MacBook Pro late 2016 (820-00239) with multiple failure modes.
  • npielawski
    • Oct 2025
    • Sweden
    I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
    I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with it for a week. I am so confused by what is happening as there are multiple failure modes.
    The motherboard is a 820-00239.
    Failure mode 1
    When I plug the computer, the voltage checker reads 5V, then 20V. The CPU gets warm, all the rails are on, all the way to S0, I don't find anything wrong. Because of this I put the motherboard back in the laptop. The fans don't start, the display seems broken (just 5 mm of colored jagged lines appear at the top of the display, I can see the cursor moving up there), the backlight is on, and the trackpad works. I plugged an HDMI adapter to use an external display, but that only worked in recovery mode, not for a regular boot. The touch bar is there and responds to touch, but extremely slowly.
    Before failure, PPVCC_S0_CPU is present at about 0.626V, then got missing. ALL_SYS_PWRGD, PP5V_S0, P5VS0_EN all went missing (non-exhaustive list).
    Failure mode 2
    After two, three minutes or so of being up and running, the laptop will shut off — whether the motherboard is in or out of the laptop. At this stage G3H and S5 are there but nothing else. I tested all the rails in the power aliases containing G3H and S5 (all present).
    Failure mode 3
    If I unplug and replug the laptop, the voltage checker reads 5 V and stays at 5 V. I identified that PP20V_USBC_XB_VBUS, PP3V3_UPC_XB_LDO, PP1V8_UPC_XB_LDOA and PP1V8_UPC_XB_LDOD are present, but PP1V1_UPC_XB_LDO_BMC is not. At this stage, I can't do anything more than that, I have to wait multiple hours (a night?) until it works again. At that point, if I plug the computer, from 5 V we reach 20 V again. According to logi wiki, a missing LDO_BMC is a sign of a broken cd3215 or corrupted bootrom, but I can't see how these two cases explain what happens here.
    Since there is no battery, I'd assume something “remembers” that it was on for it to fail consistently afterward. Failure mode 3 is extremely reliable as well, it will happen every time I unplug and replug, and it takes multiple hours for it to work again, certainly more than two hours. I don't think it's related to heat since it takes so long to get back to a working state, so could it be some capacitor holding a charge for so long? And what could cause all of this mayhem?
    I am really confused by all of this, but I hope any of this can make sense to you. Thank you for your help!
  • Boardview and Schematic Bot
    LENOVO S510 + Office 2016 Home & Business i5-6400 Specification for Upgrade or Repair
    This specification for the LENOVO S510 + Office 2016 Home & Business can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the S510 + Office 2016 Home & Business boardview and S510 + Office 2016 Home & Business schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
    09-12-2024, 01:58 PM
  • hartleyhare5
    Samsung QE65Q9FN — BN44-00944A (65A board) MOSFET failure (relay clicking on one connect) — advice before power-up
    by hartleyhare5
    Post body:
    I'm working on my Samsung QE65Q9FN (65" Q9FN QLED, European model) with relay clicking and no picture. The power supply board in the display itself is the BN44-00944A, known on the board itself as the 65A board (silk-screened designation). There is also a second board, the 65B, which looks identical but is only partly populated for the LED power.
    Symptom: Continuous relay clicking on the one connect — TV will not start up, no picture. However the standby LED is on constantly — so the standby supply rail appears to be alive and the...
    03-26-2026, 03:47 AM
  • w00pz
    No power - ramping voltage on multiple components - HP ENVY X360 13-ar, MB:G1 13 AMD X360 18740-1 448.0GA03.0011
    by w00pz
    Need help identify problem component or next steps to test.
    The motherboard isn't working there is no power indicator light and overall no power on.
    However, I have identified multiple 19v, 14, 11v, 10v and 5v points across the board but nothing that goes below 5v.
    No I have reached a part of the board where I think there is a problem.
    Multiple components (buck converters?) that are ramping up voltage. I have marked all the details in the picture, the problem is at the pink components - they are ramping up over of a few minutes from 0v to 4v and beyond....
    11-23-2025, 04:55 PM
  • puccovelli
    Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
    by puccovelli
    Hi all, I hope this is the right place to post.
    I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
    I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
    1] Could someone confirm what the component that has blow actually is (and where I could get another from).
    2] Whether this component is likely to cause the RAM failure issue, and if replacing...
    10-11-2025, 06:30 AM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    Replaced emmc.
    Terminal log
    UART
    AC_ON
    E-B
    FDE enabled
    06-01-2025, 02:11 AM
