Certain DisplayPort-HDMI cables can disable HDMI CEC communication
  • japlytic
    • Oct 2005
    • 2086
    With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
    An examination of the HDMI CEC wiring in a number of TV service manuals revealed that the CEC line (a single open collector bidirectional signal) is common to all HDMI inputs which meant that the particular DisplayPort-HDMI cable was sinking the CEC line thus disabling CEC functionality.
    So I used a variable angle HDMI adaptor (which the housing can be easily opened) with the CEC line cut for the home theatre PC which fixed this problem.
  • japlytic
    Certain "Class 2" HDMI cables can be marginal at 4K 60 Hz
    by japlytic
    For some time, a "Class 2" HDMI cable (part number BN39-01583B) supplied with a Samsung 4K 60 Hz display sometimes causes the display to overlay a few horizontal lines of flickering pixels of random colours and sometimes drops out, particularly on content requring HDCP.
    Since changing the cable to a thicker Class 2 unit, this problem has not occured again - do you know of other marginal "Class 2" HDMI cables supplied with displays?
    09-06-2023, 08:50 PM
  • RatherLoopy
    Pioneer VSX-44 receiver HDMI dropouts
    by RatherLoopy
    I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
    I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
    And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
    05-26-2023, 03:54 PM
  • RossMoodley1967
    LG LCD TV HDMI PORT FAULTY
    by RossMoodley1967
    LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
    02-28-2024, 08:38 AM
  • Wittie
    Philips 55OLED803/12 HDMI ports "half" defective
    by Wittie
    Hello everyone, Please excuse my poor English, but I'm using Google Translate ^^ I'm having a problem with the HDMI and USB ports on my 55OLED803/12. It's no longer possible to connect an HDMI device and see the picture. No matter which port I use, it only recognizes the device as an input source and displays it in the list (BD player, Fire TV, etc.). However, the actual picture doesn't appear in the same state. My home theater system also runs via the BD player - it still receives a signal and plays the sound correctly (e.g., from the TV program or an app like Netflix). This works with both HDMI...
    03-19-2025, 09:38 AM
  • brotank
    Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
    by brotank
    I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
    can someone disable onboard ram from my dumped bios, please 🙏
    I tried the other bios on this forum with disabled onboard ram, but no success
    my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
    after that I officially give up 😂
    thanks for awesome jobs 😊...
    03-16-2025, 12:51 PM
