MacBook A1932 & A2337 MDM - Permanent solution?
  • tommy97
    • Mar 2023
    • 167
    we're getting quite a lot wiped A1932 & A2337 from scrap with MDM (Remote management), we'd like to find permanent solution to remove it without CPU swap as it gets not economical, I found iremove.tools website which offer permanent solution, however if they got shut-down i believe laptops would also get locked? Does anyone have any knowledge about this service & about any other possible method?
  • ugamazing
    • Jun 2013
    • 171
    • usa
    I've heard from a few people that there is one single solution to MDM/DEP enrollment locks, but it's not an easy fix: You can ENROLL the affected device(s) into your OWN DEP/MDM server/account, and it will apparently remove the pre-existing DEP/MDM. You will have to get an enrollment account to do this, however.
    Otherwise there is no fix. DEP/MDM locks based on serial which are written in the CPU/WiFi, which are not economical to replace (at that point just swap the board out).
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue โ€“ Only Works in One Orientation (CC Line Problem?)
      by rounin
      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck โ€” hoping someone here can shed some light.
      ๐Ÿ›  Original Issue
      The machine initially wouldn't negotiate 20V over USB-C โ€” stuck at 5V.
      โš ๏ธ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • bouch
      unlock macbook air A1932 2019
      by bouch
      hi
      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
      I need help or information?
      Does anyone have the minat2 activator 1.4 software?
      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
      Thank yo...
      03-12-2025, 10:14 AM
    • mkdj
      MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
      by mkdj
      About me, my goal and the equipment I (don't) have:
      I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
      About my issue and my goal:
      A friend of mine has a MacBook Air M1 A2337 that does not...
      04-03-2025, 08:28 AM
    • nikolayu
      MacBook Air A1932 internet recovery loop
      by nikolayu
      I have A1932 that is going to internet recovery every time.
      i tried nvram and smc reset but it looks that MacBook is not reacting to that.
      i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
      keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
      also wonโ€™t open option to boot from usb device.
      and I noticed that is not possible to turn off the MacBook. Itโ€™s always turning on by itself.
      07-22-2025, 02:55 AM
    • Adogabriel100
      where to get trusted CD3217. Problem with A2337 Macbook Air
      by Adogabriel100
      Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
      The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
      09-06-2024, 12:06 PM
