalkanBoy
            today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
            Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
            I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
            Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
            I removed coil and injected 0.7V, it draw around...
            09-27-2024, 12:44 PM
          • chickenhawk88
            Troubleshooting Razer Blade 15 DA560
            by chickenhawk88
            I started troubleshooting this Razer Blade 15 laptop DA560 motgerboard a while back, due to some shorted 19v, 5v, 1v power rails. I fixed some of components and think 19v rail is good, 5v rail is good, 3v is better but not all way i think, and 1v is still bad. At this point the diode reading on these rails are 19v - 0.032v , 5v - 0.167v, 3 - 0.63v and 1v - 0.005v .
            When the rails when down, I went down different rabbit holes and seeing chips getting pretty warm on thermal but not blazing hot. Yet there were not any caps or any small components getting blazing hot. Example is EC chip,...
            06-06-2024, 11:35 AM
          • theplop
            Razer blade 2022, 14" PI480 wont boot to OS, freezes
            by theplop
            Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
            I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
            I've run memtest quite a few times, and more often then not...
            03-20-2025, 06:42 PM
          • mkdj
            Lenovo Thinkpad L480 : 3VALW rail shorted to ground, but I can't find the shorted component
            by mkdj
            Dear all,
            Laptop is Lenovo Thinkpad L480 (boardview can be found in this badcaps topic). When pressing the power button the LED power light turns on, but nothing else happens.
            I removed the motherboard, checked for shorts on the main inductors. I found that there is a short to ground on the +3VALW_P rail (@PL201). I soldered a wire on the PL201 inductor, and I injected up to 1.3V with my power supply. Current drawn is approximately 3.2A.
            I used a small thermal camera to locate the shorted component. But nothing on the board heats significantly, except the...
            08-11-2025, 04:55 AM
          • bumper1
            Looking for schematic or bv for Razer Blade 15 RZ09-0328 MOBO: DA550-MB
            by bumper1
            MOBO: DA550-MB MP V4.0 20200227
            07-10-2025, 03:40 AM
