Failed sectors at end of laptop drive
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    On my HP DV9000 i suddenly wasn't able to open a folder. The drive would keep churning and churning, but with the access light off. The system became unresponsive.
    I knew exactly what that meant so i booted HDD Regenerator and let it run. No trouble till the very end (99.34%), and then every single sector shows up as bad. It's done 336 already. With like 100.000 more to go...
    Now, the data in that folder isn't critical. The data on the rest of the drive however... The drive is 250GB and it's a WD IIRC. Well, at least the bads are only at the end of the drive. That means i can simply shrink the partition a hundred megs or so and keep using it.
    A working TV? How boring!
  • Pyr0Beast
    • Feb 2009
    • 406
    Re: Failed sectors at end of laptop drive
    Yes, I've done that before and it works.
    Just make a 'dead' partition on the end of it, or just make a partition up to that 95 (Save some % for error margin)
    • digge
      • Apr 2006
      • 296
      I wouldn't trust a drive that had those kinds of errors. Would be fine to use as extra storage for unimportant stuff and such. But if its a computer you use make backups and swap it. There is a risk that more and more of the drive will die with time.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        It is my main laptop, but i have important stuff backed up every week. It also needs a new mainboard... I'll do an overhaul once i'm done with exams at uni, then buy an enclosure and turn this drive into an external.
        • mattbrad2
          • Jan 2011
          • 122
          Not sure about HDD regenerator but MHDD can force the drive to remap those bad sectors so they'll never be used again. Its certainly useful when that sector is at the beginning of the drive or a few are spread out and you can't really clip the drives capacity.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            MHDD doesn't work with SATA drives in AHCI mode. I use Victoria, does pretty much the same thing.
            HDD Regenerator actually fixes the sectors but if the drive really is damaged they come back. With the 400 or so sectors it did on my laptop drive till i stopped it, the folder i was unable to access came back. I copied the stuff in it on a flash drive, and restarted it. I'm curious on how many it'll find bad till the end.
            • smason
              • 1652
              A drive with that many errors should only be used for the following:
              Doorstop
              Paperweight
              Target Practice
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                I have a 120GB Maxtor i use as an extra drive in my main rig. It used to have over 3500 bad sectors spread all over the place. I have also physically opened the drive and confirmed a scratched platter - whatever PSU this had been running on wasn't too kind to it. In fact it had so many that the SMART failed after i let Victoria remap all of them. Probably a buffer overflow. The drive has been holding fine for half an year. I do however only use it for movies.
                • Toasty
                  • Jul 2007
                  • 4171
                  +1 for HDD Regenerator.
                  Has saved my bacon many times.
                  veritas odium parit
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    Hdd reg is a miracle but sometimes can not fix certain drives ("drive not ready" error). Then i use HDAT2 for substitution. Hope it helps you also
                    Im Back... sort of...
                    • unlockdev
                      • 81
                      +10 for HDD Regenerator
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        Ah, didn't post the final update on my laptop. It did another 140 sectors till the end, bringing the total to about 450-500. The drive is fully functional now.
                        There are however exceptions for HDD Regenerator as you noted as well, on the aforementioned Maxtor drive it would say it fixed them but they would come back at the next reboot. Only a remap using Victoria (removing those sectors entirely from use) brought the drive in usable condition.
                        But hey - that Maxtor drive wouldn't even let Windows boot when i first got it.
                        • bigbeark
                          • Jan 2010
                          • 661
                          Amazing! I thought you needed a dustproof room to open up a HDD!
                          You opened it up, reassembled it, and it still works!
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            I actually even cleaned the platter with a cloth dipped in paint thinner before i closed it back... and hey look it still runs. And it's actually quite fast till it hits the areas with lots of remapped sectors.
                            I have a history of doing that - i first took apart a 10GB drive in my old computer and started it up like that. It died after a few minutes, not because of dust, but because a piece of plastic i forgot to remove made its way into the heads. It didn't have anything important on it tho. I had a 40GB Maxtor die on me - now that one had lots of good stuff that i haven't recovered to this day... oh well live and learn, never trust Maxtor.
                            I also fixed a friend's stuck 250GB Seagate (the drive took a fall, motor got stuck), by taking it apart and giving the spindle a nudge. It started spinning and has worked fine since.
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5047
                              • US
                              I can't imagine opening any hdd up and it still working without errors, they are filled with mostly vacuum and some inert gases. They require a class 10 clean room during manufacturing, any less, and a single particle of anything, can get caught on the head. Doing what you're doing to recover data from a hdd is actually quite genus, but continuously using that hard drive just freaks me out
                              and in the shop, whenever we have a hard drive that starts timing out on sectors, we find its usually only a short matter of time till it fails completely
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                All hard drives have a breather hole so they couldn't be possibly filled with any type of gas because it would get out.
                                  master hoarder
                                  • May 2008
                                  • 12176
                                  Sounds like the 40 GB DiamondMax Plus 8 I have. The drive had a about 1500 bad sectors when I got it. I did a low level format on it (with LLF tool), and the number of bad sectors sky-rocketed. After the LLF process was complete, the hard drive was no longer recognized by Windows.
                                  Never heard of HDD regenerator, but now it makes me curious if I can fix that Maxtor (not like I need it or anything). I do have a number of other hard drives that are bad in some way. Will definitely give this a try.
                                  Personally, I've never had a hard drive go bad on me. Kind of ironic, really, because I do have quite a few Deskstars and Travelstars in my computers - I think all of them are the affected "Deathstar" models, too. They all have at least a few bad sectors, but work just fine nonetheless.
                                  The bad hard drives I actually got from work, along with a bag full of other drives (some of them were quite decent).
                                  The Th3_uN1Qu3 is correct - there are no inert gases in the hard drive, just plain old air that we breathe.
                                  Also, if hard drives were "filled" with vacuum, they wouldn't work. The spinning motion of the platters actually creates an air stream close to them on which the heads can ride on. This is what allows the heads to get so close to the platters without actually ever touching them. Some hard drives (if not most, nowadays) have a mechanism that won't allow the voice coil and arm to move unless the drive's platters reach a certain RPM.
                                  • Pyr0Beast
                                    • Feb 2009
                                    • 406
                                    You should really get a job in modern datacenters )
                                    I had a perfectly healthy drive fail with all my data. Whopie do. I even went to do a full surface scan on it - 0 bad sectors. Next day - Pooof !
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5047
                                      • US
                                      hm I don't remember where I heard that. but the air inside it is not the normal 'air' we breathe. most breather holes appearently have a carbon filter
                                      • Pyr0Beast
                                        • Feb 2009
                                        • 406
                                        Yes. It is clean air (no dust), even partially dry air, otherwise, nothing speciall.
                                        • ahmedtou
                                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                          by ahmedtou
                                          help me please
                                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                          I will share all the details with you, including the disc information.
                                          Code:
                                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                          Current Profile: BD-R
                                          Disc Information:
                                          Status: Empty
                                          State of Last Session: Empty
                                          Erasable: No
                                          Free Sectors: 12,219,392
                                          Free Space: 25,025,314,816 bytes
                                          Free Time: 2715:27:17 (MM:SS:FF)
                                          Next
                                          08-27-2025, 08:49 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • Zentech
                                          Laptop Hard Drive Not Recognize (repair)
                                          by Zentech
                                          Ok, I have a laptop hard drive 1TB which is not being recognized by laptop. Tried different laptop, same results. I can't hear the disk spinning. This drive was good but I guess when I re-assemble the laptop, I connected the drive in the DVD drive, and the laptop will not boot up, after disconnecting the drive laptop boots again but when connect hd to appropriate slot, now it does recognize the hd. I'm trying to troubleshoot the controller board. I'm suspecting something when short circuit. Does anyone here have basic schematic or troubleshooting process for hd. I know the board has two connector...
                                          04-26-2021, 10:37 AM
                                        • Satdude
                                          Retro laptop floppy drive not working
                                          by Satdude
                                          Hi, I have a laptop with a Citizen W1D, an infamous drive in the retro computing hobby. They almost always have bad belts, such was the case with this one. However, after replacing the belt, the drive seeks and spins the disk, but the laptop still gives a "No bootable disk" error. Does anyone have any idea what could be wrong? The heads are clean and are able to move.
                                          05-24-2024, 02:32 PM
                                        • serious_electron
                                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                          by serious_electron
                                          Hello Everyone!
                                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                          06-28-2025, 02:57 PM
