Hdd recovery help needed..
  • pravin6p
    • Mar 2014
    • 75
    • india
    I HAD MADE A WRONG DECISION WITH A CUSTOMER.
    I ACCEPTED A CUSTOMER LAPTOP WITH PROBLEM NOT STARTING WINDOWS.
    STRUCK AT BOOT SCREEN. I PROMISED TO KEEP THE DATA (SOME IMPORTANT THING) AND RE INSTALL WINDOWS. AFTER THAT I CAME TO KNOW THAT THE HDD CONTAINS LOT OF BAD SECTORS I CONNECTED THE HDD THROUGH USB IT TOOK 5 MIN TO DETECT THE DRIVES. AND ITS IN DAMAGED CONDITION.
    HERE THE LOCAL PEOPLES IN UAE ARE "CRAZY" THEY DON'T KNOW ANYTHING AND THEY WONT ACCEPT ANY TECHNICAL REASONS. I'M REAL IN A HELL NOW.
    ANY WAY TO GET BACK THE DATA....
    ANY SUGGESTIONS..?
    • 31248
    Re: Hdd recovery help needed..
    if you use linux there is a few copiers that will re-try bad sectors until they get a good read or the world ends - whatever comes first.
    not sure about win though.
    • pravin6p
      • Mar 2014
      • 75
      • india
      i used hdd regenaretor... but it says mbr is damaged.
      any i dont want to recover it . i just want to give it back in the same condition i received.
      • drdyzio
        • Apr 2014
        • 74
        try some of these
        http://en.wikipedia.org/wiki/List_of...overy_software
        with a working machine and the faulty hd connected to it obviously.
        • pravin6p
          • Mar 2014
          • 75
          • india
          going to try kalii linux . forensic.
          • drdyzio
            • Apr 2014
            • 74
            let me know how to get on
            • sparker1
              • Sep 2011
              • 343
              I have used "ddrescue" in ubuntu to recover data from a badly damaged drive but it took about 4 days. Info here http://www.debianadmin.com/recover-d...-using-dd.html and here http://www.cyberciti.biz/tips/how-do...e-command.html
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                just a heads up: if windows cant fix something, it will break it to the point that nothing can fix it.
                Follow the white rabbit.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  I've encountered many drives that stop a windows PC from booting or crash when connected through USB but Linux will mount and copy, ignoring the faulty parts when copied to an external USB drive.
                  I use a Mint or Ubuntu CD in the original PC/laptop.
                  • dspok
                    • Jan 2014
                    • 553
                    • Nepal
                    sometime i also face same case.
                    at that moment i use linux live cd or resuce disk e.g. HirenBootCd, UltimateBootCD to get the data back.
                    try HirenBootCD, remove bad sector & load minixp, see if data is visible.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      The Linux on Hiren's Boot CD will work for this.
                      I have done the same thing for a customer yesterday. In an USB-SATA rack it took 5 minutes for Windows to detect it, and then it asked if i want to format it. Put it back in the laptop and booted Linux from Hiren's Boot CD and it mounted all 3 partitions with no problems. Got all his important data back.
                      A working TV? How boring!
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        try HirenBootCD, remove bad sector & load parted magic, see if data is visible.
                        fixed that for you. if windows cant fix something, it will break it to the point that nothing can fix it and the parts of the os that does that still exit is miniXP. which is EOL BTW so i would stay off the net with it.
                          • 31248
                          i would stay off the net with any windows version.
                          atleast with xp they wont be adding any NEW backdoors!
                          • dellxps15
                            • Feb 2014
                            • 1598
                            • italy
                            if hard drive is not so bad damaged, u can try hdd recovery, make cdrom and scan and repair hard drive, then get data from usb or direct sata connection.
                            another program i love to use is: get data back for fat or ntfs. it took a big time but generally i get all files i need.
                            another option is partition recovery.
                            sometimes if hard drive is not working, a simple "chkdsk /F X:" where x is the partition shown as empty in windows) fix the problem and then hard disk become visible again.
                            PS: write in caps lock is a bad idea on a forum, it's like scream to people.
                            • pravin6p
                              • Mar 2014
                              • 75
                              • india
                              Sorry for that....
                              • pravin6p
                                • Mar 2014
                                • 75
                                • india
                                I got a lession ,that, its not safe to made hdd recovery until you are in safe place.
                                what happened is , when i was tryind hdd regenerator, it reached 8% my boss removed hdd saying there is no progress. so the 'c:' drive is damaged.
                                when i tryed to copy from linux flatform , a customer came and turned my laptop , again the hdd lost connection. and now it completly ruined my life. the hdd is not working anymore.
                                Any way i think the better way to recover is from linux flatform. bcoz it ignores filesystems. and able to mount many file types.
                                • taufeeque ahmed
                                  • Sep 2011
                                  • 6
                                  hi friend first of all mistake can be happen but to rectify them is very important. sometime mistake are payable so now it is depend on you how you convenes the customer one thing you can do is to inform your customer that your hard disk is bad need to replace give him the price tell him new hard disk have one year warranty I will install software for you free of cost and I will try to recover your data what ever I will get it recovery will take 5 to 10 days ? if he really need data he will be ok because he also have no option once he get his laptop fixed he start working on it he will not care of data just keep hard disk a side in box after 5 to 6 days call him and tell him sir we tried your data for 5 days but still not able to recover your hard disk stop working in between so recovery not possible after that he will get relax and you are in safe
                                  second thing he may ask you causes about hdd failure you can say due to temperature heating issue virus problem computer not shutdown properly etc.. third thing is he will ask you how he will get date so Google the data recovery professional near to your location and give him their number. I am also in UAE so I the nature of people
                                  if you want to try to fix harddisk take any old bad harddisk and try don't do RND on customers harddisk if you want further assist you can email me or reply on badcap my id laptopservicing"gmail.com
                                  • taufeeque ahmed
                                    • Sep 2011
                                    • 6
                                    • dellxps15
                                      • Feb 2014
                                      • 1598
                                      • italy
                                      there are 2 situation: steeel disk scratched: no recover possible.
                                      pcb board damaged: possible in older hard drive to swap with same board.
                                      damaged head: recovery possible only if replace head. lot expensive...
                                      no fisical damage, but only bad sector: recovery possible with the tecnics i have said.
                                      dont google for professional repair store:
                                      they can ask up to 2000€ for head replace. i think noone will spend that money.
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        It doesn't seem to me that it's your fault that the hard drive is having problems. Originally it had bad sectors and then your boss pulled the drive, the owner later interfered with the recovery. Don't stress or take the job personally, it's the nature of the repair game that jobs sometimes don't work out to plan.
                                        From experience i know that stopping a hard drive recovery process once started can make the problem worse.
                                        Check this article for recovery of files using Knoppix
                                        http://lifehacker.com/192982/geek-to...with-a-boot-cd
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          >Read BIOS guides, methods, resources and tools
                                          Ack
                                          >Try the method at BIOS guides, methods, resources and tools before requesting help
                                          Ack
                                          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                          01-30-2025, 04:26 AM
                                        • spoti hakai
                                          HP 15t-dh100 BIOS recovery help needed
                                          by spoti hakai
                                          Hi, thank you for taking time to read this.
                                          I need help with EC firmware files extraction.
                                          OMEN Laptop - 15t-dh100 CTO
                                          Product ID: for more specific accurate search
                                          8VM74AV
                                          Can you kindly mention files which should be flashed in 16 MB bios chip? and files which should be flashed in 1 mb chips.
                                          Bios version: F.44 bricked my laptop.
                                          F.38 or F.39 were last working files.
                                          5 capslock long blinks 3 short.
                                          First, when bios updated started from windows update, it broke the laptop. Second, when i tried Win +V key,...
                                          11-13-2024, 11:21 AM
                                        • volinakis
                                          Chromebook recovery failed - how to fix it
                                          by volinakis
                                          So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
                                          Finally I found a site where they suggested to try with an older image and ... it worked!
                                          What I did:
                                          - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
                                          09-18-2023, 03:26 PM
                                        • vbogoev
                                          Lenovo S6000 won't turn on. Data recovery needed.
                                          by vbogoev
                                          Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
                                          Code:
                                          [PWRAP] pwrap_init_preloader
                                          [PWRAP] pwrap_init
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
                                          [PMIC_WRAP]wrap_init pass,the return
                                          06-20-2023, 06:36 AM
                                        • reformatt
                                          Intel iMacs, 3rd party SSD failures and Fusion setups
                                          by reformatt
                                          I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                          As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                          So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                          12-18-2024, 10:34 PM
