820-3437 motherboard acting weird.
  • bridges_4u
    • Feb 2014
    • 128
    • india
    Hi there,
    I have an 820-3437 motherboard which does not show any signs of life when using an OEM charger. But the magsafe light comes up when connected using a fake charger. While using a fake charger, the fan spins for may be 10 seconds and stops. Then the loop continues. Almost every power rail is up, but with 0.2-0.3 V drop. But I do not get a display, but sometimes does. While powered using the fake charger, the CPU seems to be burning hot. I got display at about 3 instances with the fake charger.
    But with the OEM charger, no signs of life.
    Any advises?
  • mon2
    • 14779
    Re: 820-3437 motherboard acting weird.
    Without a heatsink, this is normal.
    Remain with the original charger only.
    Start with the review of PPBUS_G3H and the PP3V42_G3H primary rails.
    • bridges_4u
      • Feb 2014
      • 128
      • india
      Hi mon2,
      The CPU seems to be overheating with the heat sink. I shall post the voltage shortly.
      • mon2
        • 14779
        CPU is likely dead. Check the resistance to ground of the CPU power rail.
        • bridges_4u
          • Feb 2014
          • 128
          • india
          Hi mon2,
          Then how does it give you a display sometimes? Are you talking about CPU vcore?
          • piernov
            • Jan 2016
            • 4439
            • France
            Magsafe issue: https://logi.wiki/index.php/Magsafe_Sleep_Mode
            POST issue is probably unrelated though.
            • bridges_4u
              • Feb 2014
              • 128
              • india
              Hi mon2,
              mon2
              I found what the problem was. It was the 68k resistor in the pp3v42 circuit. I cant recollect what the part number is.
              Replacing it solved the problem.
              Thank you for the help and guidance.
              Regards
              • payam
                • Nov 2015
                • 80
                • iran
                thanks a lot dear bridges
                my problem also solved with changing 68k resistor R7012😍
                • paparazzo79
                  Fake magsafe 2 charger
                  by paparazzo79
                  Hi guys.I bought Macbook Pro mid 2014 15 inch model which did not came with charger.
                  I got new charger but judging by the specs seems it is fake one.Sadly I live in Bosnia and genuine charger is rare to find.
                  what to do?Should I use the fake one?
                  Will it damage the macbook?...
                  10-02-2024, 08:18 AM
                • motormayhem
                  Lenovo T460 Only Charges on One Charger
                  by motormayhem
                  Laptop Question
                  I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                  A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                  05-12-2023, 01:46 PM
                  NVDC charger configuration...
                  11-05-2024, 03:28 PM
                • flat-earther
                  how to prevent a connected charger from draining battery when not charging?
                  by flat-earther
                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                  So the battery is backfeeding the charger and being drained.
                  How can I prevent...
                  08-07-2025, 01:04 PM
                • Johndill
                  Dell Inspiron 7567 LA-D993P odd charger issue
                  by Johndill
                  Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                  There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                  I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                  Here are the tested scenarios:
                  1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                  2. With the laptop off, plug in charger (LED says on) & the front charging...
                  11-16-2022, 10:55 PM
