My recapped VP6 is acting weird.
  • Harvey
    • Apr 2007
    • 264
    Re: My recapped VP6 is acting weird.
    Watch out for that big red arrow - it looks sharp
    • Newbie2
      • Sep 2005
      • 885
      That Thermaltake 430W PSU does look a little on the cheap side, but better than a L&C. Teapos are fine in a PSU, and I haven't seen a CapXon cap fail yet in a PSU.
      That will do fine powering the VP6.
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • gastorgrab
        • May 2007
        • 320
        New supply is installed and the voltage numbers look almost exactly like the Antec power supply's numbers.
        But no wierd noise.
        The "2.5v is too higher" message still comes up when enabled. It's obvious that it's not the fault of the power supply.
        Here's a question: When you use a new style supply to power a slightly older board could it cause an unexpected voltage levels? I noticed that the ATX standard developed to the point where a certain wire is no longer required (it was dropped from the ATX spec).
        ......someone forgot to pack that little red arrow with my new power supply.
        • pvideo
          • Dec 2006
          • 8
          Try this site http://www.computergate.com/products...rodcd=BCFDPCUM
          They carry the AMD K7 CPU cooler for $7.95 for two. Similar to the one you're showing.
          • Newbie2
            • Sep 2005
            • 885
            I've seen some new power supplies missing IIRC the white +5VSB wire on the ATX connector. I have four ATX power supplies like that, and the missing 5VSB wire won't hurt the motherboard at all. They didn't damage my old trusty AOpen AX6BC Slot 1 motherboard (that board came stock with United Chemi-Con caps, wow for a board made in 1999! ).
            My gaming PC:
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              #26
              i put the old via monitor on a customers box today and got the same error including the engrish.
              freshly recapped vp6 with tc's modded bios.
              its a non issue.
              • pvideo
                • Dec 2006
                • 8
                #27
                Those CPU coolers I mentioned from computergate are $7.95 each or $7.75 each for two or more. They have to be better than the stock Intel heatsinks with the green clips. And I agree, the VIA monitor abnormal voltage warning seems irrelevant and/or wrong.
                • dan8139
                  • Jul 2004
                  • 57
                  #28
                  Is 2.5V to do with the RAM (VDIMM)?
                  • RJARRRPCGP
                    • Jul 2004
                    • 6301
                    Actually, not that wow. Because back in the late 1990s, motherboards were more likely to use Rubycons.
                    And United Chemi cons probably were used more.
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • gastorgrab
                      • May 2007
                      • 320
                      #30
                      Same thing in ubuntu;
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        No.
                        On VP6 RAM is 3.3v
                        2.5v (if it's even used) is most likely for some part of the chipset.
                        Can't be sure.
                        Unlike Intel's chipsets, diagrams of VIA chipsets aren't so easy to find.
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • gdement
                          • Jan 2007
                          • 690
                          #32
                          The white wire is -5V, not 5Vsb (that's purple).
                          I think -5v is only used by some ISA cards (and apparently not many even of those). It's in the ISA pinout anyway.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            gdement's right.
                            I've heard mention that some transitional MSI boards (about the time ISA slots were going away) used -5v on the board for something or other. My guess it that they didn't have an ISA slot but the board still had a legacy ISA BUS with some chip on it that needed -5v. (Maybe like a sound chip? - Not sure.)
                            - Dr Seuss
                            • RJARRRPCGP
                              • Jul 2004
                              • 6301
                              Unless it's DDR, it isn't, AFAIK.
                              Arc A770 16 GB
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                I've never seen an Abit VP6 that uses DDR.
                                Have you?
                                - Dr Seuss
                                • bridges_4u
                                  820-3437 motherboard acting weird.
                                  by bridges_4u
                                  Hi there,
                                  I have an 820-3437 motherboard which does not show any signs of life when using an OEM charger. But the magsafe light comes up when connected using a fake charger. While using a fake charger, the fan spins for may be 10 seconds and stops. Then the loop continues. Almost every power rail is up, but with 0.2-0.3 V drop. But I do not get a display, but sometimes does. While powered using the fake charger, the CPU seems to be burning hot. I got display at about 3 instances with the fake charger.
                                  But with the OEM charger, no signs of life.
                                  Any...
                                  04-19-2023, 08:12 AM
                                  TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                                  FF Series (Very Fast Acting), 0603 Size
                                  Features
                                  ● Very fast acting at 200% overload current levels
                                  ● Low DCR
                                  ● High inrush current withstanding capability
                                  ● Fiberglass enforced epoxy fuse body
                                  ● Copper termination with nickel and tin plating
                                  ● Halogen free, RoHS compliance and lead-free
                                  Applications
                                  ● Notebook computers and tablets
                                  ● Digital cameras
                                  ● Memory cards
                                  ● Toys
                                  ● Bluetooth earphones
                                  ● Portable electronic devices​...
                                  10-07-2024, 05:50 AM
                                  APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
                                  This started a few days ago and does this about every 8 hours
                                  After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
                                  The battery backup is about 3 or 4 years old
                                  Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
                                  06-02-2024, 02:30 AM
                                • ugamazing
                                  820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                  by ugamazing
                                  So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                  1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                  2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                  04-10-2024, 08:06 AM
                                • dreamlayers
                                  Weird clipping on Logitech Z-10 speakers
                                  by dreamlayers
                                  I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                                  05-22-2025, 11:41 AM
