Identifying badcaps in a Xbox360
  • migu3l
    • Aug 2010
    • 12
    #61
    Re: Identifying badcaps in a Xbox360
    Originally posted by mockingbird
    The MFZ are 2700uf, this will not work. Also where did you get your Rubycon MCZ, not off eBay I hope. If you did, they're fake.
    The MFZ I am replacing are 820uF.
    I got the Rubycon MCZ from this site.
    • migu3l
      • Aug 2010
      • 12
      #62
      Credit to Ikvee who posted earlier in this thread.
      But here is a picture of the Rubycon capacitors I am replacing
      http://img710.*************/img710/1035/xbox36004.jpg
      Hope this helps make sense
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        #63
        afaik mfz is custom and no datasheet exists.
        so try your mcz and check for ripple.if not good enough measure voltage and use polys.i bet mcz are good enough.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          That is correct. I emailed Rubycon and asked.
          Custom and no datasheet. <- That's what they said.
          Also said they are out of production now.
          Mann-Made Global Warming.
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            The larger can is either to lower ESR or improve heat dissipation.
            Regardless, MCZ are known to work.
            - Dr Seuss
            • migu3l
              • Aug 2010
              • 12
              #66
              Ok thanks guys,
              In that case i'll try them out see how it goes.
              • mockingbird
                • Dec 2008
                • 5484
                #67
                As someone stated earlier, MFZ is just ROHS-compliant (lead free) MCZ. The entire xbox360 is lead free, due to retarded politics. I don't see how this affects any children other than those Chinese who put the xbox together in the factories, and those who take them apart in the scrap yards.
                Miguel, go ahead and replace them with what you have. The MFZ is most likely only taller because of a special request from Microsoft, or to compensate for the absence of lead. What you should have done is replaced them with polymers since they are available at that spec I believe.
                  • 31246
                  lead (and mercury, berilium etc) effect people who live near landfill sites and incinerators,
                  only a very small percentage of electronic waste gets "recycled" in china - most goes in the waste like everything else.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    #69
                    much of it is open burned or dumped on the ground.
                    "recycling" is the removal of parts that will bring a few cents each before the rest is dumped.look at some of the youtube vids.
                      • 31246
                      that's why i put recycled in quotes,
                      but what i mean is that domestic electronic waste just goes to the local tip, it's only industry that disposes of stuff through "proper channels"
                      that old tv you see by the side of the road wont get any closer to china that a local takaway.
                      • Player2
                        • Aug 2009
                        • 98
                        Sorry to bring up an old post, but I ran across this thread in a search. The Rubycon MFZ in question is not simply a lead-free MCZ replacement, MCZ is already RoHS compliant. MFZ is actually lower ESR (7mΩ for 2700uF @ 6.3v) than any MCZ. There is no MFZ datasheet, but if you scroll down to page 8 (or just search MFZ) in this document you'll see the ESR rating:
                        AFAIK, the only 'lytic that can touch those ESR numbers is Nichicon HZ. I'm certainly not saying MCZ won't work, just trying to share some info I spent a good deal of time tracking down. I ran across a couple of these MFZs on a Dell XPS mobo oddly enough.
                        Anyone done a full poly mod on a 360 yet?
                        • mockingbird
                          • Dec 2008
                          • 5484
                          #72
                          Thank you. I was also starting to second guess this, and was genuinely curious what MFZ really was. I wonder if they use precious metals inside the electrolyte to get it that low.
                          If someone can find out what is the VRM on the 360 and what isn't (I'm particularly interested in the Xenon), it could be modded. My Xenon, and othermodels also have polymer caps already on the VRM, but if there's a chance that there's a capacitor on the VRM that's not polymer, it has to be replaced with half the capacitance. And capacitors that are not in the VRM have to be replaced with full capacitance. The MFZs are 2700uF, so they can't be replaced unless they're on the VMR circuit, because there aren't any polymer capacitors at that high a level AFAIK.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            I emailed Rubycon about MFZ.
                            They said it was a custom ordered cap and they don't have any data sheets for them.
                            - Dr Seuss
                            • xboxhaxorz
                              • Jan 2011
                              • 196
                              #74
                              im soooooooo glad i found this forum, hopefully i can figure out why this xbox wont turn on now
                              • mockingbird
                                • Dec 2008
                                • 5484
                                #75
                                Why, did you try the "oven trick"? Oven trick is good for components with no thin plastic AFTER you have removed the electrolyitcs. You don't wrap it with a scarf and tinfoil, you strip the board bare, unsolder the capacitors, and then reflow it in the oven.
                                I don't recommend this with a 360.
                                • TheLaw
                                  • Jan 2011
                                  • 477
                                  #76
                                  Bummer
                                  • corrize
                                    Best way to solder LVDS connector for beginner (and qfn) ?
                                    by corrize
                                    Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                    I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                    I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                    See the test :
                                    https://youtu.be/bNAzC-EvqHs?t=1767
                                    With hot air from bellow the board, that's...
                                    03-09-2023, 02:57 AM
                                  • petemanuk
                                    BGA solder balls not connecting - help pls
                                    by petemanuk
                                    So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                    I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                    I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                    11-16-2022, 05:21 AM
                                  • myth77
                                    UV solder mask - high temp resistent, recomendation?
                                    by myth77
                                    Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                    Is there any solder mask...
                                    03-28-2022, 04:04 AM
                                  • acedogblast
                                    by acedogblast
                                    11-02-2024, 05:13 PM
                                  • sircastor
                                    Solder not reflowing - what am I doing wrong?
                                    by sircastor
                                    I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                                    For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                                    03-03-2024, 02:44 AM
