Extending wifi
    • 31190
    Re: Extending wifi
    it's mostly the shortwave afaik.
    • Logistics
      • Apr 2007
      • 721
      Re: Extending wifi
      Speaking of extending wifi, I'm curious: I have a Belkin N750 DB, and its mainboard has mini-coax jacks at three points on the board which are used as 2.4GHz antennae. I have been considering buying three 2.4GHz antennae from the local surplus place, which have mini-coax plugs, and hooking them up/attaching them to its shell, to improve signal strength.
      Does that sound like it would work?
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        Re: Extending wifi
        They should work. You might have to enable them in the router firmware.
          • 31190
          Re: Extending wifi
          the sockets have switches in them, they will just work.
          the antenna's are probably 2.5dB junk though.
          it would be better if you found some RP-SMA sockets with tails and micro-connectors on them.
          then you could get some decent 8dB antenna's!
          unfortunatly i doubt you will find such a thing.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Re: Extending wifi
            At least he'd be able to position the external antennas and that can help in many situations.
            • Logistics
              • Apr 2007
              • 721
              Re: Extending wifi
              I finally put this router into service,, last night because I replaced my sister-in-laws' aging 5101u modem with a new CMD31t (yay DOCSIS 3), and got rid of the Comcast-provided Netgear router. The signal-strength only seems a little bit better, but at least its a faster router, and seems to have greater abilities.
              But I still plan on adding antennas, ALTHOUGH I may try that trick where you deflect the signal on one side since it is on a corner of the house and doesn't need to travel outside the wall, obviously.
              Question, should I go ahead and run anything which can on the 5GHz side, just for the sake of not being on the congested 2.4GHz side? (This is a Victorian house which is partitioned into 6 units, next to two apartment complexes.
              • diif
                • Feb 2014
                • 6978
                • England
                #27
                Re: Extending wifi
                @Logistics, 5Ghz doesn't penetrate wall or have the range of 2.4Ghz, but give it a try, nothing to lose but a bit of time.
                • Logistics
                  • Apr 2007
                  • 721
                  Re: Extending wifi
                  Well, the only thing I have that can do 5GHz is my main rig, which is right on the other side of the wall from me in my sisters' apartment. I get full bars at 5GHz since I'm so close.
                  My nephew asked me to hard-line his Xbox 360 to the router over LAN because he felt it was slow over wireless. I was reluctant to do this because I don't want him and his video games stealing all the bandwidth while the rest of us connecting wirelessly suffer slower connections. BUT does anyone know if that is truly what happens or am I being paranoid? Everything seems okay, and the bit of flaky behavior everyone was experiencing seems to have disappeared. However, I also changed to a better wireless channel after scanning my area, and that may be the whole reason its working better.
                  That confusion... when you change too many factors at one time.
                    • 31190
                    Re: Extending wifi
                    games use hardly any bandwidth, but they need low latency.
                    ie - reaction speed is key, so wired is best.
                    • mockingbird
                      • Dec 2008
                      • 5484
                      #30
                      Re: Extending wifi
                      Yes, if he ever uses it to download complete games or DLCs and stuff like that. I've seen some pretty good bandwidth limiting features in the Shibby TomatoUSB firmware, so I'd recommend using that firmware or something like it that can limit bandwidth by IP. You would need to assign the Xbox's MAC Address a static IP first on the router, to make sure it gets the same one from the DHCP server each time it connects.
                      • Logistics
                        • Apr 2007
                        • 721
                        Re: Extending wifi
                        He only uses it to play games, but not download them. He's constantly playing Halo and Battlefield, which does make a noticable dent in response when we try to stream a movie over the internet or I try to stream a 3-hour long trance track from YouTube. Still annoying, which is why I want to limit his games' bandwidth hogging. But this is on top of my nephews's little brother using his iPad to stream things, his mother streaming things with her iPad, my wife streaming movies with her laptop or iPad, etc. I don't know if a costly Cisco router could handle all this better or if this just life. lol!
                        As far as TomatoUSB is concerned, it appears that nothing exists for the N750 DB, but the WNR2000 which was provided by Comcast, originally does seem to be moddable. Maybe I'll hook up the WNR2000 and just put his Xbox on it so the Belkin can do all the wireless in the house. Muahaha!
                        • nojgib
                          • Nov 2014
                          • 30
                          Re: Extending wifi
                          Sadly this sounds like my place except there are a few more playing games/ Youtube /Netflix all at the same time.
                          Try setting up QoS (Quality of Service).
                          • Logistics
                            • Apr 2007
                            • 721
                            Re: Extending wifi
                            I actually found that it's just the two, original iPads which seem to drop, sporadically when streaming YouTube and such. It doesn't seem to have anything to do with other devices in the house. I have a few HTC Evo 4G's with custom ROMs in the house which act as media players, and they never drop while running YouTube.
                            • mockingbird
                              • Dec 2008
                              • 5484
                              #34
                              Re: Extending wifi
                              Gargoyle firmware is the best firmware I've used so far. Since it's based on OpenWRT, the underlying code is far, far more stable and polished than DD-WRT could ever hope to be.
                              This has been running on a thrift store DIR-615C1 for the better part of a year now. I highly recommend you take a look at their download page to get a good idea of which models are supported (Each filename has the model in it). Either that or get something you can run a Shibby Tomato build on. As far as I'm concerned, and in my experience, DD-WRT is more often worse than stock firmware. It is the Ubuntu Linux of Router Firmwares. Tries to be all-encompassing, and doesn't run well on anything in the end.
                                • 31190
                                Re: Extending wifi
                                gargoyle has nice menu screens
                                • filippia1981
                                  Starlink WiFi router firmware of the HR1211 IC
                                  by filippia1981
                                  Hi, I would like to ask if someone has the firmware of the HR1211 IC of the Starlink WiFi router in order to program a new IC
                                  The diagnosis showed that this IC is shorted and need to be replaced with the right firmware. I cannot find the firmware
                                  kind regards
                                  Ioannis Balouktsis
                                  06-17-2024, 11:38 AM
                                • harp
                                  simple win network with optimization issue
                                  by harp
                                  simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                                  06-23-2025, 11:01 AM
                                • howardc64
                                  M557-G0 no WiFi/Bt no WIFIVendor file?
                                  by howardc64
                                  Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
                                  • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
                                  • Service Menu shows many Bt/Wifi info missing
                                  • Vizio app shows no WIFIVendor file
                                  Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
                                  • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
                                  10-15-2024, 01:12 PM
                                • double_DD
                                  Why does my ISP router hate my "homemade" power supply??
                                  by double_DD
                                  It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                  So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                  For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                  07-12-2025, 03:09 AM
                                  HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
                                  This specification for the HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Backpack & Wireless Premium Mouse boardview and 650 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                  09-06-2024, 03:30 PM
