xbox 360 HDMI to VGA pinout
  • katzcaps
    • Feb 2012
    • 48
    We want to attempt an xbox connection to a new tv using the vga input on the tv as a test to try to eliminate input lag that is occurring while using the component or HDMI input.
    Does anyone have a good diagram for an xbox 360 HDMI to VGA pinout? I've searched online but cannot really find a good, easy to read pic.
    Thanks in advance!
    Edit: Also, can you make a direct connection with this method? I've read conflicting stories on the net that it will work fine, and other s saying that you need a special adapter with circuitry in it...
  • diif
    • Feb 2014
    • 6978
    • England
    Re: xbox 360 HDMI to VGA pinout
    There needs to be some circuitry involved as HDMI is digital and VGA analogue.
    http://www.videk.co.uk/article.php/1...to-vga-problem
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      HDMI to VGA cables exist but don't work. You need an active converter not a passive cable.
      • katzcaps
        • Feb 2012
        • 48
        Thanks for the info., guys. After more research I have come to realize that we need active circuitry. At this point we are looking at a gizmo, the HDFury.
        http://www.hdfury.com/shop/gamer/hdfury-gamer-edition/
        Supposed to be popular with gamers who experience HDMI /input lag issues with the new LED tv's.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          careful, M$ might try to put you in the graybar hotel for screwing with your hardware
          Follow the white rabbit.
          • lti
            • May 2011
            • 2548
            Why wouldn't they allow an HDMI to VGA converter?
            There are cheaper converters, but I don't know how well they work. I've heard that the really cheap ones require ridiculous power supply current (close to 400mA), which could damage the video source since that power comes from a pin on the HDMI connector that is only meant to power low-current devices (less than 100mA).
            • mmartell
              • Oct 2013
              • 3189
              Because no HDMI means no HDCP even though that's hardly been a problem for those bent on circumventing that protection.
              • diif
                • Feb 2014
                • 6978
                • England
                Have you been through the settings on the tv ? turned off things like motion and tried the game mode ? /
                • katzcaps
                  • Feb 2012
                  • 48
                  It's a real crap-can tv
                  Seiki SE60GY24 - They got a good price on it, but it ends there. The pic isn't really all that great, but is okay...I guess. The blacks aren't very crisp like I would prefer. And, as far as settings go, they are virtually non-existent; No "Game mode" setting. There is a "user" mode and we scaled everything back to almost zero and it had little effect. Toggled off any acceleration that we could find, basically dumbed it down as much as possible, which as I mentioned the settings aren't very versatile at all.
                  As of now we purchased a MSoft cable, HDMI to VGA and are crossing our fingers. This tv was purchased online and a return is out of the question, as return ship is almost $170. So we gotta try to make this thing work somehow - or pawn it on craigslist maybe...
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Fingers crossed for you that the adapter works. It sounds like you've adjusted the tv as much as you can. I recently went on a job where the customer reported PS3 lag. it wasn't the TV but the second hand PS3 they had just bought. They got a replacement PS3 and there was no more complaints.
                    • katzcaps
                      • Feb 2012
                      • 48
                      We've been all through the xbox 360 settings as well, scaled it back to 720, etc. The xbox performed fine with the prev. 60" Sony LCD tv they had, which is something like a 2003 model. It's funny that when you buy the latest greatest thing you seem to always end up taking a step backwards in functionality.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        i would imagine hdcp is not an issue.those adapters spoof what they are to seem compatible.
                        like hdcp stops piracy anyway!
                          • 31015
                          http://www.ebay.co.uk/itm/131150082612
                          • luke10050
                            • Mar 2013
                            • 209
                            why not get an xbox VGA cable?
                              • 31015
                              ever seen one?
                              • katzcaps
                                • Feb 2012
                                • 48
                                Update - the HDMI to VGA cable solution was not a good one. The picture quality is quite unacceptable and the improvement in lag time is barely noticeable.
                                So for now we are going with the HDMI input and living with the lag. This is an expensive lesson to learn;
                                Unless you read a ton of reviews (and how do we really know how accurate they are?) how can one make a good decision on a LED HDTV that will not have this input lag situation...
                                It would appear that one the HDFury gadgets that I linked to earlier would actually work, but they are several hundred dollars, so in the end it would make more sense to purchase a higher quality tv instead of using that add-on.
                                  • 31015
                                  the lag is probably in the tv, if it delays the audio for the same level of time to get sync, most people wouldnt know there even was a delay.
                                  • katzcaps
                                    • Feb 2012
                                    • 48
                                    Yes, it is in the tv; we know that (I guess I should have posted that in my initial post)
                                    Apparently this is a common problem with gamers, hdtv's, and hdmi input. most noticeable when using an xbox with a first person shooter game.
                                    Honestly, I personally cannot notice any different or issues at all when compared to the previous tv, but the experienced gamer notices the lag and is complaining about it.
                                    • luke10050
                                      • Mar 2013
                                      • 209
                                      ever seen one?
                                      yes, i own one. its an official microsoft accessory.
                                      http://www.xbox.com/en-AU/Xbox360/Ac...x360vgahdcable
                                      • TMTGTR
                                        An Xbox One PSU Odyssey
                                        by TMTGTR
                                        Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                        =>Background:
                                        I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                        06-17-2022, 05:40 PM
                                      • Eniaro
                                        Xbox series X HDMI
                                        by Eniaro
                                        Can anyone recommend a reliable Amazon source for the Xbox series X HDMI port?
                                        My recent order came with plastic legs
                                        Also if it's on Mouser I'm ok with that too
                                        09-10-2023, 04:40 PM
                                        HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                        This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                        09-12-2024, 02:00 PM
                                      • japlytic
                                        Certain DisplayPort-HDMI cables can disable HDMI CEC communication
                                        by japlytic
                                        With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
                                        An examination of the HDMI CEC wiring...
                                        07-10-2022, 09:48 PM
                                      • spleenharvester
                                        Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
                                        by spleenharvester
                                        I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
                                        I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
                                        03-12-2025, 03:42 PM
