Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
  • lpraderi
    • Dec 2017
    • 30
    • Uruguay
    Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
    In some cases to use LVDS screen PCB use converter IC RTD2132/6
    Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
    at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
    Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
    Attached both schematics
    [MOD EDIT]
    Link to Quanta U99 Schematic - https://www.badcaps.net/forum/troubl...-u99-schematic
    Link to Quanta U92 Schematic - https://www.badcaps.net/forum/troubl...atic-needed​
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • ferah831208
    HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
    by ferah831208
    I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive)....
    12-07-2024, 04:02 PM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
