Synology MR2200ac mesh router, UART connection - login details?
  • spleenharvester
    • Mar 2010
    • 913
    This particular unit powers up, LEDs behave normally, but broadcasts no SSID, will not mesh with any other routers. Plugging in an ethernet cable from a Windows laptop results in "unidentified network" with an autoconfigured IP address and no response to pinging 192.168.1.1.
    I was able to log into serial/UART by connecting the 6-pin header to the GPIO on a Raspberry Pi Zero W (GND to GND, TxD to RxD, RxD to TxD, no connection between +3.3V as it is supplied on both sides) using Minicom, command:
    Code:
    sudo minicom --baudrate 115200 --device /dev/ttyS0
    Upon powering the device it looks normal to begin with. But it looks like it is mid-upgrade:
    Code:
    Found an upgrade file on data volume. Begin upgrade
    create upgrading flag to keep upgrading status.
    But then fails:
    Code:
    End upgrade procedure
    ============upgrade
    Exit on error [7] Version number not match...​
    Then proceeds to whine about how it can't find wlan0, wlan1 or eth2, and lists off the only installed devices - these being eth0, eth1, gbr0, lbr0 and lo.
    I am guessing I just need to clear the upgrade flag and/or reinstall it from UART by providing the SRM and BIOS files on a USB stick. The problem is it then leads me to a prompt with
    Code:
    SynologyRouter login:
    And then prompts for a password after this is typed in. I cannot for the gd life of me figure out what this is. The router has been reset at the back. I've tried:
    admin / password
    admin / synology
    admin / <blank>
    And various other permutations, I cannot find anything that works. SRM definitely has a default account called "admin" as I can see it on my RT2600ac but cannot see what the password might be.
    Any idea what it might be or whether I can somehow bypass it to do the upgrade?
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 913
    Okay so user is root, password is 101-0101 (apparently this is derived from the date and changes every day? - but since mine has no date set that is probably why this works). Will update if I can fix.
    • spleenharvester
      • Mar 2010
      • 913
      Info for anyone stumbling upon this in the future with a similar problem - I didn't have any luck with this unfortunately. I couldn't entirely figure out what was wrong other than an upgrade seemed to have failed, possibly related to a VERSION file being corrupted somewhere. I tried mounting /dev/sda5 and /dev/sda6 and clearing all the upgrade files + flags but something kept putting them back. I think possibly if you get an update .pat file onto the device you might be able to install it using the installer at /usr/syno/synoupgrade. I was unable to do so via ethernet as the device could ping the default gateway but would not connect any further. The device does not accept FAT32 or exFAT drives in this state, only ext2/3/4, so if you format a drive that way and load a .pat file onto it you may be able to mount it by plugging the drive into the USB3 port at the rear. The problem is further confounded by the fact that many default programs are missing (sudo, nano, apt and so on)
      synoupgrade also has some other functions incl recovery, not clear how they work but in my case they always failed
      Unfortunately between reboots I somehow fudged my device to the point that it would no longer even load the kernel so I abandoned any further efforts.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8286
        Manufacturers cracked down on a vulnerability years ago. When you do a reboot, it will reverse all changes you had made to the boot process. Same thing happened to me on a different device. In one way it is good, but looking at a repair perspective, its a real pain in the @$$.
          • 31137
          find the backup it restores from and edit that too
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8286
            stj
            I tried that a few years back on a NAS in order to make a backup from one NAS to a different one. Worked fine for years until a certain update. I had modded the boot a little to basically auto start a certain service. Well, after that update it would default the boot. So on each start of the NAS I would have to ssh in, start the service and get back out manually. Then do the backup. Needless to say, I didn’t do that for a very long time.
            Not sure how to get around it and never solved that issue, since I found a better way of doing things. Since then the old NAS is just sitting there doing nothing.
            • double_DD
              Why does my ISP router hate my "homemade" power supply??
              by double_DD
              It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
              So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
              For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
              07-12-2025, 03:09 AM
              HP ProBook 450 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 450 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Linksys Velop Intelligent Mesh WiFi System boardview and 450 G7 + Linksys Velop Intelligent Mesh WiFi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
              09-06-2024, 08:10 PM
              HP ProBook 430 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 430 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Linksys Velop Intelligent Mesh WiFi System boardview and 430 G7 + Linksys Velop Intelligent Mesh WiFi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
              HP EliteBook x360 1030 G4 + Linksys Velop Intelligent Mesh WiFi System Hybrid (2-in-1) Specification for Upgrade or Repair
              This specification for the HP EliteBook x360 1030 G4 + Linksys Velop Intelligent Mesh WiFi System Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Linksys Velop Intelligent Mesh WiFi System boardview and 1030 G4 + Linksys Velop Intelligent Mesh WiFi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
              09-06-2024, 07:50 PM
