DO THERE IS A SOLUTION PREVENT MELTING DIFFUSER
  • bohaboha
    • Nov 2012
    • 1108
    • sweden
    I want to find a solution, perhaps an ultimate, solution to this dilemma with your expertise. As it stands, the diffuser is too close, if not directly on the joint, there must be a way to separate without affecting image quality, I'm thinking with small glass strips or maybe pieces that make it a little distance, melan, them, or what do you suggest?
  • Diah
    • Feb 2013
    • 6650
    there are one solution only.. stop buying Samsung
    • bohaboha
      • Nov 2012
      • 1108
      • sweden
      THANKS diah but is it a specific SAMSUNG problem? because I see it on many other brands like Sony Philips and many other not well known brands like Voxicon etc ect... So maybe it's time to think about coming up with some kind of preventative solution
      • nomoresonys
        • 12370
        • U.S.
        I don't buy their junk but from what I understand, after replacement backlights or fixing/replacing diffuser and setting the backlights to a reasonable level, the diffuser don't burn up again.
        • lotas
          • Jan 2016
          • 5199
          • Russia
          You just need to reduce the backlight current in the power supply, in the backlight driver, increase the resistance of the resistors in the current sensor, reduce the current supply to the LEDs (they heat up less, last longer).
          • Diah
            • Feb 2013
            • 6650
            well as much i know in practice.. only smasung edge BL milt the diffuser
            and any thinmgd u put to push the diffuser to top.. it will left shadow light on screen edge
            • bohaboha
              • Nov 2012
              • 1108
              • sweden
              I think maybe you can do it for your own TV, not for something that you are going to do, congratulations for repairs, I'm thinking of something more simple
              • bohaboha
                • Nov 2012
                • 1108
                • sweden
                That's exactly what I want to avoid "shadow light on screen" therefore I thought of small glas pieces that you can put on the joint, it might raise some mm. Haven't tried yet but will try with a Philips that I have lying around here
                • nomoresonys
                  • 12370
                  • U.S.
                  Gave you the simple solution in post #4, tv menu backlight setting is it 100 put it less than 50, 20 put it less than 10, never have it on vivid or whartever they're calling 100 percent, if left on 100 or whatever the max is will burn shit up every time.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    This is a good suggestion a lot of people have started doing this now
                    • lotas
                      • Jan 2016
                      • 5199
                      • Russia
                      Yes, it’s just that all TV companies turn up the maximum current that powers the LEDs so that they burn out after their warranty expires (the warranty is over - the backlight burns out).
                      • nomoresonys
                        • 12370
                        • U.S.
                        Current mod with resistor is nothing new, been done for years, even here, youtube is full of it, but must be done correctly.
                        • Diah
                          • Feb 2013
                          • 6650
                          just keep in mind.. any pieces of glass or other transparent material if they didn't designed with light filter.. you will have rainbow effect more worse than shadow effect
                          about increase current sensor,. it work for HD TVs, but within 4K 8K TVs specially with HDR / HGR (10) & HDR (10)+ you will lost the color calibration value. and need to calibrate it again again which need tools. no one of us own it... just because its belong not for repair but for lab only.
                          • EazyBone
                            • Jun 2023
                            • 1402
                            • United states
                            • Anything I can do with my hands
                            I don't see the point in this. Take apart an entire TV to put a piece of glass to stop the diffuser from melting even though the LEDs are going to go out anyways because of being overdriven? Just so you can then take it apart and repair it so the diffuser is still good?
                            • bohaboha
                              • Nov 2012
                              • 1108
                              • sweden
                              Hello all .many nice advice, lower the baklight level. Or to reduce the backlight current in the power supply sure if it was my own TV and you should do from the start .but here are 8 tv s with different brands that have the same problem and the customers want me to fix them. Therefore, I turn to your experience and try to figure out something from your proposal.
                              Let's try again guys.​
                              • nomoresonys
                                • 12370
                                • U.S.
                                You have the answer, you are NOT going to reinvent the wheel, if the diffuser is melted it's junk and needs replaced, this video shows the upgraded diffuser. Do a search and see where you can get them, the end: https://www.youtube.com/watch?v=sawYS2pWS5k
                                • bohaboha
                                  • Nov 2012
                                  • 1108
                                  • sweden
                                  thank you all
                                  • V3dran
                                    Diffuser/LPG for UE50NU7022KXXH
                                    by V3dran
                                    I'm trying to repair a UE50NU7022KXXH with a cracked diffuser/lpg and now also with burned leds
                                    There are 4/5 white spots on the bottom that are not visible since the left side is dark now so I want to change the diffuser/lpg
                                    Looking the samsung spare parts, I see that there is a DIFFUSER PLATE and a LPG so I'm wondering what is really broken?
                                    https://www.samsungparts.eu/samsung-...n61-15659a.htm DIFFUSER PLATE 1125x625x2,5mm
                                    https://www.samsungparts.eu/samsung-...n61-15661a.htm LPG 1101x619x2,7mm...
                                    06-26-2025, 01:54 AM
                                  • sdancer75
                                    Replace an LG 49UH850V cracked diffuser
                                    by sdancer75
                                    This specific model, LG 49UH850V, is 3D. The problem here is that the diffuser has been cracked at the bottom, where the LED strip is installed, due to the heat from the LEDs. This is a common problem for many LGs and Samsung TVs.
                                    The questions here are
                                    1) Can I replace the diffuser from a non-3D LG TV with the same size (exact fit)?
                                    2) If I replace the diffuser with the original part, do I have to replace the LED strips also? They work as expected, but some technicians recommend replacing them together.
                                    Regards,...
                                    02-05-2026, 01:08 AM
                                  • linuxrunner
                                    generic diffuser?
                                    by linuxrunner
                                    i have a 65" samsung UN65TU700DFXZA. my kid sprayed cooking oil from a spray/mist bottle onto the screen (2yr old thinking she was cleaning). oil ran down and seeped under the bezel on the bottom of the screen. It appears to have soaked/wicked into the diffuser i have a light colored splotch along the bottom of the screen that grew upwards over a day or two.
                                    i have not disassembled yet but judging by the way it wicked up it looks like its been absorbed into the diffuser so i don't have a lot of hope of cleaning it.
                                    i checked Samsung parts site but they don't...
                                    08-26-2022, 10:52 AM
                                  • Storyteller12
                                    Cutting new light diffuser question
                                    by Storyteller12
                                    I have a Samsung 40” NU series tv with the melted cracked diffuser I’m fixing. I replaced the backlights and I’m planning on cutting a new diffuser out of a 55” diffuser that just melted but didn’t crack.
                                    Question is do I have to keep the top edge factory for the diffusing to work properly or does it matter?
                                    only get one shot at cutting it so wanted to make sure....
                                    03-30-2024, 07:54 AM
                                  • tommy97
                                    MacBook A1932 & A2337 MDM - Permanent solution?
                                    by tommy97
                                    we're getting quite a lot wiped A1932 & A2337 from scrap with MDM (Remote management), we'd like to find permanent solution to remove it without CPU swap as it gets not economical, I found iremove.tools website which offer permanent solution, however if they got shut-down i believe laptops would also get locked? Does anyone have any knowledge about this service & about any other possible method?
                                    06-18-2025, 02:43 AM
