I'm f*cking furious!
Two years ago I bought two NetGear WGR 614 v1 routers. One I used 24/7 with 4 devices + two eight port NetGear switchers and one I borroved to friend, who use it less with only 3 computers. Port 4 not used on "his".
Yesterday I talked on ICQ with Big Pope about caps and stuff, and my connection went down. I assumed that this is my ISP again, and don't worried too much about it - there is lot's offline work too, so... Anyway, since the connection won't kick even in next morning, I rebooted few times cablemodem (but ping on router and then cablemodem was good) and finally I rebooted router, witch seems to be working good, yet still... And connection kick for a while AND there was again a problem on port 4 of the 4 port switcher output part of the router!
When I stated earlied in the thread about WGR614v4 that I did not have any issue with my WGR614 v1 I did not wanted to elaborate on one problem, that I had and never be able to figure it out, so I won't listed it as problem.
That was - about half or 3/4 year after purchase and install the router become losing sometimes connection on port 4 - I would say the least powered port then. I thought - bad contact. Cleaned, bend the contact to make better contact, inspected again, again measured cables, put new connectors at them again and again... and no help at all.
But suddently - always after some fiddling - the port 4 kicked back in and worked for month's w/o signle issue. Hmmm.
So, I remembered the unhappy used with WGR 614 v4 and his bad caps and in hurry I opened the router to check out what NetGear come up with v1 - and !DAMN! - these are Tocon caps! Yep, similar "grade" as Teapos, GSC and other "worsest of the worse"....
I got a bit more furious and - checked the Pannyes stock. Well, their 470uF 16V ones are 16mm high. There is no more that 12, maybe 13 mm space. So, I checked out and whoa, Samxons GD 470uF 16V fit well.
It should be noted that there are two 470uF ones and two 330uF ones - these are 25V rated, tough there is no 25V on them - nowhere near, 16V ones is more that enought there... I recapped all with 4x 470uF 16V Samxons GD and - turned the router on/off at least 20 times today w/o a glitch - eg. it never lost again the connection on port 4.
I should be happy - after all, 5min of work or something? And problem is gone for good. But all I feel is growing anger at the NetGear designer, who used such caps - Tocons are well-known for his failing - in fact, that is the only one thing one can count on them...
And how the price could increase, if there are used proper caps, like Rubycons, Nichicons or Samxons - when the Panasonic ones are out of question as Panasonic don't make small-enought 470uF ones...?
Now, 470uF 16V Pannyes at http://digi-key.com cost 0.116$ in 1000 pieces volume and I bet NetGear produced much more that 250 units, so their price will be far lowr for sure.
(when one want 25000 of them, it cost only 0.09289 then for general public, NetGear sure could nagotite even lower price...)
Come on, this is four caps per unit and the damn cursed Tocons gotta cost something!
So, I take it, that for NO REASONS NetGear rob their customers by using known bad brand of caps in their units and I bet countless of users pay by their time like me, trying to figure out WTF is going on with their router - I must consider myself happy, no major problems, but I also did not used much the WiFi part, mostly disabled it, so...
Anyway, since the unit run pretty hot, I decided that it is time for better cooling holes that these very little ones NetGear made:
Hope you like my work, guys
