Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
    Hey guys.
    Need help with this one.
    Fan not spinning due to missing PWN Fan signal.
    Also 5 seconds from powering up it freezes, unless in BIOS.
    But as soon as Windows starts to load, it will freeze.
    CPU is COLD / Room temp when it freezes.
    I've replaced the CPU, same problem.
    Replaced SIO/KBC IT8987e and reprogrammed - same problem.
    Replaced fan - same problem.
    Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
    Checked the Thermal sensors around CPU and Board to the SIO/KBC and they're good too.
    No data lines seem to be missing.
    Checked resistors and data lines from SIO/KBC to the fan, these are good.
    But the SIO/KBC is missing the PWM Signal to the fan.
    If I inject 5v to the PWM, the fan kicks in, but the machine will still freezes when loading Windows.
    What am I missing ?
    Thanks.
