NETGEAR and issues with it forgetting password or just going off line fairly new
    • Jul 2011
    • 6046
    I have for many years have used NETGEAR routers and most of the time I get about 2 to 4 years of service before I have issues with it but this one is a pain in the a** to say the least
    First of all it goes offline for no reason at all
    Or it has an error message that says no internet connection
    The other issue is that sometimes it asks for the password also for reasons that I can think of
    Power cycling it helps but a week or maybe longer then you have some kind of issue like website loading very slow or can not access the printer or whatever it decides not to work properly anymore or sometimes it is very reluctant to connect a new device you have to retry several times before it will connect
    I purchased at Costco or it might have been Sam club about 3 or 4 months ago so I probably can not return it anymore
    What could be the issue with this router the last time I checked there was no firmware update except for the one that I installed when I first got the router
    There seem to be no issues with the router getting hot or anything like that
  • redwire
    • Dec 2010
    • 3910
    Re: NETGEAR and issues with it forgetting password or just going off line fairly new
    I've had many routers go flaky due to bad caps. edit: ethernet switches too.
    I would check the electrolytic capacitors, including the 12V output of the wall adapter because the caps in it can go bad as well.
    Many Netgear router models have been hacked repeatedly, check the firmware Release Notes at https://www.netgear.com/support
    You better not have "Remote Management" enabled...
    Examples of exploits:
    https://www.tomsguide.com/news/netge...ter-admin-hack
    https://www.bleepingcomputer.com/new...fi-router-bug/
      • Jul 2011
      • 6046
      It was enabled on both router I did turn them both off and on one of them the traffic meter was on I also turned it off as well
      I was not aware of this issue until you mentioned this issue
      Thanks for the info
      I will also check this out as well because the green LEDs are somewhat dimmer than it was when I first started using it
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8223
        Worked on an ASUS router that used to be stable as a rock. All of the sudden it did strange things, like choppy internet / wifi, hardly can access the login page, etc…
        Fix was a simple firmware downgrade. That all I had to do, not even a factory reset.
        • cubytus
          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
          by cubytus
          Hi to all,
          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
          01-10-2024, 01:26 AM
        • TrueSword88
          Kogan - KALED65XU9220STB - Blue Vertical Line
          by TrueSword88
          Hi all.
          I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
          The line just happens to coincide with the end of COF and start of the next COF (attached).
          The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
          Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
          Hoping to fix...
          05-05-2023, 04:28 PM
        • FALKLAN
          Running Line Voltage and Integrating LED Pods - Automotive
          by FALKLAN
          Howdy everyone! I hope all is well where ever you are!
          I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
          I am uncertain how to convert this line into a switched 12v output line for the LED pods....
          02-05-2025, 12:30 AM
        • mindoverflow
          ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
          by mindoverflow
          hello,
          there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
          I changed pads and thermal paste.
          I run mats test but it is reporting 0 errors.
          I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
          After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
          02-09-2022, 03:22 PM
        • Technomancer
          Nintendo 2DS SD Card Reader issue. Problem on the clock line?
          by Technomancer
          I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
          Here is what I have done so far:
          -Tried SD card in another 2DS and on PC, works great.
          -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
          -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
          06-07-2022, 09:01 PM
