playstation 5 digital firmware dump
  • BD4ROQ
    • Apr 2025
    • China
    #181
    have i CFI-1200A, edm030, blown bios chip, can i have the bios file?
    thanks
    • Reliance Gaming
      • Apr 2025
      • St. Lucia
      #182
      Originally posted by Cobbes
      Here is a working dump from a edm-031 cfi-1216a with 69gg southbridge. Change at 0x001C7200 the console unique data (MainboardS/N and SerialNo)
      dude this worked on a edm-040! thanks alot!
      • kUiTs
        • Apr 2025
        • 3
        • Estonia
        #183
        Originally posted by PedroMa74111271
        i guess im going to try to reflow the wifi chip. i bought this console with a 3 beeps of death, i dont know if the wifi issues was there before or if was caused by nor chip getting corrupted. Its just weird that the same bin file that was corrupted and was causing 3bod its now working.
        Anyway if anyone needs a bin file for a CFI-2016 B01Y (EDM-041) (it may have wifi issues)
        Thank you, your dump kind of worked for me (CFI-2016 B01Y, EDM-040, 69gg, J20H104), but yeah I now also have WiFi issues - MAC is not shown. Do you know if you have J20H100 or J20H104 WiFi/BT module?
        I the beginning I had DEAD console - no peeps, no nothing, Power draw was quick 58mA -> 8mA. BIOS dump showed some errors.
        I replaced values in your dump with my SN and MAC and now console works but no WiFi.
        BT works, update works, PSN games work, disc games work etc, only WiFi does not work.
        Power draw now is 254mA->14mA - kind of strange or not for slim?
        • Gamingrepairsukk
          • Apr 2025
          • 4
          Looking for a clean dump of CFI-1216B, board EDM-030 if anyone have one thank you in advance
          • Darky777
            • Sep 2024
            • 5
            • Mexico
            #185
            Good afternoon, any good soul to patch my original 1015B dump with 3BOD with one working??? It will be very appreciated
            • igeektech
              • Jul 2017
              • 18
              I have a PS5 Slim CFI-2015 EDM-044 with the 3 beeps, pulled the BIOS file and need help with a good file if anyone can assist.
              • kUiTs
                • Apr 2025
                • 3
                • Estonia
                #187
                try this
                • SoJustMe
                  • Jul 2024
                  • 5
                  • Saudi Arabia
                  #188
                  hi guys , need EDM-032 dump for 61GG please
                  i uploaded my currupted firmware
                  • igeektech
                    • Jul 2017
                    • 18
                    Originally posted by kUiTs
                    try this
                    tried this and still getting the 3 beeps unfortunately. Any ideas?
                    • umeediqbal80@gmail.com
                      • May 2025
                      Originally posted by Comp_Pro
                      Re: playstation 5 digital firmware dump
                      Here is a firmware dump for CFI-1015A. Note that it must end A. Copied from known working and it helped me fix a PS5 that had 3 beeps as soon as you plugged in the AC cable. I believe the board was originally also going to 30mA and then shutting back down.
                      Upon boot it is now asking me to reset the software, will update to see if software reset/update will work.
                      Hello, will this work for PS5 disk version?
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1226
                        • France
                        #191
                        The name of the dump ends with .BIN but must be .bin for the PS5 NOR Modifier.
                        I've modified the Windows application to allow all extensions: .Bin /.BIN /.iso /.rom etc....
                        If this helps, please test and give me feedback.
                        I don't work on PlayStation.
                        If this bothers TheCod3r​ or the forum administrators
                        Please delete it.
                        • Jacksoft
                          • Feb 2011
                          • 34
                          • Italy
                          #192
                          Check what southbridge is on your cfi-1216a edm-030
                          After start, check if WiFi is working and showing its MAC in system infos.
                          Used this on a three beeps PS5 (CFI-1216A, EDM-033, CXD90069GG):
                          - Dumped original BIOS and extracted the SN and MB SN.
                          - Written on your BIOS SN and MB SN with The Coder cmd tool.
                          - Console starts! But LAN MAC address is different! (WiFi seems the same?).
                          - Replaced both MAC addresses in the new BIOS.
                          - Three beeps again. (Tryed also with another tool and same result)
                          Only works with JUST the SN and MB SN replaced. Why!?
                          Any suggestion? Could this affects online, PSN, etc?
                          • Cobbes
                            • Mar 2024
                            • 26
                            @Maxpower3: Nice. Thanks a lot. My dumps are saved as .BIN and till now I had to rename them in .bin to use TheCod3r's tool. Your modification is very handy.
                            @ Jacksoft: So, if you use the donor dump replace just the SN and MB SN, the PS5 starts. If you replace also the MAC for LAN and WiFi you get three beeps? Interesting.
                            Btw: If you have initial three beeps with the original NOR, please clear error codes and check if it is solve the 3BOD problem.
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1226
                              • France
                              #194
                              For the WiFi Mac address, did you notice that it's written three times? With +1 and +2.
                              Click image for larger version  Name:	Nouveau Image bitmap (4).png Views:	0 Size:	375.4 KB ID:	3639083
                              Edit
                              Click image for larger version  Name:	image.png Views:	0 Size:	31.0 KB ID:	3639088
                              • Fenerlee11
                                • Nov 2016
                                • Türkiye
                                #195
                                i need edm 020 cfi-1116A bios for no power 3 beeps
                                • Jacksoft
                                  • Feb 2011
                                  • 34
                                  • Italy
                                  #196
                                  Edit
                                  Ah!
                                  Yes I noticed that but I completely forgot about bluetooth! So it could be because a mismatch!?
                                  I'll try and let you know asap!
                                  • jibril mohammed
                                    way big
                                    • May 2025
                                    • 6
                                    • Nigeria
                                    #197
                                    guys need a good dump for cfi-1216A edm-033
                                    • MIRROR6866
                                      • Jun 2016
                                      • 7
                                      • IRELAND
                                      #198
                                      HI, need help looking for CFI-1216A, EDM-033 CG69 working BIOS. please
                                      • Jacksoft
                                        • Feb 2011
                                        • 34
                                        • Italy
                                        #199
                                        Edit
                                        Fixed all the MACs but still three beeps. I gived up and keeped the old one from the dump. Console boot, goes online, joypad works, disc drive works.
                                        I noticed that WiFi MAC is still the original one and NOT that from the BIOS. Maybe it self-update by reading the chip infos?
                                        • Mason Hamilton
                                          • May 2025
                                          I'm looking for a BIOS dump for a EDM-031, model CFI-1215A, 61GG board — the disc edition
