List of pin compatible Laptop ICs
This is a sticky topic.
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    #261
    Re: List of pin compatible Laptop ICs
    Current max same
    Voltage range same
    Socket sot 23,-5
    But pin configuration different
    Data sheet attached check
    • peste
      • 13377
      • ROMANIA
      #262
      does anyone know an equivalent for ISL88739HRZ
      thanks
      • Öğretmen27
        • Oct 2019
        • 36
        • TÜRKİYE
        #263
        What is the stac9200x5 counterpart?
        • makinist
          • Jan 2021
          • 6
          • Turkey
          #264
          I have replaced RT8207A on Quanta HK1 with G5616R52U from Quanta HK5 since surrounding components were almost entirely identical.
          Everything is ok on HK1 with G5616R52U.
          • Öğretmen27
            • Oct 2019
            • 36
            • TÜRKİYE
            #265
            ALC 662 equivalent ?
            • clikcom
              • Aug 2017
              • Perú
              #266
              Isl6265c algun equivalente?
                • 21641
                TPS22966DPUR - APE8990GN3B compatible (LA-A994P U18)
                • jasko_jacker
                  • Oct 2014
                  • 1140
                  • italy
                  #268
                  5X=4F 3v 5v alw is a ?
                    • 21641
                    Originally posted by jasko_jacker
                    5x=4f 3v 5v alw is a ?
                    rt6575dgqw 5x=
                    https://bomcross.ti.com/en/search?se...5dgqw&qty=1000
                    TPS51275B-1RUKR
                    https://cdn.badcaps-static.com/pdfs/...a3ab1be060.pdf
                    • jasko_jacker
                      • Oct 2014
                      • 1140
                      • italy
                      #270
                      • jasko_jacker
                        • Oct 2014
                        • 1140
                        • italy
                        #271
                        It's used in conjunction with bq24780s on asus motherboard as upgrade of
                        tps1285a , someone can confirm this cross reference ?
                          • 21641
                          Are you asking for a compatible part for the tps1285a or asking if its compatible with the TPS51275B / rt6575dgqw ?
                          The richtek cross reference says the RT6585A is compatible with the tps51285a .It says B2B meaning its a Fully drop-in replacement. Check both datasheets though to make sure
                          https://www.richtek.com/Design%20Sup...ss%20Reference
                          RT6585A marking code 3J=
                          https://cdn.badcaps-static.com/pdfs/...ae9d171f8c.pdf
                          • kher
                            • Jan 2021
                            • 16
                            • philippines
                            #273
                            8744e which one can be replace or compatible to replce?
                            • caspian
                              • Oct 2015
                              • 1591
                              • Laptop
                              #274
                              Mosfet AO4409 can be replaced by AO4423.
                              I observed that the factory did this replacement in Dell Inspiron n5520.
                              • elvirpa800
                                • Nov 2019
                                • 27
                                • Deutschland
                                #275
                                Hello
                                Any help for replacement for BAAAIK Its near the Battery port on Lenovo V130-14ikb Mainboard LA-F486p Rev 1.0 or if anyone has Schematics for it.
                                Thanks B.R.
                                • elvirpa800
                                  • Nov 2019
                                  • 27
                                  • Deutschland
                                  #276
                                  Sorry for LQ Picture
                                    • 21641
                                    Originally posted by elvirpa800
                                    Hello
                                    Thanks B.R.
                                    Schematic - https://www.badcaps.net/forum/showthread.php?p=1060162
                                    https://www.badcaps.net/forum/showpo...1&postcount=12
                                    BAA*** SY8286RAC
                                    No cross compatible part afaik .
                                    • elvirpa800
                                      • Nov 2019
                                      • 27
                                      • Deutschland
                                      #278
                                      Thank you very Mouch bro,you saved me ...
                                      • kalilinux25
                                        • Mar 2018
                                        • 2089
                                        • ZAMBOANGA SIBUGAY
                                        #279
                                        what is the alternative ic for BQ24780RUYR?
                                        • nassih
                                          • Oct 2015
                                          • 276
                                          • morocco
                                          #280
                                          RTD2136R IC equivalent
                                          hi everybody i need equivalent for this IC RTD2136R plz
                                          • Deby
                                            List of compatible laptop motherboards
                                            by Deby
                                            This is a list of compatible laptop motherboard information that I have been collecting for some time.
                                            And it's still ongoing.
                                            Every time I come across information that a board is compatible with another, I write it down.
                                            Anyone who wants to, can continue to expand the list.
                                            Packed in the rar, is an excel table that has additional information.
                                            Motherboards.rar...
                                            05-31-2024, 04:34 AM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                            Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:11 AM
