we were garage sale shoping when the guy at sale said he had a laptop for sale.He said it was password locked and it belonged to his bother and that he had forgotten password and had given him the laptop.I figured windows password would not be hard to figure out.So i took it to my brother to unlock it.He said it had a 3 layer password protection something about bios ,hard drive and something else he was not able to unlock it.He said he had never seen that level of protection.He said it was probably belong to some had know a lot knowledge about computers.I was wondering if it is possible to unlock or is the something i should just leave alone.
Bought computer thats is password locked
Re: Bought computer thats is password locked
Depends what kind of laptop it is. If it's not a ThinkPad, BIOS password can be removed by reflashing the BIOS chip using a programmer. I recall there are solutions for the hard drive as well.
If it's a ThinkPad, no dice, as they have a dedicated security chip. It will need a new motherboard in that case.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company. -
This might be helpful, worth a look anyway:
http://www.thinkwiki.org/wiki/Embedd...rity_SubsystemComment
Can you supply the service tag number, service tag is like 123GB45-595B or 2A7B etc
Does it come up with a white screen This system is protected by the Password Authentication System
If it does what is that code?Comment
Some Dells spit out a code after 3 failed password attempts and can be unlocked with a key generator program, or you can use the service tag printed on the bottom of the laptop to get the master password. You may be lucky and not need to take the laptop apart and flash the BIOS.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
post the service tag here, so we can see it
or use this link, http://bios-pw.org/Comment
try:
hxht114q
qurc3mu1
3vn344jdsEFI0OiHThings I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
1010005 ?Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
I called dell told them my situation .how a bought computer garage sale and bios is locked.They told me to register new ownership online. The will expedite the process.they opened a ticket an it will be sent to level 3 tech to get a unlock code.Comment
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
Channel: BIOS Requests ONLY!
by SysengThis sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...-
by moshuHi everyone, I have a HP EliteBook 755 G4 with a Biuos password.
I've read the 16MB chip and patched using ​RCUnlocker_v_1_0 but seems it didnt worked, password is still there.
Can you please help to remove the password?
after first boot, there was an message thet firmware is restored, dont know if was suppose to happen.
HP EliteBook 755 G4
ProdID: W5Q98AV
SN: 5CG7524BY4...-
by Modify_incI have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
by Mike_HoDear All,
I have one 2nd hand Thinkbook 13s G2 ITL with broken display, after replace the LCD module it show password locked,
Can someone please kindly help me to get back the password code or modify this BIOS Dump to clean the password.
S/N: R912D81K
BIOS: W25R256JV
Thank's a Lot.
Best Rgds,
Mike....-
- Loading...
