Well my old reliable Linksys BEFSR41 router just disconnected me again this morning the red diag light was on and as usual when this happens I just unplug it and reconnect it and I'm good to go for some undetermined amount of time until it does this again.
It could be a week 2 or a month I don't keep track.
However recently I assembled my new shiny Blue Anatek / Bob Parker ESR meter (I will have a full review in the test equipment section next week boy was assembly and problems that weren't there caused by the "diagnosis function" time consuming).
Anyhow so I open the case to open it is easy there are no screws simply grasp one of the blue legs and one of the black ones and pull apart real hard and the front of the case will release from the back.
Remove the single screw securing the board to the bottom casing and push the board back to disengage it from the 4 retainer tabs.
The D-Paston caps inside all looked fine with no bulging.
So I get my ESR meter out and measure the low value 10uf 16V caps and this is what I find.
There are 15 10uf 16V in all I only listed the ones with ESR greater than 3.0 ohms.
70 ohms
24 Ohms
15 Ohms
12 Ohms
11 Ohms
8.0 Ohms
8.0 Ohms
5.6 Ohms
5.3 Ohms
These measurements were made out of circuit after they were red flagged when I measured them in circuit.
No thats not a mistype one was actually 70 ohms.
I replaced all of these with General Purpose 105 C Chemicon KMGs.
The 2 1000uf 16 Volt filter caps measured as follows:
.14
.32
I don't think that they were a real problem but since they were an unknown (D-Paston) I replaced them too.
I used low ESR Panasonic FCs since those caps were part of the filter network and I upgraded the working voltage to 25V for a little more "elbow room" especially since the wall wart linear adapter isn't regulated.
This is the very reason why I don't believe that caps under "insert value here uf" usually don't give you any trouble and you can leave them alone.
The faulty caps on this board looked just fine to the eye but one of those "ok" caps had an ESR of 70 ohms
I say let your ESR meter be the judge.
Here is a pic of the finished board I had to mix 63 volt 10 ufs with 100V 10 ufs (thats why they are different sizes) because I was running out of Chemicons at 10uf I have to reorder
I must say it felt wierd not having Internet access while recapping I wanted to check out D-Paston but I couldn't it also reminded me not to screw up
70 ohms
24 Ohms
15 Ohms
12 Ohms
11 Ohms
8.0 Ohms
8.0 Ohms
5.6 Ohms
5.3 Ohms
.14
.32
