Gateway MD2419u Media Test Failure
  • Paul678
    • Nov 2011
    • 402
    With no hard drive, this unit displays this on bootup:
    PXE-E61: Media Test Failure Check cable
    PXE-M0F: Exiting PXE ROM
    Here is a picture:
    Then I tried to boot to a Linux-Live CD, and although
    at first it boots up fine, it ends up with this garbage on the
    screen:
    Jesus, I hope this isn't a motherboard issue!
    Any advice greatly appreciated, Thanks!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Gateway MD2419u Media Test Failure
    That's the network cards' BIOS trying to boot. It's normal.
    Looks like it unfortunately. However, does this have onboard graphics which steal from the RAM? If so, it could be bad RAM and the motherboard could be okay. Garbled characters in text mode is something integrated GPUs do when the system RAM is bad. Edit: Just googled it and it's a HD3200, so yes it's an IGP. Try changing the RAM, you may be lucky.
    A working TV? How boring!
    • Paul678
      • Nov 2011
      • 402
      Ok, I changed the RAM, and still the same problem.
      What I don't understand, is why during most of the BIOS
      bootup, and the LINUX boot-up, the graphics look perfectly
      normal. The Linux Knoppix Penguin looks absolutely fine!
      Then it takes a shit as soon as the Linux desktop is supposed
      to show.
      And when I'm not loading Linux live, what are all the
      "happy face" characters you can see in the picture?
      I'm anything BUT happy!
      There should be a proper: "No bootable disk" message....
      I'm starting to have a bad feeling about this one....the motherboards
      were $100 on Ebay!!!
      If it is the motherboard, I'll try baking it first......
      • artois7
        • Mar 2011
        • 159
        I get that second screen fairly often on laptops using an old ubuntu 6.06 liveCD. Try some other liveCD's, or even boot a windows install disc and see if the graphics are normal.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          The garbled up screen can happen if the live-CD uses the wrong resolution. Had that happen a bunch of times before.
          Try a Vista or Win7 install DVD if you have one.. They have a graphical installer (not DOS mode). If that's messed up as well, it might mean trouble.
          Other Linux Live CDs/DVDs might be worth a try too.
          My bet is that the Live CD you used auto-detected a wrong/oddball resolution, the LCD can't display it and you end up with that garbage on the screen.
          edit: Check the RAM with Memtest86+ too. That might be the cause for those weird "happy faces" when it tries to boot up, as the onboard/integrated graphics "card" uses the system RAM as video memory.
          • Paul678
            • Nov 2011
            • 402
            Ok, JOY! I was able to install Windows XP
            pro. Graphics look perfect.
            But now I have new problem: The laptop is
            shutting off by itself, as it's getting pretty hot.
            I scrapped off the old grey thermal grease, and
            installed new white thermal grease, and it still
            shut down on me. The fan is definitely working.
            The AC adaptor seems to be getting hotter than
            any other adaptor I have seen before. Maybe someone
            has overclocked this motherboard? Or at least something
            is overheating the unit......
            • Paul678
              • Nov 2011
              • 402
              Oh, great! Now I'm getting a blue screen of death:
              I pray to the Laptop Gods that it's a
              problem with the hard drive, and not
              the mother board.
              This happened as I was extracting a Windows 7 packet......
              • 999999999
                • Sep 2006
                • 774
                During installation of the OS and applications you'll have the CPU at a higher load than during regular use so it isn't necessarily a sign of a problem if the AC adapter seems hotter than the typical laptop adapter would.
                See if you can get temperature readings with software, either something already on the laptop or perhaps Notebook Hardware Control: http://www.pbus-167.com/
                When redoing the thermal grease, are you certain the heatsink is making good contact with both the CPU and the chipset? The bluescreen could just be the result of current overheating or a past instability that caused file corruption while installing the OS or apps.
                If you have not checked the system with Memtest86+ as Scenic advised, do that after checking temperatures (do not leave it running if it really is overheating).
                • Paul678
                  • Nov 2011
                  • 402
                  Ok, a ray of hope!
                  I put this 250Gig Western Digital into another laptop, and
                  I got an immediate SMART "your hard drive will fail
                  soon, back up data immediately" message.
                  And then Windows XP boots up, and the blue screen
                  of death shows up very quickly.
                  This means the Gateway's motherboard may be
                  good!
                  I'm trying not to celebrate too soon.....gotta find
                  a good used laptop SATA now.....not easy in Tucson.
                  Has anyone here ever repaired a bad hard drive? I've
                  read it's not an easy fix, unless it's only the PCB board.
                  But yeah, it's best to buy new when it comes to
                  hard drives.....
                  • 999999999
                    • Sep 2006
                    • 774
                    Consider the hard drive non-repairable if it's more than a PCB component or entire PCB swap. At best someone repairs it to get valuable data off, then replaces it with another one since reliability is important, yet fleeting if a drive has mechanical problems... and yet by "someone" I mean usually a data recovery center.
                    I wouldn't bother trying to find a good used laptop SATA drive locally, unless you already had a source/supplier known for low prices. Generally anything remotely modern will cost too much locally, possibly even as much as a new one except that right now HDD prices are still artificially high due to the Thai flooding. Best price for used HDDs is probably ebay, perhaps a seller who parts out laptops, or the For Sale subforum here or at Anandtech, etc.
                    https://www.badcaps.net/forum/forumdisplay.php?f=12
                    http://forums.anandtech.com/forumdisplay.php?f=19
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      SMART reporting failure usually means bad sectors. Happens on laptop drives frequently, due to them being moved around a lot and dropped quite often. Even if the laptop is in a protective bag, a drop still means high G forces which are bad for the HDD.
                      Since the drive is still being recognized, there is software that can fix the bad sectors temporarily - HDD Regenerator is one example - but it's intended for fixing them long enough for you to get data off the drive. Since this isn't the case and there's no data to be recovered, i would strongly advise throwing away the drive. Once bad sectors start to develop due to a mechanical reason (drive suffered shocks), they quickly multiply. There are very few exceptions to this.
                      • artois7
                        • Mar 2011
                        • 159
                        This is because it will attempt to load the drivers for the other laptop's motherboard. You can't generally swap XP installations like that unfortunately!
                        • Paul678
                          • Nov 2011
                          • 402
                          You are correct. The drive got worse and worse, slower and slower,
                          until eventually, the Windows XP installer couldn't even see it anymore!
                          Into the junk parts bin! I found someone who supposedly has a 320Gig
                          for $30, and says he will install Windows 7 on it, while it's on my laptop, just to prove that it works.
                          And another triumph: Gateway put black tape between the
                          fan and the heat sink fins, which effective hid the thick carpet
                          of lint that was hidden there! Once I got that shit out, the
                          laptop ran way cooler! Surprise, surprise! haha!
                          This is great news......hopefully this will be a working laptop (with
                          just a bad hard drive) for a measly $20!!!
                          • Paul678
                            • Nov 2011
                            • 402
                            Ok, bought a 650 Gig HD for $50, and it works great
                            on this laptop, thanks to all for easing my paranoia!
                            The guy installed Windows 7 64-bit just to prove it worked,
                            but he didn't partition the HD, so I'm gonna re-install it.
                            But my question is: Will I really notice a speed difference
                            between the 32-bit version I've been using, and the 64?
                            I read on Microsoft's website that you only really notice
                            a difference with large amounts of RAM, at least 4 Gigs
                            or more. This unit has 3 at the moment, but i plan
                            to make that 4 Gigs.
                            Also, I know it's best to make about an 80Gig partition
                            for the OS, but what about the rest of this larger drive?
                            Would you recommend dividing it up a bit? To improve
                            the seek time?
                            I'm gonna be using this laptop for digital audio recording.
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              Unless you have 4GB RAM or more, a 64Bit windows install won't be any better.
                              About the HDD partitioning.. get HDTune and check the performance of the drive (not necessarily in the laptop itself.. you can connect it to your main rig if it has SATA ports). The neat little function called "short stroke" lets you simulate a small partition.
                              i.e., if you have a 640GB HDD and you set short stroke to 120GB, it'll only benchmark the first 120GB of the drive (as if you benchmarked a 120GB partition). That way you can test out up to what size the HDD performs best, and then partition it to that size later in the laptop (system partition).
                              Example is in the attachments (full 320GB vs. same HDD shortstroked to 120GB)
                              edit: if you plan to use it for audio stuff, stick with the 3GB RAM you currently have and go for XP. Vista and 7 tend to have audio latency problems (dropouts, clicks and stuttering).
                              • Paul678
                                • Nov 2011
                                • 402
                                That's a cool tool, I'm using it now, thanks.
                                I'm shooting for the "short stroke" partition that will
                                give me the highest AVERAGE MB/s, right?
                                I haven't heard too much about Windows 7 having
                                audio problems.....I'll do more research....but I can tell
                                you that Cubase 5 32-bit so far appears to work well in Windows
                                7 32-bit, at least for me on one of my laptops.....
                                Maybe people were having problems with the 64-bit version
                                of Windows 7 ?
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  I have 64-bit Win7 on two laptops (2GB RAM each) and one PC (8GB), zero latency problems. No clicks, no pops, no dropouts, no nothing. The original HP Vista installs on the laptops did have issues indeed, but it ended up being wireless drivers at fault on the DV5, and the nvidia powermizer on the DV9000 (which nvidia has finally fixed now, after 3 years or so... i ran with powermizer disabled till i bothered to install new drivers this year and found out it works fine now)
                                  I use 12ms latency in ASIO4ALL with the onboard soundcards of my laptops, and 8ms on the main PC with a lame old Audigy SE (i blew the onboard). I do recording on my main PC with the Audigy, and i *never* had a digital glitch. Plenty of glitches made by the performers tho...
                                  Latency problems have nothing to do with the OS, they're caused by crap drivers. XP isn't any better in this regard. Never had any issues with Vista 64 either... a few years back while everybody was complaining about the 32-bit version i was cruising just fine with the 64-bit one.
                                  Stop spreading FUD, support for XP will be soon dropped and drivers are getting scarce already, for a current-day media production machine either use Win7 or get a Mac... Or whatever, but don't complain when things stop working. Getting XP drivers for a recent laptop is an adventure in itself. Getting stable XP drivers for a recent laptop is a shot in the dark.
                                  • ahmedtou
                                    HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                    by ahmedtou
                                    help me please
                                    I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                    When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                    I will share all the details with you, including the disc information.
                                    Code:
                                    HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                    Current Profile: BD-R
                                    Disc Information:
                                    Status: Empty
                                    State of Last Session: Empty
                                    Erasable: No
                                    Free Sectors: 12,219,392
                                    Free Space: 25,025,314,816 bytes
                                    Free Time: 2715:27:17 (MM:SS:FF)
                                    Next
                                    08-27-2025, 08:49 AM
                                  • npielawski
                                    MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                    by npielawski
                                    I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                    I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                    10-15-2025, 01:53 AM
                                  • chth96
                                    How Can I test PWM DM0365R?
                                    by chth96
                                    Hello
                                    I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                    So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                    I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                    I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                    06-18-2025, 04:14 PM
                                  • khelane
                                    test active pfc power with lamp test
                                    by khelane
                                    Hello
                                    I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                    Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                    Is there a way...
                                    06-03-2025, 01:00 AM
                                  • chronic519
                                    Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                                    by chronic519
                                    Hello.
                                    GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                                    Found issue with a RAM block
                                    Replaced, green lines gone.
                                    Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                                    Used a good card to test and same results low errors 32+.
                                    I am just search for some form of command to do a full test on the GPU.
                                    I just ran the mats command with my good GPU and passed after roughly 40 min.
                                    The repaired one, ran...
                                    05-20-2025, 07:56 PM
