Missing trace pad help
    • 30911
    Re: Missing trace pad help
    the pins are plated with nickle or silver or even gold, sanding removes the plating.
    • ivtec
      • Dec 2008
      • 1967
      thanks stj.
      • ivtec
        • Dec 2008
        • 1967
        Hi guys; hope you all had an Happy New Year;
        Update on the Kindle Missing port, i connected it per instruction given by you guys here only soldered the side 2 pins for the charger,but it only turns on with the charger plugged in,it wont turn on or off, if i plug in the charger it comes on if i disconnect charge it will stay on for awhile,then turns itself off,but if i don't connect it to the charger it wont turn on,also there is a orange led on when is charging,i think it should be a green led,
        is there anything that i did wrong?
        Also can i use Gorilla glue to hold the USB port on the sides of the port to the board to better hold it or is it conductive?
        • ivtec
          • Dec 2008
          • 1967
          Hi is there anybody to advice ?thanks
          • diif
            • Feb 2014
            • 6978
            • England
            Have you got a photo now its soldered in ?
              • 30911
              sounds like the battery is bad or not charging to me.
              i'm sure the led should be orange when charging, and turn green when charged.
              • Sparkey55
                • Jan 2010
                • 1523
                If you use Gorilla Glue test it first on similiar material. It could dissolve some plastics.
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  there are 2 ground pins, the other side is the 5v.
                  the remaining 2 are usb data
                  they link to the other side of the board, so you could fit a fine wire through the hole to solder to the pin.
                  So going back to Stj comment it would seem that one of the 2 ground pads are missing. This I guess is where the trace went to the black chip/cap? Those 2 gnd. pins need to be connected and the black Chip/ cap where the missing trace went to also needs to be connected to the gnd? Is this your understanding STJ or am I missing something?
                  • ivtec
                    • Dec 2008
                    • 1967
                    Thanks i will leave it charging all night and check it in the morning,but i'm preety sure that the green light never comes back and can't turn it off cause the power button is not active exept when charging or not.
                    • chth96
                      Is it possible bridging tiny broken trace
                      by chth96
                      When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                      cutting tiny trace.
                      This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                      Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                      But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                      12-03-2022, 11:32 PM
                    • ugamazing
                      820-02020 PPBUS_AON missing
                      by ugamazing
                      Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                      Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                      02-05-2025, 04:21 PM
                    • jpreza
                      Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                      by jpreza
                      I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                      Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                      It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                      Looking at the card, it appears to be missing the following:
                      1x 1.0uH inductor - orange square
                      2x...
                      11-01-2024, 10:54 PM
                    • gurj1979
                      Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                      by gurj1979
                      Hey guys.
                      Need help with this one.
                      Fan not spinning due to missing PWN Fan signal.
                      Also 5 seconds from powering up it freezes, unless in BIOS.
                      But as soon as Windows starts to load, it will freeze.
                      CPU is COLD / Room temp when it freezes.
                      I've replaced the CPU, same problem.
                      Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                      Replaced fan - same problem.
                      Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                      Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                      08-19-2024, 05:22 PM
                    • salopian
                      Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                      by salopian
                      Hello. I would need some advice please.
                      My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                      He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                      I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                      I have already replaced the logic board with another...
                      02-27-2021, 07:30 AM
