XBOX Original - Won't power on
    • 30979
    Re: XBOX Original - Won't power on
    these need to be very good caps,
    next time i do an xbox i will try a polymod - previously i used MBZ or MCZ.
    • Relayer
      • Nov 2017
      • 35
      • Earth
      Hey guys,
      I spent a few years installing modchips and repairing original X-Boxes, under my old Forum name of "Darkmatter".
      I used to post regularly on the now gone llamma.com Forum.
      When replacing the clock capacitor, make sure you check the surface of the main board where the cap was situated. Nine times out of ten it will have leaked. You need to clean that area thoroughly, with isopropyl alcohol or methelated spirits.
      Have a very close look at the tracks coming from the clock caps mounting holes to see if any of the tracks have been corroded. Use a magnifying glass or similar with good lighting when you check it out.
      If you do find tracks eaten, then you will need to repair the tracks.
      The cap can be replaced with a super cap as shown in the link below:
      [URL=http://www.jaycar.com.au/22f-2-5vdc-super-capacitor/p/RE6702[/URL]
      Once again: "Insert Link" option not working properly.
      If you're not living in Australia you can try Mouser or EBay. But make sure its rated voltage is 2.5 volts. You could use a 3V one, but nothing higher.
      I found that the X-Box, after using the 22F cap, allowed it to keep its clock for over 3 weeks with the X-Box unplugged entirely.
      If you do replace it with a higher capacitance cap, you may need to lay the cap on its side, and bend the leads accordingly for it to fit below the drives.
      I have found many common faults with X-Boxes, but overall thay were pretty reliable performers.
      Some faults and preventative maintenance issues I've listed below:
      (1) The two pin mains input socket on the PSU was extremely notorious for cracked and dry joints. You're best off re-soldering them regardless if you've never had any problems with this issue.
      (2) The varistor close to the mains input socket was also a major problem.
      The varistor was either blue or tan in color depending upon the version of the PSU.
      The picture below shows the destruction of the mains fuse and varistor when it decides to let fly:
      X-Boxes have been known to catch fire due to the varistor self destructing, so if you ever have to replace one, make sure you encapsulate it with heat-shrink tubing. It will keep the flame out within the heat-shrink and not blacken any other components nearby.
      It was strongly suspected that the varistor's internal molecular structure changed every time it copped spikes and other transients, therefore it reached a point that it was no longer doing its job and explodes due to it shorting out.
      This fault was more prevalent on X-Box PSU's that had the faulty joints on the mains socket.
      The replacement type was: JNR 14D241K Though my replacements were made by JNR, you can source elsewhere provided you use 14D241K as your reference.
      One last thing: Most spike suppression power boards and other PSU's, especially the cheaper Chinese ones use varistors and they are also prone to the molecular change within the device. It makes it worse if you live in a country, province or town where the mains voltage is not well regulated.
      Unfortunately switch-mode power supplies in nearly all appliances contribute to the mains problems.
      (3) Another fault is being described in this thread. Caps bulging on the motherboard.
      New caps should be rated at 10WV, working temp rating of 105º and MUST be low ESR high ripple types such as: TX or WL-R Series caps
      (4) On earlier versions of X-Boxes, there was a problem of corrosion found on two particular spots on the motherboard. This corrosion was caused at the factory, and over time, corroded even further until the motherboard failed. Versions that were affected: V1.0 to V1.3. No later versions were found with this issue.
      Here are the symptoms due to corroded tracks:
      (a) The X-Box fails to power down using the power on/off button on the front panel. The power cord has to be pulled out to shut it down.
      (2) As soon as the power cord is plugged in, the X-Box powers up without pressing either the on/off or eject buttons.
      (3) While the X-Box is on for a certain amount of time, it shuts down by itself for no reason. The time factor before shut down can vary wildly.
      The only fix for this is to bypass the affected tracks using Kynar wire.
      If anyone needs help in this regard, then please PM me with your email addy and I'll send them my tutorial on how to wire things up and at what points.
      Other tutorials:
      * Varistor repair
      * Voltage change: From 110V AC to 240V AC and vice-versa (Not all versions of PSU's).
      * Version 1.6 PSU SMD transistor equivalent replacement
      * Headphone amplifier creation and installation
      * Version 1.6 "No Video" fix
      * I used to have a hard disk drive activity LED tutorial but can't find it at the moment. I'll post it up if I find it
      * I also had a tute to install color changing LED's within the ROM drives when ever the tray was open. It looked like fireworks were coming from inside the drive. I'll have to look for that as well.
      Any questions regarding the original X-Boxes can you please put into the Forum discussion and not via a PM. Thanx.
      By the way, I had extremely limited experience on X-Box 360's and any others manufactured after the original ones stopped production. Therefore I have little or no info I can share with you.
      Regards,
      Relayer
      P.S. Sorry for the long arsed post...
      • tudrojopsi
        • Nov 2017
        • 9
        • Israel
        Originally posted by Wester547
        Higher ripple current is better, and lower ESR is also better in this case. You would ideally keep the capacitance and voltage ratings the same. These would work fine as replacements.
        Thanks.
        What about impedance? Lower is better?
        • tudrojopsi
          • Nov 2017
          • 9
          • Israel
          Originally posted by Relayer
          Hey guys,
          So, you're saying I'm better off replacing my bulging 3300uF 6.3V caps with new 3300uF 10V caps rather than new caps with the original 3300uF 6.3V rating?
          Is ESR=Impedance?
            • 30979
            upping the voltage wont harm it - choose based on price etc.
            and yes ESR / Impedence can be considered the same when reading datasheets.
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              #26
              Originally posted by tudrojopsi
              Thanks.
              Impedance is the vector sum of capacitive reactance, inductive reactance, and ESR, which is nearly identical to ESR at the switching frequency of a motherboard CPU buck regulator. So lower is definitely better (in this case).
              Of course upping the voltage rating won't harm anything, but generally the case size becomes larger as the voltage and capacitance rating of a capacitor increases and vice versa. These Xbox motherboards were silkscreened for 10mm diameter capacitors in the CPU VRM output, so it would help to stick to the original case size (and thereby the original capacitance and voltage ratings). But you could use larger capacitors if necessary (if the lead spacing / pitch would fit).
              1.4 was affected by trace corrosion as well. See here. 1.4 uses the focus video encoding chip instead.
              6.3V is not too low for this application because the Xbox CPU's Vcore voltage is only 1.7-1.75V or thereabouts. It's even safe to use 6.3V on the +5V CPU VRM input of the CPU, although upping the voltage there wouldn't be detrimental, I suppose (but again, on version 1.6 of the Xbox motherboards, that area is too only silkscreened for 10mm diameter capacitors). Again, you could use larger capacitors anyway, although it wouldn't look very tidy.
              Just to clarify: The Nichicon HM capacitors were bulging and leaking on the original Xbox motherboards not because the voltage rating was too low but because they came from a bad batch of that series (with 2002-2004 datecodes in the case of the first Xbox), so all are eventually doomed to failure.
              • Relayer
                • Nov 2017
                • 35
                • Earth
                #27
                Hello Wester547,
                Thank you for clarifying the capacitor issue in regards to its working voltage.
                Though when I used to replace those offending caps, I found that my 10 volt types had the same pitch as the 6.3 volt ones.
                Thank you also for alerting me to the V1.4 trace fix.
                I was not aware of it on that particular version.
                I also never realized that my tutorial landed on another web site. I really thought that when llamma.com went defunct, it would have been lost forever.
                I'm so glad that someone had the sense to relocate it.
                I forgot to mention another fault with the Delta model of PSU's.
                If R901 (22Ω 0.25W Fusible Resistor) goes open circuit, you may find that Q981 (N-Channel MOSFET STD1NC60 [TO-251 IPAK]) has shorted between Source and Drain. Often times Q981 is OK.
                But if keeps blowing R901 and/or Q981, then the Chopper (Switching) Transformer has shorted turns on its primary side.
                This was confirmed when I replaced the faulty tranny with a known working PSU, the faulty power supply fired up with no more issues.
                I hope the above may help some one out.
                Regards,
                Relayer
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  #28
                  It's even safe to use 6.3V caps on the +5V CPU VRM input.
                  Fixed that typo.
                  Wow, it's really rare for transformers to go bad, except for flybacks in CRTs and LCDs. Although I suppose if the transformer becomes saturated due to other components failing that it could happen. It sounds like these faults are with the 240V version of the Delta PSU. There are two versions (240V and 120V) of the PSU (the 240V version has a Passive PFC on the primary side).
                  • Relayer
                    • Nov 2017
                    • 35
                    • Earth
                    #29
                    Hello Wester547,
                    Agree. In all my time in the past when I was working with TV's or computer monitors, I only ever come across one switching transformer with shorted turns. And from memory it was in a Sharp portable CRT telly.
                    Heaps of flyback trannys with shorted turns, even the occasional CRT deflection yoke, but just the one Chopper X-former.
                    True. Though I've had a fair share of 110V versions come through my work bench, but none with a faulty tranny.
                    Admittedly I've only come across three PSU's with this fault, and everyone of them the 240V version, and only the Delta types.
                    You are 100% correct.
                    Though the voltages can be changed to suit either 240 or 110 volt mains supplies.
                    Here's how it can be done:
                    By the way, a few years back I was able to fit a Delta PSU into an X-Box 360 power supply case. I had to mod it a fair bit, and now I use it as a 5V and 3.3V supplement power supply.
                    As you can see, I had to add a small project case to extend it, as it was a fairly tight fit in the 360 case. Plus the small transformer had to be fitted externally for the same lack of space.
                    Regards,
                    Relayer
                    • tudrojopsi
                      • Nov 2017
                      • 9
                      • Israel
                      #30
                      Thanks again.
                      Unfortunately, The badcaps store doesn't have them anymore.
                      I've found the following three caps at digikey - copy and paste the full url:
                      Code:
                      www.digikey.com/products/en/capacitors/aluminum-electrolytic-capacitors/58?FV=fff40002,fff8000a,fff8000b,fff8000c,fff804fb,fff80532,fff80533,fff80010,fff800ed,fff80256,fff80298,fff802a3,fff80008,fff80054,fff80009,1c0003,b8367d,b54000d,b54000e,b540011,b540005,1f140000,mu3300uF|2049,mu10V|2079,mu12V|2079,mu6.3V|2079,mu7.5V|2079,mu7V|2079,mu8V|2079,mu15 mOhms|2080,mu17 mOhms|2080,mu20 mOhms|2080,ffe0003a&quantity=0&ColumnSort=1000001&page=1&stock=1&rohs=1&k=Electrolytic&pageSize=500&pkeyword=Electrolytic
                      or as a link (when putting the full url as a link it gets broken because of some chars in the url):
                      https://tinyurl.com/ycltcatz
                      Are they suitable? If so, which one will be best for this?
                      Thanks!
                        • 30979
                        obsolete info.
                        read this thread.
                        https://www.badcaps.net/forum/showth...t=48951&page=3
                        start at post #53
                        • tudrojopsi
                          • Nov 2017
                          • 9
                          • Israel
                          #32
                          I have a 1.6 board - does it make any difference?
                          Are there really no suitable caps for this on digikey or any other store?
                          How does 5x1000uF replaces 3x3300uF?
                          If I understood correctly, this replacement is done because "Ultra low ESR" caps are needed and are not available anymore.
                          How do I recognize an "Ultra low ESR" cap? Should I only consider the ESR value, or maybe also Impedance or Ripple-Current@Low/High-Frequency or something else? For ESR, how low is "Ultra low"?
                          Thanks.
                            • 30979
                            no difference between boards as long as it has the extra spaces.
                            the original xbox used 5x 1500uf, and poly's are so much better that you can drop the value by a third and still get better performance.
                            ultra-low esr caps, panasonic FL, rubycon MBZ/MCZ or nichicon HM/HN are all VERY low esr, but not made anymore.
                            that's why pc motherboards all use poly's around the cpu now.
                            • tudrojopsi
                              • Nov 2017
                              • 9
                              • Israel
                              #34
                              I have 5 bad 3300uF caps.
                              Please see the below pictures. You can see the bad caps on the top right part of the main board in the first picture.
                              Can you please advise what can I do?
                              Thanks!
                              My board:
                              One of the caps:
                              Other side of the cap:
                                • 30979
                                are they all 3300 / 6.3v?
                                and 10mm diameter?
                                • tudrojopsi
                                  • Nov 2017
                                  • 9
                                  • Israel
                                  #36
                                  and 10mm diameter?
                                  Yes, they are all the same.
                                    • 30979
                                    these around the cpu,
                                    https://uk.rs-online.com/web/p/alumi...itors/8392133/
                                    these for the other 2 if you have 25mm height.
                                    https://uk.rs-online.com/web/p/alumi...itors/7660044/
                                    if you can only fit 20mm then these.
                                    https://uk.rs-online.com/web/p/alumi...itors/1458528/
                                    it's possible you could use the 2000uf polymers to replace all 5, but i'm not sure it's been tried yet.
                                    • Stefan Payne
                                      • 1267
                                      Don't forget to replace the smaller ones in that blown area!
                                        • 30979
                                        btw, keep an eye on the supercap near the ribbon cable - it's gold coloured.
                                        • tudrojopsi
                                          • Nov 2017
                                          • 9
                                          • Israel
                                          #40
                                          @stj & @Stefan Payne thanks very much to both of you.
                                          Sorry to bump this after such a long time, but this website doesn't ship to Israel, and being the procrastinator that I am, I didn't do anything about it in the last 18 months .
                                          I really want to fix it now, though.
                                          Do you have another suggestion for caps that I can order to Israel?
                                          I don't understand what you mean. Can you please explain?
                                          Again, I don't understand what you mean. Can you please explain?
                                          Thanks!
                                          • OriginalDaggers
                                            XBox 360 All Polymer Capacitors
                                            by OriginalDaggers
                                            As the title says, Xbox 360 Polymer Capacitors, replacing all on a Kronos 1 revision board.
                                            I went over a thread here (Xbox 360 with blown caps) and gather some extremely useful knowledge!
                                            If I have things right, I can replace them TO
                                            x9 : 1500uF 16V 10x20mm
                                            TO: 470uF Nichicon FPCAP R7
                                            x2 : 820uF 6.3V 8x12mm
                                            TO: 2.5V 820uF Nichicon FPCAP R5
                                            On this revision, there are other 820uF polymer capacitors for GPU/CPU - I'll be replacing those anyway with the above FPCAP R5
                                            What's a good replacement for the smaller...
                                            This can be anything from game consoles to arcade games to anything else that doesn't really fit into any of the above categories. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
                                            02-20-2024, 12:49 PM
                                          • ohren
                                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                            by ohren
                                            Hello!
                                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                            Measured voltages with no load:
                                            After rectifier diodes
                                            12V: 6.17 V
                                            5V: 5.67 V
                                            Secondary transformer pins AC measurement (really don't know if this says anything)
                                            12V: 2-2.5 V
                                            5V: 1.04 V
                                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                            03-18-2023, 10:33 AM
                                          • tccyo22
                                            Xbox One Original missing 12v enable signal
                                            by tccyo22
                                            Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
                                            Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with...
                                            08-14-2023, 06:06 AM
                                          • bulkchart32
                                            Wanting To Try Something With Extra Capacitors for my original xbox
                                            by bulkchart32
                                            i have a shipment of capacitors arriving friday. i'm wanting to try an experiment where i fill all the cap spots(instead of just the 3 spots) in front of the processors with 3300uf caps to see if the extra power being available to the gpu/cpu help the xbox's performance. my question is, is there any chance that this will damage the xbox? also, has anyone ever tried this before?
                                            10-07-2020, 04:54 PM
                                          • bulkchart32
                                            does anyone have a schemtaic for what circuit each cap is in on the original xbox?
                                            by bulkchart32
                                            i have a 1.1v and i am having issues with faint wavy lines on the screen that i am trying to make perfect so it will be my main xbox.. also have some 1.0v's that are doing it but to a lesser degree. i really don't want to do a full board recap, especially don't want to have to replace those smds, so i want to find which specific caps that filter the video signal. i have already replaced several caps and messed up one of them that caused a dead short(has been repaired). so i really don't want to just do all the caps. plus, those 1.1v boards have a lot of them. i'd really like to just focus on the...
                                            05-16-2025, 07:33 PM
