dead transformer on ceramic oven
  • petehall347
    • Jan 2015
    • 4452
    • United Kingdom
    Re: dead transformer on ceramic oven
    is there room for a regular transformer to be mounted ?
    • Wolf1977
      • Jul 2023
      • 59
      • Greece
      Has anyone encountered a similar problem to mine? and has put in place of the first transformer which is TA105/F transformer TA70/B?
      • Wolf1977
        • Jul 2023
        • 59
        • Greece
        hi again
        just i want to ask to be sure
        i want to test the rest circuit with an external power supplier to see if its ok
        the transformer at the output has 2 outputs 12 vac 250 ma each and are connected parallel and go to the input of a bridge rectifier and the output of bridge connected on electrolytic capacitor 1000uf/35volt
        i connected 12vdc to the pins positive and negative of the capacitor and the circuit is dead i measure on the other pcb that it has the controller and i have 5 volt
        so i wanted to ask i dint think to needs the circuit more volatage from 12 volt to work do you agree ;
        • R_J
          • 9638
          12 volts AC would produce approx.. 17VDC
          • Wolf1977
            • Jul 2023
            • 59
            • Greece
            show with 12 volt maby its not operate
            although pose produces 5 volts nothing lights up so it can play a role and I have to give it 17 volts correctly
            Of course this board was connected to a network where there was some overvoltage and the pos transformer I have reported inflated so I keep my doubts about the rest of the circuit
            • redwire
              • 3912
              What voltage are the relay coils? They are also run off the raw DC. I see a blue PTC or MOV next to the transformer, I wonder what it does.
              But I am assuming the 5V rail is the main one.
              EGO 75.13051.10B oven board repair
              • Wolf1977
                • Jul 2023
                • 59
                • Greece
                #27
                The PTC from what I know is for current limitation I had given the positive pole of the power supply first there and from its other foot to the positive of the electrolytic capacitor and then I put it and directly on the electrolytic did not change anything the relays are 12 volts I checked if any integrated more of the processor warms up all well just does not command to light anything by pressing with my finger the black buttons
                • redwire
                  • 3912
                  If there is no crystal on the board the MCU might rely on mains AC for 50/60Hz clock (timekeeping) and be waiting for pulses on that?
                  That is the last thing I can think of, but we have no pictures of the board to figure out what the transformer completely does.
                  You said a power surge killed the transformer in the first place, it is bulged out?
                  So the 5V rail is OK, but the display is dead? Otherwise I would guess the MCU is dead or other parts are damaged.
                  • Wolf1977
                    • Jul 2023
                    • 59
                    • Greece
                    #29
                    there is not crystal
                    • redwire
                      • 3912
                      Then the MCU is using RC oscillator which is not very accurate, it would not be good enough for a time clock. Does the oven have this feature? Say a 3hour timer or something?
                      There is a chance the MCU needs AC pulses from transformer secondary for the firmware to work.
                      You can look for a small trace leaving transformer secondary and then a diode and resistor to a MCU pin.
                      I just don't want you to write off the board as bad if it's only the transformer.
                      • Wolf1977
                        • Jul 2023
                        • 59
                        • Greece
                        #31
                        Unfortunately I couldn't find a line going to the pins where the oscillator crystal connects the processor is atmega16l and the legs of the crystal go to two islands in the air I can't find where they go the board is 0000 980,120-02 yl145 t105
                        • labello
                          Beko microwave oven dead !
                          by labello
                          Hi guys, how's it going?I hope you're all doing well. So a friend of mine told me that his little oven just dead, no noise like spark or something no blown up, anything just dead. I opened it and on the board control I found capacitor dead (you can see the dirty on the pcb , resistor broken and the rest of capacitor are low value. I
                          just wanted to understand if existing the scheme for this controller board. Thank you do much for the answer
                          02-14-2024, 04:05 AM
                        • Bobby78
                          Dead Oven Control Board, Possibly Transformer?
                          by Bobby78
                          Six long years ago, @tom66 helped me save my plasma TV here on BADCAPS, and it's still going strong. Fingers crossed for another win!
                          I have a Frigidaire oven, rarely used, that I noticed was dead at some point during the summer, possibly after one of the bad storms. The light still comes on when the door is opened, so the circuit has power, but no sign of life from the LCD or the button panel. The control board part number is 318010700 and does not seem to be available any longer from any supplier, but there are companies that will repair them for $150-$200. Obviously I'd like...
                          11-11-2020, 12:42 PM
                        • double_DD
                          Transformer replacement for a dead coffee machine
                          by double_DD
                          Hi guys,
                          I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
                          Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
                          If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
                          My other ideas:
                          - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
                          - to buy...
                          06-23-2025, 05:43 AM
                        • learnmore
                          Help choosing replacement transformer for Levoit 600S SMPS
                          by learnmore
                          Hello Community,
                          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                          Peace
                          LM...
                          11-04-2025, 09:35 AM
                        • ohren
                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                          by ohren
                          Hello!
                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                          Measured voltages with no load:
                          After rectifier diodes
                          12V: 6.17 V
                          5V: 5.67 V
                          Secondary transformer pins AC measurement (really don't know if this says anything)
                          12V: 2-2.5 V
                          5V: 1.04 V
                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                          03-18-2023, 10:33 AM
