LGA775 mobo from Acer, with suspicious FJ caps ? The rubber seal is just strange. Could it be counterfeit part ?
Fake Panasonic FJ ?
Re: Fake Panasonic FJ ?
I opened this in Paint Shop and messed with it a bit. The vent marks look correct, and you can see the end of the line of the date code next to the left hand leg.
What is the date code? Roll that cap over a bit more and show the line of numbers & letters in dark red, heat stamped onto it.
Also, that can has a dent in it. It's now probably bad.
Toastveritas odium paritComment
Now OEM's are using counterfeit caps? This mean we are going to have to see if they are not only a good brand, but also not counterfeit?
PS, I have looked at lot of capacitors in electronic service, recovering good ones and replacing bad ones (even good ones do go bad eventually.) This capacitor rubber bung design (circular ridges and flat) is not Panasonic's unique design. The engineering drawings and other photos of geniune panny capacitors of these bungs is correctly Panasonic own.
That flat bung with circular ridges is COMMONLY associated with low quality capacitors. I see this on many funny sounding capacitors as well, including Yublight, etc.
Reason for the specially designed bungs are to stand up the capacitors and sit upright correctly before soldering process, and to vent cleaning solution/allow flushing out cleaning stuff. The low quality capacitors that does not have this design sits flat and trap stuff, which is not great thing to begin with.
Occasionally even a good OEM got caught with fakes. But I know Acer is notorious for not looked at closely to keep cost down. Note the similar models by competitors are bit expensive (around 20 to 150 dollars difference?). That how it is, and I have taken apart Acer equipment (notebooks, LCD monitors, LCD TV, etc.) Signicifent lower quality, not as durable casings, poorly filters on power planes in PSUs and mainboards as such (causes intermittent BSODs, memory corruptions, data losses, etc, not as long life) and not as engineered vs samsung, Toshiba, Sanyo etc.
For this reason I refuse to own Acer stuff. Same with ECS, Biostar, MSI (some are bad, some is good, have to know which) and like as well. Sorry. I had sour discoveries when I was inspecting the pulled mainboards.
Very small value capacitors leads are always pre-formed so they sit proud above circuit boards since the bung is too small to allow this and lead spacing is so narrow that drilled holes on mainboard is not ideal. That is same reasons low quality boards utilize this incorrect practice by sitting those small caps right on circuit board via so small lead spacing drilled holes.
Cheers, WizardComment
May be specially made for acer, though who is the maker of that motherboard?
The purple kind of says ECS, which I wouldn't be surprised if they were fake panny's.
It seems to me that a major manufacturer wouldn't have any reason to end up with fake caps - if they're big enough then they ought to be sourcing from the manufacturer directly. Not saying it doesn't happen but I don't get why it would.Comment
Acer is AOpen. I think they still make their own boards.
They've been into the pretty colors thing for a while now.
Acer/AOpen has always gone cheap. All the way back to 486.Mann-Made Global Warming.
- Dr Seuss
That's the rumor but I haven't seen anything official.Mann-Made Global Warming.
- Dr Seuss
FJ and FL have no publicly [officially] released datasheets.
[I know you know, just sayin' for new people.]
I think those series are intended to be sold only direct to manufacturers [Asus, Intel, Gigabyte, and so on] and aren't sold through normal distribution networks.
I suspect all those seen for sale are the result of over-stock or old-stock buy outs.
- That would at least explain not publicizing the datasheets.
As a side thought.
I don't recall Panasonic ever having a low ESR cap without using gold either as the sleeve or the printing.Mann-Made Global Warming.
- Dr Seuss
I think Soyo was doing that.Originally posted by 370forlifeNow OEM's are using counterfeit caps? This mean we are going to have to see if they are not only a good brand, but also not counterfeit?
On some boards they had silver sleeved OST, Sacon, Evercon, and Capsun branded caps ALL with the EXACT same colors and ALL an oddity in the way the vent stamp was done which suggested they ALL came off the same assembly line.
To further support my suspicion, one [some?] of the boards had silver sleeved caps marked OST RLX in can sizes that don't exist in the RLX datasheet.
Pretty sad when they're counterfeiting OST!
- Dr Seuss
I recently pulled some Panny FJ caps of another Acer Motherboard. they look identical to the caps in the first pictures on this thread, with that same suspect rubber seal. I'm glad I found this thread before I got to re-use them.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
I doubt they are counterfeit, major board manufacturers order in enough quantity they could have Panasonic make the bung different.
Acer has been cheap on some things, but traditionally AOPEN has used some quality caps, for example during the BX era when caps were popping left and right on generics and even Abit's boards, AOpen was one of the few that used a large amount of Sanyo caps... just ignore where the author of the linked article calls them Tantalum as they were std. low ESR 'lytics.
http://www.anandtech.com/showdoc.aspx?i=663Comment
...1 Photo11-20-2024, 08:52 PM -
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
Channel: BIOS Requests ONLY!
by stecosHi everyone!
I happened several times, in the search for help from the web, to consult this very interesting forum.
So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
Having said that I come to the gist of my post on the forum as the title suggests.
For my passion for technology I'm now collecting several... -
by aa10aa10Good day,
I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....-
by Mnawar27Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
I need help to remove it,
thankyou all.
SN; 2FKCA26876...-
- Loading...
