TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
    FF Series (Very Fast Acting), 0603 Size
    Features
    ● Very fast acting at 200% overload current levels
    ● Low DCR
    ● High inrush current withstanding capability
    ● Fiberglass enforced epoxy fuse body
    ● Copper termination with nickel and tin plating
    ● Halogen free, RoHS compliance and lead-free
    Applications
    ● Notebook computers and tablets
    ● Digital cameras
    ● Memory cards
    ● Toys
    ● Bluetooth earphones
    ● Portable electronic devices​
    Ordering Information:
    T0603FF0150TM
    T0603FF0200TM
    T0603FF0250TM
    T0603FF0375TM
    T0603FF0500TM
    T0603FF0750TM
    T0603FF1000TM
    T0603FF1250TM
    T0603FF1500TM
    T0603FF1750TM
    T0603FF2000TM
    T0603FF2500TM
    T0603FF3000TM
    T0603FF3500TM
    T0603FF4000TM
    T0603FF5000TM
    Surface Mount Fuses Fundamentals Datasheet
    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
    10-07-2024, 06:07 AM
  • Sik_6ty_Sixx
    HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
    by Sik_6ty_Sixx
    So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
    02-18-2025, 05:06 AM
    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
    12-14-2023, 07:45 PM
  • acedogblast
    Power supply for main amp blows fuses after replacing filter caps.
    by acedogblast
    Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
    I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
    I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
    02-27-2023, 05:11 PM
  • MrzPdlch
    Blown fuses on Gigabyte GTX 980TI 6GB
    by MrzPdlch
    Hey everyone,
    I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
    Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
    Find some pictures of the actual GPU together with a picture of how it should look like.
    I also wonder whther it might be a problem that there...
    03-10-2024, 04:14 PM
