Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
This topic has been answered.
  • spleenharvester
    • Mar 2010
    • 921
    I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
    I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • Answer selected by spleenharvester at 03-21-2025, 09:36 AM.
    spleenharvester
    • Mar 2010
    • 921
    I need to wait longer to be sure but I think I have actually figured this out - software problem related to the WiFi. It's hard to tell exactly what is happening with the lack of date/timestamps in the log dumped to USB, but it was getting spammed full of this
    Code:
    [1;37;41mcheck [0/1] COM.NVT.PRIVSERVER[0m[30;41mICE_WIFI ERR : [0m[1501]ice_WiFi_MTK_ScanAp():Retry over 20 times, scan time out
        > ecl/wificontroller: Scanning access points.
    [0mICE_WIFI_WAR : [0m[2421]ICE_WiFiConnectAp():create monitor task!
    [0mICE_WIFI_WAR : [0m[2432]ICE_WiFiConnectAp():[END] ret=1
        > ecl/wificontroller: ret: 1​
    Followed by messages like this
    Code:
    [1;37;41mcheck [0/1] COM.NVT.PRIVSERVER[0mcat: write error: No space left on device
    It occurred to me one thing I did when I enabled CEC was factory reset the TV and connect to WiFi to check for updates, which I hadn't done previously. When I went to check the WiFi settings in the GUI I noticed it was just hanging repeatedly trying to connect to my router, which was bizarre as the credentials were 100% correct. We run a PiHole on our network, and as soon as we temporarily disabled blocking it connected no problem. My best guess is that it was trying to phone home to an address on my PiHole blocklists after authenticating to check internet was connected, and when it couldn't do that it would just try and do it over and over again until it ran out of memory. It would also explain why the reboots were always spaced about 2 hours apart and never in quick succession. Interestingly I also noted in the log files that it seems this model actually can't authenticate with the software upgrade server properly because of having no date/time setting. It defaults to 01/01/2021 whenever it's powered up, and tries to get the update file from an AWS address. If you enter that address into your browser it tells you access denied because the token expired on 01/01/2021.
    Anyway I disabled networking entirely and it's been running for about 8 hours without any problems. I'll update this post if it is definitely fixed.
    • spleenharvester
      • Mar 2010
      • 921
      Update, it is still restarting with CEC and ARC disabled. I am starting to think it happening at the same time as replacing all the cables was just a coincidence, and that the TV is actually kaput. It's now restarting about half a dozen times per day, every couple of hours ish. There's no abnormalities displayed at the time it does it, it's literally just as if someone turned it off and then straight back on again.
      Before I replace the PSU board, any ideas on what I can try/check? All components on both the PSU board and the mainboard look physically OK.
      • nomoresonys
        • 12307
        • U.S.
        Can you just try a simple antenna with over the air, unhook all other hdmi etc, see if it still does it.
        • spleenharvester
          • Mar 2010
          • 921
          Unfortunately our roof antenna hasn't worked in a long time lol
          I found last night that somehow the TV turned HDMI-CEC back on by itself so I've turned it back off again, will wait and see if it resolves it. I've also ordered a PSU board as managed to get a working one for £8 delivered. Even if it turns out the board is fine it probably doesn't hurt to have a spare, it's an old set.
          • nomoresonys
            • 12307
            • U.S.
            A spare is never a bad idea, you can use just an old piece of coax with a stripped end where the wire is exposed a little for an antenna just to get a nearby station, just for checking, will probably work if towers aren't too far away.
            • spleenharvester
              • Mar 2010
              • 921
              Will pick up one of those mini coax antennas to test with I think. I just changed the HDMI cables and all the settings back to what they were before I started messing with HDMI-CEC and it is still rebooting, so I am now fairly sure it is a coincidental hardware problem. I might recap the new board while it's out on the bench too.
              Can anyone think of a particular reason why, on UK 240V mains, I would need a 200V cap on the isolated side? There is a 200V 56uF 10x20mm capacitor and I am struggling to source a replacement... I can only find 50V 56uF. If that won't suffice I might just have to leave that one alone. (Edit, it looks like the 65" version of this TV came with two 47uF 200V caps in place of that 56uF 200V cap, so I might be able to do that instead?)
              • nomoresonys
                • 12307
                • U.S.
                47UF should be ok, you just never want to go with less voltage so 200 or a little more like 250 or so is fine.
                • spleenharvester
                  • Mar 2010
                  • 921
                  Ok thanks I'll get some on order,
                  I've enabled USB logging through the service menu (home -> 4725) and left it running until the TV reboots. From the first attempt there are a few suspect lines suggesting it is trying unsuccessfully to install an update but it is mostly just verbose noise, and the TV has no date/time setting so there's no clear indication of what is happening when.
                  I've found the 17MB230 schematic, am I correct in thinking TP254 and TP255 on the Novatek NT72671TBG IC are the UART pads? Wondering if I could get better information with an RS232 connection
                  • spleenharvester
                    • Mar 2010
                    • 921
                    Code:
                    Code:
                    • nomoresonys
                      • 12307
                      • U.S.
                      Well done, very nice detective work, glad to see you solved it.
                      • spleenharvester
                        • Mar 2010
                        • 921
                        Cheers :-)
                        Three days and no reboots with HDMI-CEC and HDMI-ARC re-enabled too, so confident it is fixed now
                        • spleenharvester
                          Toshiba/Vestel 50UL2063DB rebooting whenever it feels like
                          by spleenharvester
                          We've had this one about 4 years now, for the past year or so it's been rebooting roughly once a week. Always in the middle of playback from an Xbox Series S. Not sure if hardware or a software configuration issue as we changed our setup a while ago.
                          I've tried putting the latest firmware .bin on a FAT32 formatted 4GB USB2 stick, 28617342_MB230_TOSHIBA_QUI_KYLO_V051300_SVN_328380, which I am 95% sure is the correct file. I then tried all the usual Vestel tricks (plug in USB stick, unplug TV, plug in TV while holding OK and/or power button). No response, it just boots straight to the...
                          06-18-2024, 10:51 AM
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • zen
                          KDL46W905A , randomly rebooting . Latest upgrade & advice please.
                          by zen
                          Hi all
                          Self check came up with 61 errors logged for HOST-WDT . Anyone know what this means ? Cleared by typing 80 whilst on self check page .
                          Carried out a factory reset , which has resolved issue for now , but not sure long term .
                          Current software PKG4.600EUA . Is the latest version .
                          Has been to another engineer before me . Suspect they may have tried factory reset , as customer mentioned it lasted 2 weeks before rebooting again .
                          She started noticing issues after connecting Chrome cast , unless that's pure coincidence...
                          07-19-2022, 06:09 AM
                        • pcwhiz24
                          Lenovo IdeaPad 3 14ADA05 NVME keeps randomly disconnecting
                          by pcwhiz24
                          This issue has me stumped! I have this Lenovo IdeaPad and the SSD (NVME) keeps on randomly disconnecting. It'll stop being detected in BIOS randomly and when I turn it off and back on sometimes it'll detect again and boot up just fine...only to crash after a few minutes and either boot again or stop being detected.
                          Things I tried so far:
                          - Reset the CMOS by removing battery, held power buttons 60 seconds, all that jazz.
                          - BIOS is fully updated (had to use CHA341 because I bricked it the first time trying to update it)
                          - Tried multiple working NVME drives...
                          04-08-2025, 06:59 PM
                        • plytek
                          Samsung QE50Q60TA rebooting
                          by plytek
                          Hi all.
                          I'm trying to fix my Samsung QE50Q60TA TV.
                          IT's rebooting every few seconds.
                          I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
                          Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
                          Can anyone suggest what I can test and do to get it working again please?...
                          02-08-2025, 06:02 AM
