Starlink WiFi router firmware of the HR1211 IC
+ More Options
Posts
  • filippia1981
    • Mar 2021
    • 29
    • Greece
    Hi, I would like to ask if someone has the firmware of the HR1211 IC of the Starlink WiFi router in order to program a new IC
    The diagnosis showed that this IC is shorted and need to be replaced with the right firmware. I cannot find the firmware
    kind regards
    Ioannis Balouktsis
  • filippia1981
    • Mar 2021
    • 29
    • Greece
    This IC is situated at the power supply board of the router
      • 30978
      it doesnt have firmware, you just configure settings.
      look here:
      https://www.monolithicpower.com/en/hr1211.html
      maybe it still has a working core and you can read it out.
      • harp
        • Jun 2022
        • 598
        • Planet Earth
        Or to trace needed parametar from pcb... if you have dedicated GUI.
        • filippia1981
          • Mar 2021
          • 29
          • Greece
          Thank you very much for your quick responses
          kind regards
          Ioannis Balouktsis
          • TheUser
            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
            by TheUser
            Hello to everyone ,
            This is my first post here, and i would like to share with you a small story in case you can help me.
            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
            02-10-2024, 02:07 PM
          • double_DD
            Why does my ISP router hate my "homemade" power supply??
            by double_DD
            It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
            So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
            For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
            07-12-2025, 03:09 AM
          • duwane
            A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
            by duwane
            Hi All.
            Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
            The issue:
            Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
            10-26-2022, 07:02 AM
          • gurj1979
            Ubiquiti firmware help. US-8-150W POE
            by gurj1979
            Hi guys.
            I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
            Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
            So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
            Got New chip and writes good.
            THE PROBLEM...
            It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
            Does anyone have a Good Firmware I can have?...
            07-22-2024, 05:13 PM
          • Russ1
            Starlink GEN2 Router Internal Power Supply Chicony UTP-211C Schematic
            by Russ1
            Sick of seeing big numbers of these routers dead no power light underneath.....
            Chasing Schematic of this power supply I have searched high and low....
            Already spotted a few swollen caps, but Ac fuse ok.....
            This is a dual output 50Vdc 2.5A and 12Vdc 1.25A psu
            Can anyone help with any type of schematic and parts list ?
            Thanks and Regards, Russ
            07-10-2025, 11:01 PM
