Dell GX620
  • midibob
    • Nov 2008
    • 285
    Dell GX620
    As yet I'm not sure this is a bad cap issue so I'd be interested in hearing anyone's experiences.
    My son works in IT and has told me that a large number of GX620 mobos are starting to fail at his workplace, sometimes visibly ie C329 (next to the cmos battery) is venting (820uF).
    I have only seen one failed board so far which doesn't show any signs of distress. The ESR of the caps, in circuit, looks OK of the 820 and larger ones that I've checked so far.
    The new replacement boards are fitted with Rubycons throughout. Another one I have seen had a mixture, the 820uF were brown and un-named?
    The faulty one I'm looking at has Nichicon for the 820uF and the rest Rubycon. The Nichicons all test 0.1 ESR in circuit.
    I'm hoping to lay my hands on one of the vented ones when the next one fails (I'm sure that won't be long).
    Searching the web there's not too much about these but I do get the feeling that it's going to be an upcoming issue. The 3 year guarantee has just run out too so it's looking a bit like the old 270 issue.
    So, if anyone's got similar experiences I'd be interested to hear.
    Bob
  • 4tified
    • Jun 2008
    • 55
    Re: Dell GX620
    I haven't repaired any GX620 motherboards yet, but I will say that the issues are very similar to those of the SX280's, which I've fixed dozens of. Usually only 2 caps go bad on the GX620's upon total failure.... the capacitor you mentioned, and also a 2200uf, 6.3v located right underneath the hard drive. Not alot to say about replacement except to make sure you replace all the 820uf and 2200uf caps of the same brand on the board, because once you replace those two that failed originally, the rest are sure to follow within 3-4 month, if you're lucky.
    Good luck on repairs, it should only take 5-10 minutes if you have the resources.
    • midibob
      • Nov 2008
      • 285
      Re: Dell GX620
      Thanks for the reply,
      Interesting that the 2200uF are Rubycons. I was thinking if they were were Nichicons perhaps some fakes had crept in. I've been stung with fake semis in the past and with all those dodgy caps that were made it wouldn't surprise me if somebody had decided to change the plastic covers. Unlikely I guess but who knows.
      I was thinking about changing out the whole lot of 820uF and above caps just in case but I'm still suspicious that they should fail after only 3 years. At 105c rating I've seen caps last a lot longer in much more hostile environments.
      Bob
      • bgavin
        • Jan 2007
        • 1355
        • Subwoofer engineering/building, wedding photography, electric bass, Hammond keys, 5-string banjo
        Re: Dell GX620
        Perhaps there is a run of defective PSU in those machines?
        Might be worth a half hour to pull the PSU and lift the cover to take a peek. It might not be the board causing the failures.
        • midibob
          • Nov 2008
          • 285
          Re: Dell GX620
          I'm hoping to get hold of a PSU if only to be able to test any boards that I try to repair. Although up till now it would appear that once the mobos have been swapped out everything is OK. Time will obviously tell.
          The board I'm working on at present, I've now removed all the large value caps and they all test OK ESR wise.
          The only caps that have an issue I've noticed are the 220uF ones. A few of these have varying ESR readings, one in particular 12ohms whereas some of the 'good' ones are around 0.4. Mind you although these are Rubycons they are only rated at 85c (tut tut Dell)!
          I'm not sure there's any value in swapping out the large value ones as their ESR's are very good (low). Maybe there's a regulator failure, I need to look further into this.
          Bob
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16996
            • Badcaps.net Founder
            Re: Dell GX620
            I havent seen any yet, but I'm sure its a matter of time before I do.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              • PC's, The Experts Exchange (same name there), Gardening, Hot Rods.
              Re: Dell GX620
              Looks like badcap.net will soon have a new pet Dell board.
              Source:
              http://cnet.nytimes.com/desktops/del...tml#msg2590766
              Content:
              June 3, 2008 08:07
              Terrible
              0.5/5
              I have a lab with 56 of these machines with the super duper small form factor. During the course of the last two weeks, 26 machines have failed with at least blown capacitors on the motherboard. Some have needed CPUs in addition to the motherboards. Some have needed new power blocks, too.
              This lab is very cool, with it's own air conditioning. Speed Step protection is on, and the extra cover on the case is off.
              For whatever reason(s), these machines fail constantly. If you do the simple math, I have experienced a 46% failure rate. Maintaining this lab has turned into a full-time job in itself and I have never been so frustrated with Dell products in my life.
              If you do have to buy this machine, get a 4-year warranty and then extend it to however long you think you might have the machines.
              Caveat emptor.
              - WoofDoggie
              If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
              Subscribe to support us. It only takes 1 minute:
              https://www.badcaps.net/settings/subscriptions
              • midibob
                • Nov 2008
                • 285
                Re: Dell GX620
                Hi Pcbonez,
                I did come across that article in my travels which lead me to think that this one is about to become more widespread. Dell are denying any issues with this board but I wouldn't expect anything less.
                When I get my hands on a blown capacitor board hopefully I'll be able to identify the problem.
                Topcat, I'm sure that there are many others out there suffering the same issue so this thread should expand somewhat.
                Bob
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Re: Dell GX620
                  Yes,
                  Dell did the same thing when the HN and HM problems first started showing up.
                  [In their defense with new problems at first no one really knows what's going on.]
                  It's probably simply heat issues with that one.
                  Small tight case. Possible poor air flow in some areas inside.
                  On the other hand this may be the beginning of yet another plague.
                  In that case it might be a year or more before the real problem in known.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16996
                    Re: Dell GX620
                    True. Heat in these little boxes kills rubycons and panasonics all the time. I see blown pannies and rubies in SX280's on a daily basis. These systems don't breathe well.
                    • midibob
                      • Nov 2008
                      • 285
                      Re: Dell GX620
                      I've managed to get hold of another faulty board this time with with 2 blown caps on it. These are both 820uF and as you can see from attached (hopefully) photo they have blown their tops. One is next to the battery and blue link and the other to the left of the spiked ally heat sink.
                      Interesting thing is the caps next to them are 220uF and showing no signs of distress, but only 85c rated. These will need checking of course but how much internal heat would the 820's be generating to blow like that. I'm not convinced (yet) that this is caused by external heating alone.
                      Still, early days yet I suppose.
                      Bob
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Re: Dell GX620
                        The 220uF probably don't do much filtering compared to the 820's.
                        In fact probably aren't filter caps at all but are for coupling or something.
                        Recommend replacing 820's with some that handle more ripple.
                        The ripple capacity (kinda, sorta) tells you how much internally generated heat they can handle. More is better.
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16996
                          Re: Dell GX620
                          Bob
                          Replace everything on that board 820 and up. They're all Nichicon's. The blown 820uF's are rubycon. not uncommon for rubycons or panasonics to blow on these boards, they overheat.
                          • midibob
                            • Nov 2008
                            • 285
                            Re: Dell GX620
                            Well I have to start with a loud shout of 'Geronimo' as I now have a working board.
                            What I've found is the 220uF caps were all going low capacitance and only being rated at 85c I'm not surprised. The ones around the outside of the board were not too bad (0.7) but the middle ones varied from ESR's of open circuit, 70, 40, 12 ohms etc. I therefore decided to replace all of them with 105c.
                            I replaced the two vented 820uF and out of interest they measured around 6 ohms.
                            All the other caps were still measuring 0.1 so for now I've decided to leave them and see how it goes. Possibly short sighted I know but checking two boards now it appears they don't suffer the same stress.
                            Anyway, I must give a big, big thanks to Joe (Big Pope) for sending me the caps so quickly.
                            As for Dell fitting 85c caps in these boards is no more than built in obsolescence and these will probably be failing in huge numbers pretty soon.
                            I feel a recall coming on
                            Thanks to all
                            Bob
                            • kc8adu
                              • Nov 2003
                              • 8835
                              • U.S.A!
                              Re: Dell GX620
                              that board will be a good test of the samxon caps.
                              i am convinced that nothing short of polys will last in dell gx/sx boxes.
                              i just curbshopped a 280 yesterday.panasonic fj and fl blown up.
                              its going full poly tonight if i feel up to it.
                              hope you can keep that 620 to monitor the samxons.
                              for a fair test finish the recap as tc said.
                              • midibob
                                • Nov 2008
                                • 285
                                Re: Dell GX620
                                I'm keeping a database of the serial numbers as I do them with the caps that were changed. Being as the boards are now 3 years old it's doubtful the PC's will be kept for more than another two years so if they last that long then it's not a problem.
                                I'll certainly report back here if there's any news.
                                Bob
                                • midibob
                                  • Nov 2008
                                  • 285
                                  Re: Dell GX620
                                  A quick update on the 620's.
                                  The failed boards are still trickling in and the common fault in almost all cases bar one is the two 820uF venting (under the disk drive) and all the 220uF around the same area and close to the regulators.
                                  Interestingly enough the odd one I've just repaired, the usual two 820uF tested fine and the failure was due to the numerous 220uF caps going bad. Something to watch out for I think as one usually goes straight for the high value caps.
                                  All the other caps on the board were tested and proved to be at 0.01 ohms. I did change the 820's just in case but it's odd why these haven't failed in this particular board?
                                  I'm expecting another load of faulty boards today so I'll check the date stamps on the caps to see if anything there shows up.
                                  I've also got a load of GX280's to repair but that's for another thread I think.
                                  Happy New Year to all and have a good re-capping 2009
                                  Bob
                                  • lightingguy32
                                    • Feb 2008
                                    • 14
                                    • Computer tech, tech theater, electronics
                                    Re: Dell GX620
                                    What form factor are those GX620 machines? I work as a volunteer computer tech for both a local university (which has hundreds of GX620s all mini tower) and my high school (which has about 200 some GX620 desktop form factor machines)
                                    • midibob
                                      • Nov 2008
                                      • 285
                                      Re: Dell GX620
                                      I believe these are the USFF type as they have the external PSU brick.
                                      Out of interest they are still trickling in and almost all with the same caps going bad. No repaired ones have bounced yet, touch wood, but lets see what summertime brings.
                                      I find it strange that at the failure rate of these boards, there hasn't been more
                                      people here having the same problems?
                                      Bob
                                      • sargeslaughter
                                        • May 2009
                                        • 5
                                        Re: Dell GX620
                                        I am the network administrator of a 60 node network and Yes the ultra small form factor Optiplex GX 620's have a very high rate of failure. In October of 2008 I had about 40 + of 60 that were failing all in the same month. I had dell replace every one of them. During the replacement, there was an occasional bad board right out of the box. Don't they test these things? Occasionally they'll give you a bum board that never was retro fitted with the new caps. I had one go bad today. Sure enough it has the old style caps with the Y instead of the K design and it is leaking.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Adilson Silva
                                          Dell PowerEdge T110 server that stopped working after a stress test - bios request
                                          by Adilson Silva
                                          I'm working on a Dell PowerEdge T110 server that stopped working after a stress test. I need help recovering the VPD EEPROM (AT24C02).
                                          ― HISTORY ―
                                          I bought this server at a charity bazaar (Pequeno Cotolêngo, Brazil). I cleaned it up, installed Windows 10 LTSC, and tested it all day — heavy file transfers to 3 HDDs, driver installations, and finally added an external audio card to watch YouTube. At that point the machine shut down suddenly and never came back.
                                          ― SYMPTOMS ―
                                          • Power supply would not arm (no PS_ON signal)
                                          04-25-2026, 04:28 PM
                                        • Tesla
                                          Dell XPS-15 (9520) Mostly Bricked after common BIOS-Firmware upgrade - Full Repair Log
                                          by Tesla
                                          I have a Dell XPS-15 (9520) with the LA-L402P motherboard. It seems to have bricked itself after a common BIOS-Firmware upgrade. Now, it just shows BIOS screen for a few seconds before turning-itself back Off (and doesn't seem to be fully Posting). I've done these many times before with no problems.
                                          I was hoping to please have my own-thread to work-through this (hopefully successful) repair as a whole. Apart from the possible need to have a BIOS-dump fixed-up, I have a feeling I'm going to have other questions. This includes using my new XGecu-T76 for the first time (should be here...
                                          03-19-2026, 07:51 PM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
                                        • MtapeK
                                          Dell 14 Plus 2-in-1 DB04250 bios
                                          by MtapeK
                                          Can you help me i have my dell 14 plus that was restarted when it was updating bios firmware
                                          it is a DB04250 not a PB14250 i didn't know if i should start a thread or post here...
                                          Device details:
                                          • Model: Dell 14 Plus 2-in-1 DB04250
                                          • MFG Yr: 2025
                                          • ST:58ZXYB4
                                          • EX:11428011760
                                          • REG MODEL : P198G
                                          • REG TYPE NO: P198G001
                                          04-10-2026, 03:57 AM
