List of pin compatible Laptop ICs
This is a sticky topic.
  • petehall347
    • Jan 2015
    • 4440
    #281
    Re: IC equivalent
    here is a datasheet .. https://www.datasheetq.com/RTD2136R-doc-Realtek
    • nassih
      • Oct 2015
      • 276
      • morocco
      #282
      Re: List of pin compatible Laptop ICs
      ok tanks,i have it ,i need equivalent for this
      • raajkumar
        • Mar 2015
        • 354
        • Srilanka
        #283
        I found a chip as PUM1 with marking 4B=4J on HP LA-E841P. But on another same model motherboard i found G5616B as the memory controller. Is that both are same? If it same, Does anyone know what is the number of 4B=4J chip and also i need Datasheet for it. There is some difficulties to get datasheet for G5616B and can get G5616A. but both are different.
        • age80
          • Jun 2013
          • 55
          • Greece
          #284
          https://www.google.gr/search?q=richt...e-gws-wiz-serp
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            #285
            Thanks bro. Now i got the correct information of these both chips and its looking both are same.
            So anyone can Use These both chips as compatible for DDR4 PWM Buck converter
            G5616B = RT8207P ( with marking 4B=4J )
            • mmaewbsoft
              • Apr 2018
              • 65
              • yemen
              #286
              hi all
              i have mb dell Dell Inspiron 15-3542 Wistron Cedar MB 13269-1 FX3MC
              i found 2 ic tps First (tps51225) Second ( tps 51716)
              this ic tps51225 is hot which alternatives for it and where is the ic power
              • raajkumar
                • Mar 2015
                • 354
                • Srilanka
                #287
                Originally posted by mmaewbsoft
                hi all
                This tps51225 is Step down controller for 3V 5V and TPS51716 for DDR3 power supply. I had the similar issue on a same board. I checked pin no.3 for VReg3 was low and i just removed tps51225 and checked that pin again it was low impedance. I inject 0.8V to that pin and i noticed SIO getting hot. I replaced SIO and the problem was gone.
                • mmaewbsoft
                  • Apr 2018
                  • 65
                  • yemen
                  #288
                  You mean replace This tps51225 is Step down controller for 3V 5V with new one
                  • mmaewbsoft
                    • Apr 2018
                    • 65
                    • yemen
                    #289
                    I replaced SIO and the problem was gone U said where is it please
                    • mmaewbsoft
                      • Apr 2018
                      • 65
                      • yemen
                      #290
                      you mean super input and outpt
                      • raajkumar
                        • Mar 2015
                        • 354
                        • Srilanka
                        #291
                        Yes. Its NUVOTON NPCE285PA0DX i have replaced. But you have to check it before you replace. I didn't replaced TPS51225 ic and i replaced NUVOTON SIO chip only.
                        • electronica
                          • Apr 2014
                          • 88
                          • algeria
                          #292
                          asus n550jv rev 2.0 it8586 and it8585
                          today i didn't find it8585 so i decided to replace it with it8586 and its work after programming . the motherboard is asus n550jv rev 2.0 .
                          i wanted to share this information with you guys .
                          • elghrib
                            • Jun 2021
                            • Maroc
                            #293
                            Thinks
                            • mohamed said
                              • Apr 2015
                              • 30
                              • egypte
                              #294
                              does anyone know compatibility with
                              JC-FH ic
                                • 21641
                                JC-FH ic
                                No idea what JC-FH is. Do you mean JC=
                                • t.danes
                                  • Jan 2016
                                  • 8
                                  • ba
                                  #296
                                  you can't advise a replacement for sy8032abc or what laptop it might be in
                                    • 21641
                                    FK*** SY8032ABC LA-B102P
                                    I don`t know if there`s an equivalent
                                    • kuchomex
                                      • Aug 2021
                                      • México
                                      #298
                                      tps51225=rt6575=BQ727b=<3F=1D 3F=EA 3F=FJ 3F=fk>
                                      • supun1992
                                        • Jun 2017
                                        • 13
                                        • Sri lanka
                                        #299
                                        isl95831 same type plz?
                                        • paulyboy
                                          • Mar 2020
                                          • 130
                                          • New Zealand
                                          #300
                                          Hi guys,
                                          Is there any other is compatible with UP9002P I have many various IC's but none with this code.
                                          Warm Regards
                                          Paul
                                          • Deby
                                            List of compatible laptop motherboards
                                            by Deby
                                            This is a list of compatible laptop motherboard information that I have been collecting for some time.
                                            And it's still ongoing.
                                            Every time I come across information that a board is compatible with another, I write it down.
                                            Anyone who wants to, can continue to expand the list.
                                            Packed in the rar, is an excel table that has additional information.
                                            Motherboards.rar...
                                            05-31-2024, 04:34 AM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                            Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:11 AM
