SMD ceramic capacitor capacitance & voltage
  • Sparklingx
    • Jul 2024
    • 41
    • Bangladesh
    what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?
  • MORETTIGIAN
    by MORETTIGIAN
    Title:
    Description:
    Procedure performed:
    - Removed backplate
    - Reapplied thermal compound
    - Reassembled card
    09-18-2025, 12:14 PM
  • chth96
    desoldered capacitor is self charging until 0.6 voltage.
    by chth96
    I have an 21 inch CRT TV which is not able to power on.
    I disassembled 21 inch CRT TV and measured voltage of main filter capacitor(Samhwa HC 400WV 220uF) in the circuit.
    It shows 270V on my DMM.
    So I discharged this main filter capactior completely and detached circuit board from cathode-ray tube.
    Then I desoldered this main filter capacitor from circuit board.
    But I noticed that this desoldered large capacitor(Samhwa HC 400WV 220uF) is slowly charged by itself until it reached 0.6V
    I measured its ESR value with MESR-100 and it shows 0.1 ohm,judging...
    03-28-2024, 08:56 AM
  • NuclearSpartan
    Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
    by NuclearSpartan
    I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
    The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
    I don't see any other visible damage anywhere else on the board....
    11-14-2024, 02:32 PM
  • UserXP
    Transformer producing higher voltage than rated
    by UserXP
    Hello, people.
    i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
    So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
    09-02-2025, 12:42 AM
    AOZ2261NQI-11 Datasheet
    General Description
    The AOZ2261NQI-11 is a high-efficiency, easy-to-use DC/DC synchronous buck regulator that operates up to 28V. The device is capable of supplying 8A of continuous output current with an output voltage adjustable down to 0.6V ±1%.
    A proprietary constant on-time PWM control with input feed-forward results in ultra-fast transient response while maintaining relatively constant switching frequency over the entire input voltage range. The on time can be externally programmed up to 2.6µs.
    The device features multiple protection functions such...
    10-07-2024, 04:02 AM
