List of pin compatible Laptop ICs
This is a sticky topic.
  • joselito
    • Mar 2015
    • 50
    • Philippines
    #161
    Re: List of pin compatible Laptop ICs
    HI
    is this IC have compatible replacement?
    G5616..
    thanks.
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      #162
      Originally posted by joselito
      HI
      G5616..
      thanks.
      Seem compatible with RT8207 family, just make sure the package TQFN3X3-20/WQFN-20L 3x3 or TQFN4X4-24/WQFN-24L 4x4
      compare its both pin out with according datasheet each vendor
      https://cdn.badcaps-static.com/pdfs/...6218c2ffb1.pdf
      https://cdn.badcaps-static.com/pdfs/...fa9f34c8a3.pdf
      • ahmad.qralh
        • Apr 2017
        • alkrak
        #163
        Thanks for sharing
        • oussama.elcheikh
          • Apr 2017
          • 34
          • Lebanon
          #164
          please hp15-d030se 03011NG00-600-G bios Please
          • annietronix ebay
            • May 2017
            • Nigeria
            #165
            Originally posted by highpulse
            max 8731ae , wich one can be compatible ?
            getting a similar one might be a hard shell to crack. I'd rather check in dell vostro 1000.
            • kadi144
              • Aug 2015
              • 690
              • algerie
              #166
              can i use a TPS51216 or BQ 727 as replacement of TPS 51716 in DELL INSPIR0N 15-3000
              • jbstokyo
                • Jun 2017
                • 6
                • japan
                #167
                Any RT9024PE replacement?
                • farman19
                  • Jul 2017
                  • India
                  #168
                  rt 8223b compatible ic???
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    #169
                    216-0774207 can replace 216-0771009, done just now on HP G62. It's a "newer" family too, likely based on the same architecture but it is seen as an upgrade - 6300 series vs 5400 series.
                    A working TV? How boring!
                    • Rashid36
                      • Aug 2014
                      • 59
                      • Saudi Arabia
                      #170
                      Dear All member i need help about this chip with number "2n=2m" or any website where i can find this code
                      • fddizon
                        • Sep 2011
                        • 555
                        • Philippines
                        #171
                        What is the board you're working at?
                        • dvitryv
                          • Aug 2017
                          • Russia
                          #172
                          2n=
                          https://cdn.badcaps-static.com/pdfs/...d7b1efab2b.pdf
                          • swapnil1996
                            • Aug 2017
                            • 5
                            • India
                            #173
                            Nuvoton sio npce795pa0dx alternate so that i can fix my dell n5110 laptop. And any one has pinout of this chip please give.
                            • RethoricalCheese
                              • Mar 2013
                              • 1513
                              • Estonia
                              #174
                              Can I replace 25Q80BV for example for 25Q64FV? First one is 8mbit, second 64mbit but otherwise should be the same.
                              • imranromi
                                • Jan 2015
                                • 1288
                                • Pakistan
                                #175
                                No replace 25q80bv =1mb
                                25q64fv=8mb if u replace any 3v 1mb chip is working.if 8mb replace same 3v working all.8mb some chip 1.8v working.
                                • age80
                                  • Jun 2013
                                  • 55
                                  • Greece
                                  #176
                                  Are HM70, HM75 and HM76 interchangeable?
                                  • Djosla
                                    • Dec 2012
                                    • 246
                                    • Montenegro
                                    #177
                                    you can replace hm70 with hm76 ,and vice verca, but keep in mind that hm70 supports only celeron and pentium cpu`s so if you have better cpu onboard it won`t work for it...
                                    • age80
                                      • Jun 2013
                                      • 55
                                      • Greece
                                      #178
                                      Thank you Djosla for the info!!!
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        #179
                                        Correction, original chip was 216-0774009 not 216-0771009. Writing was rubbed off a little.
                                        • nabi
                                          • Sep 2017
                                          • 15
                                          • algeria
                                          #180
                                          Thank you
