Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
  • salopian
    • Feb 2021
    • 6
    Hello. I would need some advice please.
    My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
    He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
    I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
    I have already replaced the logic board with another one, but I am now really interested and curious to learn as to WHY this MBP failed (temp difference resulting in condensation? something else?).
    So, my measurements are like this:
    PPBUS_G3H 12.55V
    PP3V42_G3 3.39V
    PPVRTC_G3H 3.34V
    PP5V_S5 5.02V
    PP5V_S4 0 V (missing)
    PP5V_S0 0.37V
    PP5V_S3 0.37V
    PP3V3_S5 3.34V
    PP3V3_S4 0V
    PP3V3_S3 1.78V
    PP3V3_S0 1.78V
    S4_PWR_EN 0V
    I then checked the enable signals @ U7501
    SMC_PM_G2_EN 3.39V
    S5_PWR_EN 3.39V
    P5VS4RS3_EN 0V (missing)
    …and then concluded that the PM_SLP_S4_L is missing
    PM_SLP_S4_L 0V (missing)
    Then I checked the inputs for the system power management:
    PM_PCH_PWROK 0V (missing)
    SMC_ADAPTER_EN 3.36V
    PM_RSMRST_L 3.3V
    PP3V3_SUS 3.34V
    All CPUs 11 prerequisites for PM_SLP_S4_L are OK.
    I then checked the PCH PWROK Generation @ U1950:
    ALL_SYS_PWRGD 0V (missing)
    CPUVR_PGOOD_R 1.78V
    SYS_PWROK_R 0V (missing)
    PM_S0_PGOOD 0V (missing)
    SMC_DELAYED_PWRGD 0V (missing)
    PP3V42_G3H 3.39V
    The only thing that I didn't measure (as I don't have a scope) is SYSCLK_CLK32K_RTCX1 i.e. clock frequency (the voltage is 0.43V on U1900, if that means anything).
    And this is where I got stuck….where should I go next with troubleshooting?
    Did I miss something along the way?
    Sorry, I am a complete newbie who's just trying to learn out of curiosity as I find this very interesting…
    Any advice would be greatly appreciated.
    Many thanks
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
    check resistance in omh on cpu coil
    • piernov
      • Jan 2016
      • 4439
      • France
      Originally posted by salopian
      PP3V3_S3 1.78V
      PP3V3_S0 1.78V
      CPUVR_PGOOD_R 1.78V
      That doesn't sound right. I don't see how there can be leakage on both PP3V3_S3 and PP3V3_S0 here.
      Anyway when SLP_S5#/SLP_S4# are missing, first thing is to check if they are pulsing when plugging in Magsafe using the oscilloscope (most multimeters are too slow to catch it).
      If not then go through the power sequence https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
      If it's pulsing then it's not actually missing and the issue is not in that first part of the power sequence.
      • salopian
        • Feb 2021
        • 6
        Oh, so sorry, you're right! I've written down the wrong measurement.
        PP3V3_S3 is 0.19V, not 1.79V
        Will try to get an oscilloscope and also go through the power sequence as suggested.
        Many thanks!
        • salopian
          • Feb 2021
          • 6
          Resistance to ground in diode mode:
          L7320 0.001
          L7310 0.001
          Resistance to ground in ohms:
          L7320 1.8 ohm
          L7310 2 ohm
          I guess these are the cpu coils?
          Thanks!
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            u had the same exact voltage like i had on same board. it's cpu is in short. ofcourse u can try with 1 volt and see if cpu is getting hot or some caps, but dont go to high with voltage, u can damage cpu. go around 1 volt and see if cpu or caps emosfet get hot, maybe ur lucky and it's just one mosfet or capacitor near it
            • salopian
              • Feb 2021
              • 6
              So high chance this board is not repairable due to a dead CPU, oh Apple....
              Where would be the best place to inject the voltage? At one of these CPU coils?
              Thank you so much for your help, really appreciated.
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                inject 1 volt on the coil (cpu side) without cpu heatsink. chech carefully if cpu or mosfet or caps around it get a bit warm.
                on my board it was the cpu getting warm.
                • dellxps15
                  • Feb 2014
                  • 1598
                  • italy
                  look at the attached picture; check the red markez zone for getting warm and that side of cpu too.
                  edit: i did edit the previous post but dunno why i did a new post. sorry for that
                  • Eleways
                    • Oct 2014
                    • 62
                    • Italy
                    Hi
                    I've a similar problem, my A1502 it's dead too, but the led does't light on.
                    These are my measurements:
                    PPBUS_G3H 12.55V
                    PP3V42_G3 3.4V
                    PPVRTC_G3H 3.4V
                    PP5V_S5 0V
                    PP5V_S0 0.39V
                    PP5V_S3 0.15V
                    PP3V3_S5 3.4V
                    PP3V3_S4 0V
                    PP3V3_S3 0V
                    PP3V3_S0 0V
                    S4_PWR_EN 0V
                    SMC_PM_G2_EN 0 V
                    S5_PWR_EN 0 V
                    SMC_ADAPTER_EN 0 V
                    PM_RSMRST_L 0 V
                    PP3V3_SUS 0 V
                    CPUVR_PGOOD_R 0 V
                    PP3V42_G3H 3.4V
                    Anyone can help me to understand what's the problem? I'm not able to find a solution.
                    Thanks!!
                    • mon2
                      • 14677
                      hi.
                      1) Is your logic board also 820-3476-A ? Please confirm by searching for these markings on the PCB.
                      2) Assuming yes, the PP5V_S5 rail is created by U7501 pin # 29. Check for this rail @ C7505.
                      3) Confirm the enable for this rail - check the voltage on pin # 4 of U7501.
                      4) Voltage on pin # 5 of U7501 ?
                      • jeusith
                        • May 2022
                        • Mexico
                        Hello guys, greetings from Mexico and a Happy new year to all of you!
                        I'm having trouble with a 820-3476-A that suddenly decided not to power-on (no liquid damage or anything like that).
                        I'm seeing similar symptoms as the ones described on this thread (No power, but charger light is present), also, I can hear a clicking noise on the board, which seems to be coming from Q7520 (I assume that's where the noise comes from, since after inspecting under a thermal camera, temperature pulses can be seen at the same rhythm of the noise).
                        I also took some measurements following mon2's advice:
                        PP5V_S5= Oscillating between 1.5V - 5V
                        U7501-Pin 4= Oscillating between 0-0.14V
                        U7501-Pin 5= 0V
                        Any clues? I might lose my job if I don't manage to fix this MacBook
                        • mon2
                          • 14677
                          What is the voltage to ground of PPBUS_G3H?
                          Is it also power cycling?
                          • jeusith
                            • May 2022
                            • Mexico
                            PPBUS_G3H is a steady 12.57V
                            • reformatt
                              • Feb 2020
                              • 1509
                              PP5V_S5 is a LDO output on U7501 and should be a stable 5V (as is pin 22 which should be 3.3V). This chip is fed from PPBUS_G3H, so check it on pin 23 for voltage and stability. Then check resistance to ground for pin 22 and 29. LDO's don't provide much current, so it doesn't take much for them to shut down as they are just linear regs.
                              You will only get PP3V3_S5 enabled if SMC_PM_G2_EN is high.
                              • jeusith
                                • May 2022
                                • Mexico
                                U7501:
                                Pin 22 = stable 3.3V / Resistance to ground ≈4MΩ
                                Pin 29 = cycling between 1.5-5V / Resistance to ground ≈2MΩ
                                Pin 23 = stable 12.57V
                                • reformatt
                                  • Feb 2020
                                  • 1509
                                  Are you doing this with board removed or still in the laptop? Only other place PP5v_S5 goes is the trackpad. Try disconnecting it from J4800.
                                  This LDO output is limited to 100ma. So it's either an active short or U7501 is U/S (unlikely).
                                  • jeusith
                                    • May 2022
                                    • Mexico
                                    The board is removed from the laptop, so the Trackpad was disconnected while taking measurements.
                                    The owner of the macbook tells me that a while ago, he had a similar problem (no power and he heard a clicking noise) he took it to another shop and they had his logic board replaced.
                                    Before replacing the logic board on the other shop, he says, the OS was reporting the battery 'was in bad condition and that it needed to be replaced soon'.
                                    After the logic board was replaced, this message about the battery never showed up again and he assumed it magically fixed itself
                                    Could it be that the battery somehow damaged U7501?
                                    • reformatt
                                      • Feb 2020
                                      • 1509
                                      Not likely. These boards should boot on the bench without a battery connected BTW. They may have swapped the entire lower case with battery I suspect. Broken screen on these results in a donor machine, since the displays are still seriously expensive. They were only made for a limited time, which is why they are like hens teeth.
                                      What is the resistance to ground of PP5V_S3 (at L7520). You should also measure all sub-rails too, just go around each coil and measure resistance to ground. Check L7630 just to make sure you don't have a dead PCH.
                                        Apple MacBook Pro Retina 13' A1502 820-3536-A Schematic
                                        Apple MacBook Pro Retina 13' A1502 820-3536-A Schematic...
                                        10-12-2024, 11:43 AM
                                      • ugamazing
                                        820-02020 PPBUS_AON missing
                                        by ugamazing
                                        Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                        Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                        02-05-2025, 04:21 PM
                                      • jpreza
                                        Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                        by jpreza
                                        I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                        Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                        It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                        Looking at the card, it appears to be missing the following:
                                        1x 1.0uH inductor - orange square
                                        2x...
                                        11-01-2024, 10:54 PM
                                      • gurj1979
                                        Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                        by gurj1979
                                        Hey guys.
                                        Need help with this one.
                                        Fan not spinning due to missing PWN Fan signal.
                                        Also 5 seconds from powering up it freezes, unless in BIOS.
                                        But as soon as Windows starts to load, it will freeze.
                                        CPU is COLD / Room temp when it freezes.
                                        I've replaced the CPU, same problem.
                                        Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                        Replaced fan - same problem.
                                        Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                        Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                        08-19-2024, 05:22 PM
                                      • ein_individuum
                                        Missing Capacitator Intel I9-12900KF CPU
                                        by ein_individuum
                                        I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
                                        I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
                                        Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
                                        08-06-2025, 01:36 AM
