the crazy solution for Quanta R62 enjoy!!!
  • kiraro
    • Jan 2016
    • 177
    • North NY
    Hi my friends, today I want to share my crazy solution for fun, because I can't find the circuit (I know I can buy it) but some challenge sometimes not bad,
    It's an HP 15 model “Quanta R62” and the 5V-always is missing, “NB669” It is faulty (and I do not have it in others mobo).
    My idea it is using the dual step-down controller from other mobo to fix this issue, and then I choose to use the dual step down controller for N5010 (RT8205BGQW).
    Why N5010? Because all necessary components are together in the same location (top side and bottom side: circuit + transistors + coils + caps).
    Soldering necessary signal “VIN, enable signal “and soldering the 5V LDO and the 5V always to the coil on the HP. Finally removing nb669.
    The result of my final work in the pictures.
    Sometimes fun is good lol.
    Hope that help someone or inspire others.
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: the crazy solution for Quanta R62 enjoy!!!
    Good share, thak you.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3597
      • slovakia
      im so sick of this shit
      hope nobody will be inspired with this, untill u have BURNED traces and u cannot repair that circuit
      • kiraro
        • Jan 2016
        • 177
        • North NY
        Man it is for fun not a customer computer, it is my old PC,not a professional solution,like i say before it's for fun . thanks
        • diif
          • Feb 2014
          • 6978
          • England
          Good work, I like this sort of stuff, inventive. We know it's not for a customer.
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            Well done .. And thanks for sharing
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Though a real crazy solution and hardly practical for repairs-but i salute your curiousity. Good job and well done as well.
              • kiraro
                • Jan 2016
                • 177
                • North NY
                Thank you my friends .
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  i also hope to get to that level of knowledge to do stuff like this
                  good job
                  Im Back... sort of...
                  • kiraro
                    • Jan 2016
                    • 177
                    • North NY
                    good job
                    Thank you
                    • lpraderi
                      Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
                      by lpraderi
                      Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
                      In some cases to use LVDS screen PCB use converter IC RTD2132/6
                      Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
                      at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
                      Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
                      11-25-2023, 09:31 AM
                    • Francisco.s
                      Quanta N76 power-on issue.
                      by Francisco.s
                      Hello, I'm trying to repair an HP 27 Quanta N76 (DA0N76MB6E0 Rev E).
                      I only get 3.3V, 5V, and 1.05V; no other voltages.
                      I tried the BIOS and changed the KBC. The KBC self-programmed upon power-up after changing it.
                      The VR-On is missing for NCP81220, but 1.2V is also missing for DDR4, so 1P2V_PWRGD is low. SUSON or DDR_VTT_EN are not present on the DDR4 voltage regulator (RT8231BGQW). It seems the KBC isn't triggering these signals.
                      I'm using the Quanta N91 schematic, but there are too many changes that make it nearly impossible to measure signal...
                      07-14-2025, 02:20 PM
                    • tommy97
                      MacBook A1932 & A2337 MDM - Permanent solution?
                      by tommy97
                      we're getting quite a lot wiped A1932 & A2337 from scrap with MDM (Remote management), we'd like to find permanent solution to remove it without CPU swap as it gets not economical, I found iremove.tools website which offer permanent solution, however if they got shut-down i believe laptops would also get locked? Does anyone have any knowledge about this service & about any other possible method?
                      06-18-2025, 02:43 AM
                    • bohaboha
                      DO THERE IS A SOLUTION PREVENT MELTING DIFFUSER
                      by bohaboha
                      I want to find a solution, perhaps an ultimate, solution to this dilemma with your expertise. As it stands, the diffuser is too close, if not directly on the joint, there must be a way to separate without affecting image quality, I'm thinking with small glass strips or maybe pieces that make it a little distance, melan, them, or what do you suggest?
                      03-06-2024, 12:59 PM
                    • pleomax1110
                      Quanta DA0R05MB8D2 Rev. D (Quanta R05 / Dell 14z-N411z) schematics needed
                      by pleomax1110
                      Hello, everyone!
                      I need schematics of this board:
                      Model: Dell Inspiron 14z-N411z
                      Board No: DA0R05MB8D2
                      REV: D
                      Quanta project: R05
                      I have already seen the file ''quanta R02_UMA.pdf'' in this thread:
                      https://www.badcaps.net/forum/showth...dell+14z-n411z
                      but it is differ from R05_UMA and it can't help me in my case.
                      The main problem of the laptop is as follows:
                      LED backlight is absent in the screen and appropriate 36's contact of the LVDS 40pin 1ch connector is shorted...
                      10-21-2022, 01:56 PM
