HP DV6-6027TX wont boot (caps lock 1 flash)
  • luke10050
    • Mar 2013
    • 209
    Hey everyone, its been a while.
    I have a hp dv6, model 6027tx with an intel core i7 and dedicated graphics that has a slight problem.
    When the system is plugged in and the power button pressed, it turns on and flashes the caps lock key once (backlight does not come on, no image) and then turns off. It will not repeat this until you unplug the power and plug it back in, i have tested it also with a core i3 i had lying around and no change.
    It will occasionally turn on a second time without being unplugged and then immediately turn off.
    I really dont have any ideas at all, just curious on what my first few steps from here should be and wondering if anyone has a partial or full schematic of this laptop
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: HP DV6-6027TX wont boot (caps lock 1 flash)
    It could be a bios issue, you can try to flash the bios.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3582
      • slovakia
      1blink-cpu fault
      • luke10050
        • Mar 2013
        • 209
        I know its considered a cpu fault, but at this stage i've tried 3 different cpu's that work in other laptops. They all produce the same error
        Edit: i should also note that the cpu is getting power, ~1.1-1.2v which from memory is pretty normal
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3582
          • slovakia
          try to heat up GPU to 100c
          • polytek
            • Dec 2013
            • 496
            • TUNISIA
            REFLOW THE PCH it will fix it
            • luke10050
              • Mar 2013
              • 209
              Had a look, pch does appear to be getting +3.2v, so i assume either a corrupt bios or it needs a reflow?
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Originally posted by ktmmotocross
                1blink-cpu fault
                If it stays on and blinks like a standby light, then yes.
                Had a Compaq CQ 61 fail like that, it turns on and stays on, but nothing else except for an LED that blinks like a monitor standby indicator.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  More likely bad CPU caps or CPU socket needs to be reflowed.
                  Arc A770 16 GB
                  • luke10050
                    • Mar 2013
                    • 209
                    Probably, tested the 2720qm in a toshiba board i had lying around, the cpu is perfectly fine, i think the pch could be the problem as the laptop went through something that fried the ac adaptor. Might need to inspect the ethernet NIC and a few other things
                    • luke10050
                      • Mar 2013
                      • 209
                      Just an update incase anyone stumbles aceoss this: the motherboard is a HPMH-40GAB6600
                      I've got to the stage where i get run_ok and some cpu power but the uncore power ok signal is not sent. Meaning the CPU does not initialise causing the 1 capslock flash
                      • luke10050
                        • Mar 2013
                        • 209
                        Hey, digging this up because i'm still working on it. I notice i get 19v to pq802 but the iGPU does not seem to be getting any power, could this cause a "bad cpu" code?
                        • FShahid
                          • Nov 2012
                          • 57
                          Could be bad chipset chip (northbridge chip) due to bad or poorly designed charger. At least on a new dell xps 15 (i7-4700HQ bga) model I have seen overheating chipset chip while the system constantly making 7 beeps for CPU error. It so happened by the original charger which was connected to a faulty AC outlet I suppose.
                          • luke10050
                            • Mar 2013
                            • 209
                            Its a possibility, it looks like i'm not actually getting a pwm signal for the FETs. Though looking at the boot order the igpu voltage should come on at the same time the cpu core power does. I get cpu core power but no igpu power. I'm leaning toward a failed mosfet driver or power management IC myself. Unless igpu power is not required for it to boot.
                            • welcometoo
                              acer nitro 5 AN515-55 no display / caps lock
                              by welcometoo
                              Hi brothers, please i need help diagnose acer nitro 5 no display issue.
                              model: nitro 5 an515-55
                              motherboard part number: GH51M LA-K862P Rev: 1A
                              i received this laptop with a short in power line, it was a capacitor + a mosfet on VCORE line , the laptop turned on cpu and gpu getting warm all voltages seem ok except vcc_gt but no display/caps lock activity also no hdmi out.
                              i flashed new bios also ec(ene kb9022) the same result .
                              disabled discrete graphics (rtx 3060 ) by cutting its power and shifting a resisror near pch VCC_GT comes but still the same...
                              07-05-2025, 11:11 AM
                            • Kiwi Viking
                              HP Elitebook 855 G8 all of a sudden does not power on. 7 flashes of Caps lock and Number lock prod ID 4X5S2PA#ABG
                              by Kiwi Viking
                              HP Elitebook 855 G8
                              Product ID:4X5S2PA#ABG
                              Motherboard M53301-601.
                              Hi Gurus, I am wondering if someone might be able to help. I purchased recently this used computer that otherwise looks in mint condition. I worked for 1 week, until one morning I shut down the computer using the power off commands in windows. There was no warranty. This was purchased for my teenager for use at school.
                              When I went to start the computer up in the afternoon, all the keys lit, but the computer didn't POST. Then the next thing I tried (pressing the power button) resulted in only the...
                              03-01-2025, 01:05 AM
                            • Ihandyrepair
                              4 red flash led 65X950G boot Sony and android logo but then black
                              by Ihandyrepair
                              HI guys
                              I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                              here is the issue
                              I have Sony and android logo. but then 4 led red flash lights front of the tv
                              I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                              but then I get black screen and 4 red flash light at the front LED
                              but I get 3 led flash on the LED driver board.
                              I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                              so I tried...
                              07-11-2024, 01:45 AM
                            • hinisa
                              Xiaomi router freezes at boot after re-capping
                              by hinisa
                              I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                              When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                              After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                              Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                              07-08-2023, 05:58 AM
                            • zlr8r
                              HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
                              by zlr8r
                              Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
                              To begin with, this laptop was dead-dead.
                              Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
                              • am getting white power led
                              • 5-long-flashes on CAPS Lock and NUM lock
                              • then, fan full speed
                              • CPU heats up some (smaller die PCH, does not)
                              • always constant black screen no matter what's tried
                              • no USB recognition
                              • no HDMI output
                              this is as far as I can get with it and not sure where to inspect next ?
                              I tried...
                              03-27-2024, 03:13 PM
