Identifying badcaps in a Xbox360
  • Toasty
    • Jul 2007
    • 4171
    #41
    Re: Identifying badcaps in a Xbox360
    What model is the system? Age?
    MCZ is typical in these nowadays.
    HZ is also typical. HZ(M) is the proper marking and should be under the (-) negative stripe and above the H0732.
    If yours has the yellow Fujitsu 820uf/4v, and you managed to damage them, you've really gone beyond the extreme in roasting. BBQ anyone?
    veritas odium parit
    • migu3l
      • Aug 2010
      • 12
      #42
      It was manufactured in 2007. Its not the first gen model because it has HDMI, but its fairly old.
      I don't have 820uF/4v caps, only nichicon and rubycon 820uF/6.3v. I only damaged the ones around the CPU (4 of them are buldged, another 4 have leaked and 4 of them have looked like it had a volcanic eruption). I had the heat gun on for 4-minutes, which seemed long but I blindly followed the YouTube guide anyway.
      Normally I would just give up and buy a new Xbox, but I live in Australia where its a PAL region. I got my system from the states and have some games with it already. On the plus side it seems like a good learning experience.
      • Toasty
        • Jul 2007
        • 4171
        #43
        OK. They changed the Fujitsu's for Rubycon's.
        Heat gun method requires a ~carefully~ cut-out, 2 layer aluminum foil shield that blocks everything the chip(s). If you just blasted away without the shield, there's the problem. Same happens with the "oven-bake" method. Just put the new caps and you should be in good shape. Until it RRODs again...
        Look into building the foil air tunnels that channel the fan draft over the GPU and CPU. Also consider investing (~$25) in the newer GPU heatpipe style cooler that places a second coil in front of the CPU cooler airflow. A fan upgrade to the Talismoon LED fans (just the regular ones, not the Turbo-switch style) is $20 well spent. A 60% increase in air volume without an increase in noise level (actually a 3dB decrease) is nice too.
        There are loads of mods out there. Some make sense, some are a waste of time. YMMV
        Toast
        veritas odium parit
        • Toasty
          • Jul 2007
          • 4171
          #44
          EDIT:
          ...foil shield that blocks everything but the chip(s).
          veritas odium parit
          • migu3l
            • Aug 2010
            • 12
            #45
            Toast
            Thanks Toast
            I'll look into the other mods, I have a Talismoon on its way and Ill try the aluminum shield duct.
            When I heat gunned I did cover the caps with foil, although I just threw a sheet over it rather than securing it properly. I really rushed it because I wanted to get the thing fixed already.
            • mockingbird
              • Dec 2008
              • 5484
              #46
              I was looking to replace the yellow Fujitsus in my Xenon with equivalent Sanyo Oscons. Are the Fujitsus already Polymer eventhough they have a K-Vent?
              Also, the 2700uf Rubycon MFZ... What would you guys recommend replaceing them with as this value is a little out of the ordinary.
              • Toasty
                • Jul 2007
                • 4171
                #47
                Yes,they are. Fujitsu FP caps are now under Nichicon branding.
                Nichicon HZ, Ruby MCZ, Nichicon HN.
                Or, you go nuts and poly the entire board.
                veritas odium parit
                • mockingbird
                  • Dec 2008
                  • 5484
                  #48
                  Good, so I don't have to worry about replacing those. They're all near the GPU which gets very hot. The Rubycon MFZ are 6.3v 2700uf. I can't find anything with that value that low ESR on Digikey.
                  Which polymer caps would you recommend?
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Originally posted by mockingbird
                    Are the Fujitsus already Polymer even though they have a K-Vent?
                    Sorta.
                    They are "Functional Polymer" as opposed to "Solid Polymer".
                    They've pretty much kept what "Functional Polymer" is a secret [trade secret I guess] so the need for the vent unknown.
                    The early versions [made before 2003-ish - guessing] occasionally had problems where moisture from the air would slowly leak -in- and cause minor bloating but since then the seals have improved.
                    That may have been the only reason for the vent as the very new ones don't have vents anymore.
                    [I've replaced bloated ones on boards made in 2000-2001 and seen them on boards made from the late 90's thru 2001-2002 or so.]
                    There is no performance difference or known longevity difference between them and actual solid polymer anymore.
                    Just consider them the same as solid polymer.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      http://www.mouser.com/ProductDetail/...mZ8C%252bg8%3d
                      - Dr Seuss
                      • mockingbird
                        • Dec 2008
                        • 5484
                        #51
                        Ah, these are Nichicon HZ... But do you know what polymer series would be a suitable replacement? Also how do HZ compare to UCC LXZ or LXY?
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          To compare caps look at ESR and Ripple
                          https://cdn.badcaps-static.com/pdfs/...43c4079d93.pdf
                          ESR - Less is better [may say Impedance in data sheet vs ESR]
                          [ESR is *like* a caps resistance to Ripple. Since these caps job is to pipe Ripple to the ground plane less 'resistance' to Ripple is better.]
                          Ripple - More is better
                          [Ripple rating is *like* a caps watt rating. - Tells you how much ripple it can handle without overheating internally. - Kind of like a measure of how heavy duty it is.]
                          Look at data sheet for the 2700uF HZ:
                          ESR = 7 mOhm @100kHz [or 0.007 Ohm @ 100kHz]
                          Ripple = 3770 mAmp @ 100kHz
                          [This is a very high grade of low ESR cap.]
                          Now go look at ESR/Ripple for LXZ & LXY.
                          These are much lower grades but still good brand and low ESR.
                          Digikey has none for poly that size.
                          Mouser just crashed. Can't check there on poly.
                          If they have a 2700uF 6.3v poly you may have to give up your first born son or a body part to get some.
                          - Dr Seuss
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Mouser is back. - All they have in poly @2700 is a 4v.
                            You would have to check actual voltage in all system conditions.
                            If it never goes over +4v [including Ripple] then the poly would work.
                            http://www.mouser.com/ProductDetail/...nyKaom4Q%3d%3d
                            - Dr Seuss
                            • mockingbird
                              • Dec 2008
                              • 5484
                              #54
                              Hmmm. Nichicon LG. Looks good. I would be comfortable replacing with 4v . Next time I open it up for the JTAG. I want to hack the NAND to modify the I2C default fan settings. Thanks.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                You need to check the volts in the circuit.
                                Good chance it's a 5v circuit and that will toast a 4v cap in no time.
                                - Dr Seuss
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  #56
                                  Ok, I will try and ask around on the xbox-scene forum. They've a hardware mod section but oddly enough, I've never seen anyone attempthing a poly mod. Especially on Falcons, they don't even have the Fujitsus around the GPU but Nichicon HN!!! (Yes I know HN is good after '05/'06)
                                  • migu3l
                                    • Aug 2010
                                    • 12
                                    #57
                                    Hey guys,
                                    I just received my replacement caps from badcaps.
                                    However they are significantly smaller in size to the original damaged caps.
                                    By significantly, I mean nearly half the size of the original ones.
                                    The specs are same but is it suitable to replace the damaged capacitors?
                                    Cheers
                                    • mockingbird
                                      • Dec 2008
                                      • 5484
                                      #58
                                      What did you order and what are you replacing?
                                      • migu3l
                                        • Aug 2010
                                        • 12
                                        #59
                                        Hi mate,
                                        I ordered the Rubycon MCZ series 820uF 6.3V.
                                        They are to replace the current ones which are Rubycon MFZ and nichicon capacitors both 820uF and 6.3V. However the current ones are around 22-24mm in height and around 8mm in diameter.
                                        The MCZ capacitors I recieved are only 12mm in height and the same diameter
                                        • mockingbird
                                          • Dec 2008
                                          • 5484
                                          #60
                                          The MFZ are 2700uf, this will not work. Also where did you get your Rubycon MCZ, not off eBay I hope. If you did, they're fake.
                                          • corrize
                                            Best way to solder LVDS connector for beginner (and qfn) ?
                                            by corrize
                                            Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                            I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                            I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                            See the test :
                                            https://youtu.be/bNAzC-EvqHs?t=1767
                                            With hot air from bellow the board, that's...
                                            03-09-2023, 02:57 AM
                                          • petemanuk
                                            BGA solder balls not connecting - help pls
                                            by petemanuk
                                            So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                            I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                            I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                            11-16-2022, 05:21 AM
                                          • myth77
                                            UV solder mask - high temp resistent, recomendation?
                                            by myth77
                                            Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                            Is there any solder mask...
                                            03-28-2022, 04:04 AM
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • sircastor
                                            Solder not reflowing - what am I doing wrong?
                                            by sircastor
                                            I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                                            For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                                            03-03-2024, 02:44 AM
