Missing trace pad help
  • ivtec
    • Dec 2008
    • 1967
    Hi guys; i have here a Kindle mother board that charger port fell off, i have a new port but there is a missing trace pad on the board the second trace on the left next to the ground pin,
    can i chant this missing pin; see pic on the link,thanks and have a merry Christmas.
    http://www.ebay.com/itm/Kindle-Fire-...8AAOSw8-tWXglW
    • 31249
    Re: Missing trace pad help
    there are 2 ground pins, the other side is the 5v.
    the remaining 2 are usb data
    they link to the other side of the board, so you could fit a fine wire through the hole to solder to the pin.
    • ivtec
      • Dec 2008
      • 1967
      Thanks stj;i have another same board that is bad and i scraped at the beginning of the missing pad and it is tied to the first pin which is ground and goes to that black chip,if so i can chant it to the first pin on the left and connect a small wire to the black chip right in front of the missing pin see pic of the board that is ruined and has only 2 trace paths
      • ivtec
        • Dec 2008
        • 1967
        • ivtec
          • Dec 2008
          • 1967
          Sorry here it goes
          • ivtec
            • Dec 2008
            • 1967
            Originally posted by ivtec
            Sorry here it goes
            here is one more pic,Sorry is kinda hard to take good pic with a crapy camara
            • ivtec
              • Dec 2008
              • 1967
              Here another pic hope is better
                • 31249
                these crap connectors get ripped out a lot do they?
                i know it's common on portable harddrives.
                • TossDon
                  AKA Masood
                  • Jun 2013
                  • 26
                  The extreme connections are for power, as I saw in the first pic the pads are OK, even without the other 3 pins connected the charging should work, in your next picture, you filled in the solder, remove that to avoid any shorts and wire wrap if you need the the data connection too, generally, you can use the flash card for transfer. Good luck.
                  • ivtec
                    • Dec 2008
                    • 1967
                    Thanks TossDon, since there is no trace path on the second trace on the board, can i connect a wire from second port pin to the black chip,but i don't know if i have to connect it somewhere else/ thanks and have a Merry Christmas .
                    • ivtec
                      • Dec 2008
                      • 1967
                      Here the real board pic attach
                      • TossDon
                        AKA Masood
                        • Jun 2013
                        • 26
                        First, clean/remove all the solder dunes and then solder the new connector, the first and last pins should be soldered, leave all the others for now, MAKE SURE there are no shorts and connect and see if charging gets restored. FYI, The second pin from left is the ID for the device and Pin3/Pin4 are for data sync, all three are not needed for charging. Let me know how it goes.
                        Merry Christmas
                        • ivtec
                          • Dec 2008
                          • 1967
                          Merry Christmas
                          Thanks TossDon; i'm waiting for the Port,
                          If i don't connect those 2,3,4 pins what happens?
                            • 31249
                            in theory it will charge, but you cant use the port to connect to a pc - although it should charge from the pc, just no data transfer.
                            • TossDon
                              AKA Masood
                              • Jun 2013
                              • 26
                              stj is right, you won't be able to connect to PC for data sync but it will still charge from any USB port.
                              • ivtec
                                • Dec 2008
                                • 1967
                                Thanks guy i appreciate your info and now i understand.
                                • dj_ricoh
                                  • 2073
                                  alright!
                                  was reading with great interest this post and i want to ask one thing:
                                  no one suggest to use sand paper?
                                  i have a lot and i only use it in case like this.
                                    • 31249
                                    why sand?
                                    • SteveNielsen
                                      Retired Tech
                                      • 2327
                                      Sandpaper would be damaging.
                                      • ivtec
                                        • Dec 2008
                                        • 1967
                                        Isn't sand paper good to sand the pins on the port? to make good contacts,i use sand paper to scrape the pins so the solder will adder better,isn't this a good practice,correct me if i'm wrong?
                                        • chth96
                                          Is it possible bridging tiny broken trace
                                          by chth96
                                          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                          cutting tiny trace.
                                          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                          12-03-2022, 11:32 PM
                                        • ugamazing
                                          820-02020 PPBUS_AON missing
                                          by ugamazing
                                          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                          02-05-2025, 04:21 PM
                                        • jpreza
                                          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                          by jpreza
                                          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                          Looking at the card, it appears to be missing the following:
                                          1x 1.0uH inductor - orange square
                                          2x...
                                          11-01-2024, 10:54 PM
                                        • gurj1979
                                          Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                          by gurj1979
                                          Hey guys.
                                          Need help with this one.
                                          Fan not spinning due to missing PWN Fan signal.
                                          Also 5 seconds from powering up it freezes, unless in BIOS.
                                          But as soon as Windows starts to load, it will freeze.
                                          CPU is COLD / Room temp when it freezes.
                                          I've replaced the CPU, same problem.
                                          Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                          Replaced fan - same problem.
                                          Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                          Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                          08-19-2024, 05:22 PM
                                        • salopian
                                          Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                                          by salopian
                                          Hello. I would need some advice please.
                                          My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                                          He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                                          I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                                          I have already replaced the logic board with another...
                                          02-27-2021, 07:30 AM
