Having seen all these threads about bad capacitors on video cards, I happened to note that my X1900XT has all ceramic caps (not even a polymer on there). Seeing as it is a 5 year old card (still runs great), I am surprised that more recent models continue to rely on more failure-prone electrolytics. Does this have to do with certain shortcomings of ceramics that could not be addressed, or does it have more to do with planned obsolescence?
Electrolytics vs Ceramic
Re: Electrolytics vs Ceramic
Check the price of Tantalum and Ceramic SMD capacitors. After you're done crapping kittens tell us what you're going to order next. Remember that those come in fairly small values so you need to stack a lot of them to equal the capacitance of a typical electrolytic. -
I do realize that ceramics are more expensive. However, the X1900 series does not make use of stacks, and is relatively sparse in terms of what you would expect in order to make up for the lack of electrolytics. So I do not think cost is an issue, at least in that regard. It would seem that the PCB is more inductor-heavy to make up for the lack of capacitance.Comment
well, people want newer faster things anyway... why make somehting last longer than its usable life?
then again, most people do not know how to recap things...sigpic
(Insert witty quote here)Comment
Checking Digikey
16v ceramics max uF is 680uF [have to call, the 150uF 16v is $25.25]
25v ceramics max uF is 470uF [$37.75 each]
50v ceramics max uF is 220uF [$34.26 each]
Now the 4v are cheap [under $2] if you buy 2000pc but they max at 100uF so you would need 50 to 60 to have enough bulk capacitance for a VRM Vcore.
Just using them there would add $50-$100 to the cost of the motherboard.
I for one would like to see some photos when you get them all soldered in.
Your video card is counting on the bulk capacitance in the PSU and on the board [to the slot] to keep it from dropping out on transients.
I wouldn't consider that a quality design...
.Mann-Made Global Warming.
- Dr Seuss
agreed. I really hope you were not using a gutless wonder with it or else your video quality will be in the toilet (or your gpu will be toasted). epic fail to the designers there.
that said, it is with noting my gateway/jabil kadoka slot A board is all tants, but it is the only board I have see like that.sigpic
I did have it running with a "520"W Aspire unit for a while, haha. It's on a PC P&C (non Teapo) unit now, though. The VRM section does seem to use some very complex silicon, so it may be possible that the designers intended to mitigate transients actively, rather than passively. There are 7 switching transistors, each coupled to its own inductor, so it seems that they did not necessarily skimp on input filtering/regulation. Looks more like just a different, rather unorthodox implementation.agreed. I really hope you were not using a gutless wonder with it or else your video quality will be in the toilet (or your gpu will be toasted). epic fail to the designers there.
Anyway, here is a shot of the reference design (transistors are covered by a heatsink, there are seven of them): http://www.xbitlabs.com/misc/picture...ler_bg.jpg&1=1Last edited by Trinite; 01-10-2011, 01:00 AM.Comment
by Pentium4So I disappeared from working on electronics for quite some time. I'm unboxing my ancient projects and want to resume some of them. Unfortunately, my knowledge is a little rusty.
I've always liked to do full recaps on power supplies. My cap supply isn't perfect and I do not have any more 0.47uF 50V caps. I do have some ceramic caps with that value. Can they replace the lytic without issues? If I remember correctly, their max voltage drops rapidly after getting hot. Is that correct? If this isn't a good idea, I doubt the cap will cause any problems. It's by the main controller/exhaust...-
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
by Perry BabinThere have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
If they require derating, why would the manufacturer give them their rated voltage?
This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
https://www.mouser.com/datashe...-
10-24-2025, 11:57 AM -
by Perry BabinI'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
This is for the primary side of a switching power supply in a car audio amplifier.
Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...-
by Wolf1977hi in ceramic oven the transformer is damaged
and writes
2x115v/2x12v/6VA 50-60hz ta105/f
can you suggest me a compatible transformer ;
i have found in 70 degrees celsius do you think is suitable for ceramic oven ; - Loading...
