Replacing low value electrolytics with ceramic?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    So I disappeared from working on electronics for quite some time. I'm unboxing my ancient projects and want to resume some of them. Unfortunately, my knowledge is a little rusty.
    I've always liked to do full recaps on power supplies. My cap supply isn't perfect and I do not have any more 0.47uF 50V caps. I do have some ceramic caps with that value. Can they replace the lytic without issues? If I remember correctly, their max voltage drops rapidly after getting hot. Is that correct? If this isn't a good idea, I doubt the cap will cause any problems. It's by the main controller/exhaust so I doubt it will get hot or fail but I like to be thorough.
    • 31209
    Re: Replacing low value electrolytics with ceramic?
    most ceramics are 60% tolerance.
    i use polyester or polypropylene for 1uf and under.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Ceramic capacitors capacitance are also voltage dependent.
      So the general answer to this question would be no, you can't.
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        If you can get same value/voltage CGO ceramics, you won't have to worry about the temperature or voltage coefficients. If X7R, then the combined tolerance will be, IIRC, +/-20%. Z5U and Y5V are crap, IMO.
        That said, the impedance characteristic will be very different from lytics.
        PeteS in CA
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Thanks for the replies. I couldn't find anything suitable in my parts bin. I think I will just leave the cap where it is. All the other higher value caps will be replaced which should be good enough.
          • PeteS in CA
            • Aug 2005
            • 3581
            Ack! COG, not "CGO".
            PeteS in CA
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              but it is NP0?
              • PeteS in CA
                • Aug 2005
                • 3581
                "COG" and "NPO" are the same thing, probably nomenclature going back more decades than I do (I think I saw the terms used in late 1950s vintage TV technician magazines).
                PeteS in CA
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  oh I was jusr being silly with O's and 0's, you know my username...
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    I needed to order parts for something else so I just ordered some 0.47uF 50V nichicon UPW
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      OOOOOOooooooooK
                      PeteS in CA
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        000000k it is
                        • TheLaw
                          • Jan 2011
                          • 477
                          If you want to visualize how capacitance drops with applied DC bias voltage, you can check out Kemet's KSIM web app:
                          https://ksim3.kemet.com/capacitor-simulation
                          The limitation is fundamentally package size, and more directly, the physical amount of dielectric material contained. Since Class II ceramics are ferroelectric, they "saturate" similar to how an inductor's core might. More material means it saturates less under the same DC bias conditions.
                          Beware of "too good to be true" capacitance values in tiny packages. Sure you can get a 1.0uF/25V 0603 capacitor, but you better not use it above 5V, if you really need a 1.0uF capacitor.
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Thanks for the link, that's a pretty useful tool
                            • spleenharvester
                              Ceramic capacitors/resistors - do suppliers matter?
                              by spleenharvester
                              I want to buy one of those SMD component books so I don't have to spend as much time searching my scrap boards for what I need, specifically ceramic caps and resistors as they seem to be what I spend most of my time replacing. But the only ones I can find are no name brands. Does manufacturer matter as much for SMD parts as it does with electrolytics or is the generic stuff likely to be fine?
                              05-01-2025, 05:34 PM
                            • chth96
                              by chth96
                              03-09-2024, 10:03 PM
                            • sdogs
                              Macbook pro 13 A2442 820-02098 Touch ID doubt
                              by sdogs
                              I have a macbook pro 14.1 A2442 that has had contact with liquid, the affected area is the one near the touch id connector (see image). I carefully cleaned the affected area but the UT600 chip (LM3638A0) seems to be in poor condition and probably needs to be replaced.
                              I searched online and found the replacement but it is indicated as a spare part for iphone 6 and 6 plus and at this point I had a doubt, does this chip have some type of programming?
                              Forgive the question, I'm just an enthusiast but I had this doubt and before ordering the spare part I wanted to be sure I wasn't doing...
                              09-24-2024, 02:36 AM
                            • Reintar
                              Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
                              by Reintar
                              First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
                              One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
                              08-30-2024, 06:13 AM
                            • m1ch43lzm
                              Replacing 2xAA / 2xAAA alkaline batteries with Li-Ion / LiPo battery?
                              by m1ch43lzm
                              Hi, i have this RadioShack IR thermometer Cat. No 22-170 which takes 2xAAA batteriss, I've tried with NiMH AAA rechargeables but it complains about low voltage, it flashes an "empty" battery and doesn't measure anything, even with freshly charged 2xAAA NiMH, so i have to "borrow" the batteries from my multimeter when i want to use it
                              I'm thinking abour replacing the 2xAAA batteries with a small LiPo battery that fits inside that space, but the voltage would be too high (4.2v)
                              I'm open to suggestions on whether i should use an LDO or another type of voltage...
                              05-27-2025, 05:34 PM
