Rtl8169
    • 31087
    Rtl8169
    are these chips supposed to get so hot that even with a heatsink they cant be touched??
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Rtl8169
    0-70c operating temperature according to the data sheet.
    I wouldn't have thought it should be too hot to touch though. I've seen them in laptops and they aren't heatsinked.
      • 31087
      Re: Rtl8169
      hmmm.
      i have 2 pci cards.
      one netgear - naked.
      one chinese - with a sink and frankley better made.
      i tested the chinese one and just idling for 15mins without any data transfer it was generating some serious heat - but worked fine when i fired up firefox for a test.
      i think i'll dig the netgear out for a comparison.
      • diif
        • Feb 2014
        • 6978
        • England
        Re: Rtl8169
        Interesting, let us know what you find.
        Better made ≠ better designed though.
          • 31087
          Re: Rtl8169
          most things like this are all based on the reference design though.
          • diif
            • Feb 2014
            • 6978
            • England
            Re: Rtl8169
            Did the chip on the Netgear get hot ?
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Re: Rtl8169
              All my 8169 chips on the ethernet boards I have stay fairly cool.
              The only thing on these boards that get hot are the VRs on the boards.
                • 31087
                Re: Rtl8169
                the netgear was screwed,
                but i decided to look at the regulators on the chinese one and the resistance between input and output was only a few k - very suspect.
                they are 1117's - so i'll pull then in the next couple of days and meter them off-board.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Re: Rtl8169
                  If it's a real rtl8169 it should only average about 0.5W - this should be enough dissipation to feel something but it should not burn your finger off nor need a heatsink (unless it must stay cool).
                  • Badee
                    • 7
                    Re: Rtl8169
                    interesting design, i must say
                    • hikaruichijo
                      • Aug 2015
                      • 123
                      • Spain
                      Re: Rtl8169
                      Realtek cards are poor performers, but only saw then overheating after a lightning strike.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Re: Rtl8169
                        I've seen a lot of hearsay that rtl8169 chips are poor performers but no actual benchmarks. I do not expect it to match top cards but from my experience with them, they are more than "poor" - they're quite acceptable for many uses. Is there a benchmark where the rtl8169 is less than 60% the speed of another ethernet solution, and how often does that benchmark happen in real life?
                        Oh, and do not count rtl8169's put on PCI 32-bit/33MHz busses... that's known to be a bottleneck...
                        • harp
                          Metod for removing glued heatsink from fragile component
                          by harp
                          I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                          06-23-2025, 02:01 PM
                        • Ven
                          Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                          by Ven
                          I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                          The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                          I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                          If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                          07-08-2024, 09:32 AM
                        • piernov
                          Core 2 "gaming" build with SLI
                          by piernov
                          My turn to post a build I guess, wasted way too much time on this one…
                          First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
                          Everything done with random parts I had lying around.
                          Specs :
                          • CPU: Core 2 Quad Q9450
                          • RAM: 2x2GB KHX6400D2K2
                          • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
                          • MB: P5N-E SLI
                          • PSU: Antec Basiq Power 550 Plus
                          • HDD: Hitachi Ultrastar A7K2000 1TB
                          • ODDs: DVD ROM, DVD RW
                          • Case: not sure
                          Cooling:
                          • 92mm rear fan
                          • 120mm front fan
                          • Additional heatsink on southbridge
                          05-20-2023, 11:38 AM
                        • harp
                          can fanless heatsink replace poor original on RX26PG2
                          by harp
                          I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                          06-25-2025, 10:56 AM
                        • Crystaleyes
                          Omega MML200 Coutant Lambda PSU repair
                          by Crystaleyes
                          Hi all.
                          Recently I picked up a vintage HP 37717B communications analyzer which uses one of these MML200 Coutant power supplies. Needless to say the PSU is not working, and surprisingly there is apparently nothing available on the web regarding repairing one of these. No stories, no schematics, zilch!
                          There are however many companies offering repair 'services', however I don't have the luxury of sending it off, so am intending to do the repair myself.
                          I admit right now that I am no expert on smps repair, although I do have a grasp on the principle of the general...
                          05-29-2024, 08:23 PM
