Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
  • Toasty
    • Jul 2007
    • 4171
    #121
    Re: Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
    If the solder does not turn to liquid with your current iron, then you will need one with more watts. Next step up I would recommend would 40w to 45w. I also recommend one that is automatically temperature controlled. I don't know what is available where you are (Brazil?).
    Here's one example, an Aoyue 937:
    http://cgi.ebay.com/AOYUE-937-Digita...-/120545542541
    Always try to get 1 extra tip in around 1/8" chisel tip.
    Toast
    veritas odium parit
    • hernan_perez_br
      • Jan 2011
      • 37
      #122
      Hi, I finally could desolder the capacitors (the iron was not hot enough) and solder the new ones. But unfortunatelly the monitor still does not work (it shows the "acer" logo and then the screen goes black).
      I realised that when I turn it on, there is a yellow light that comes from the tubes, close to the inverter board. this ligth flashes only one second and at the same time I can hear a "click" sound.
      Do you know what it means?
      I have uploaded a 5 seconds video that shows the problem.
      http://www.youtube.com/watch?v=UrVXn96_E5s
      Thank you very much!
      Hernan
      • retiredcaps
        • Apr 2010
        • 9271
        #123
        Hmm, I see you chose not to buy the Panasonic FC and got something called Suntan.
        --- begin sig file ---
        --- end sig file ---
        • Toasty
          • Jul 2007
          • 4171
          #124
          None of Suntan's caps are suitable for this application. They are all general purpose caps and list no ESR or Ripple ratings:
          https://cdn.badcaps-static.com/pdfs/...69d67effe9.pdf
          You -must- use low ESR caps here. You probably just replaced failed caps with new ones that are no better in ratings than the failed ones.
          Where are you getting the caps from? Local store or website?
          Toast
          veritas odium parit
          • Toasty
            • Jul 2007
            • 4171
            #125
            Do you know what it means?....
            It means the inverter controller is sensing an imbalance in the output to the tubes and is shutting down. Experience and the number of complaints seems to point to these being -overly- sensitive to faults.
            That light looked pink not yellow in the video. The fact that it's firing the tubes, means the driver circuits are probably in good shape. You may have a weak tube and the chip sees that as a problem and shuts the unit down. Make sure the start up lighting appears equal along those slots.
            The clicking sounds like a relay, but maybe I'm not hearing what you are.
            Maybe it's the sound of the inverter shutting off?
            Let's go back and start with replacing those caps with the correct ones.
            What was the name and series off the original.
            If you're not sure what I'm asking, just post each line off the old cap and we'll figure it out.
            Toast
            veritas odium parit
            • hernan_perez_br
              • Jan 2011
              • 37
              #126
              Hi Toasty, thanks for reply.
              The light that comes from the tubes flashes when the "acer" logo appears on the screen.
              And the "click" sound is like a relay.
              I have bougth the new capacitors in a local stores (I am living in Australia)
              http://www.jaycar.com.au/productView...T&SUBCATID=859
              I bought them because in the description said low ESR "Capacitor Electrolytic 100uF 35V L/ESR "
              The old ones are:
              "NKCOM" 100uF 35v
              105oC
              F2056
              EVL
              This time I will buy them online, is this capacitor the one I have to buy?
              http://australia.rs-online.com/web/s...uct&R=4491056#
              Regarding the "acer" logo, it is shown 2 seconds when I switch on, and then if I swith off and on, it just flushes half a second.
              Thanks again for reply!
              Hernan
              • Toasty
                • Jul 2007
                • 4171
                #127
                If they had been the Samxon's that are advertised in the picture from Jaycar, you would probably be okay.
                As retiredcaps pointed out, the Panasonic FC is what you need. The one you chose from RS is correct.
                Ahhh... Just a thought here? If you replace the caps and it still does the same thing, the sound you're hearing -might- be a tube connection arcing to the shell. The inverter senses the problem and shuts down. Just a theory. I cannot hear the click on the video other than when you switch it on.
                You'll have to pull the panel apart then, and that's another bag of worms. Many people damage the panel doing that, and trash the monitor.
                Toast
                veritas odium parit
                • hernan_perez_br
                  • Jan 2011
                  • 37
                  #128
                  You are rigth I replaced the caps and it still does the same thing.
                  I have pull the panel apart and I realised some tubes are not in the right position, could you please let me know if the tubes are connected OK?
                  That may be the cause of the problem.
                  Thank you very much!!!
                  • Toasty
                    • Jul 2007
                    • 4171
                    #129
                    Misunderstood.
                    The current caps are -not- correct.
                    What I meant was, once you replace the caps you just replaced with the FC ones from RS, if it does the same thing, then you should take the panel apart.
                    Since you have it apart, inspect those connections. See if there are any places where it may have arced to the panel or penetrated the insulation of either the wire or the connection points. Sometimes there is a bad solder joint, so look closely where the wire is soldered to the tube.
                    Yes, carefully reposition that tube the same as the others.
                    Be -VERY- careful with those panel ribbon wires at the ends and at the top when reassembling the panel. They're easily damaged. Also, remember those connectors have a pop-up release mechanism. Basically a zero insertion force connection. No tension on cable to remove -or- reinsert.
                    Toast
                    veritas odium parit
                    • hernan_perez_br
                      • Jan 2011
                      • 37
                      #130
                      Yes, I misunderstood.
                      I opened the panel and inspected the tube connections, solder joins and all looks OK.
                      I assemble again the panel and it is showing the "acer" logo, which should mean that I have not damaged the ribbon wires.
                      I will order now the panasonic FC capacitors and change them, looks like it is an issue in the inverter board and not in the tubes.
                      Thanks a lot.
                      Hernan
                      • alexanna
                        • Mar 2010
                        • 1346
                        #131
                        Thanks a lot.
                        Hernan
                        Well since you have already had the LCD panel apart down to the ccfl's ,If you haven't already try powering the monitor on and looking closely at each ccfl.See if one or two are giving off the yellow or reddish color.
                        You don't have to have the LCD's ribbon cable hooked up just insulate the pins so they will not touch a ground
                        • hernan_perez_br
                          • Jan 2011
                          • 37
                          #132
                          Hi Alexanna, I have assembled again the LCD panel, so I can not test the tubes. I just had a look to the tubes and the solder joints and all look ok.
                          The yellow or reddish color comes from the tubes in the middle of the screen but only when the "acer" logo is shown, as you can seen in this video: http://www.youtube.com/watch?v=UrVXn96_E5s
                          Thank you very much.
                          • BShanahan14rulz
                            • Aug 2010
                            • 20
                            #133
                            Which MOSFETs you folks been using to replace the p5504edg and the p2804bdg? I saw mention of FDD6690 and FDD6685, do these look viable?
                            • wenter
                              • Aug 2010
                              • 65
                              #134
                              I am looking for replacement parts for the inverter and need your advise. All part numbers are from digikey.
                              Is DMN4015LK3-13DICT-ND or FDD8451CT-ND good replacement for P2804BDG?
                              Is FDD4685CT-ND good replacement for P5504EDG?
                              Are P10294-ND capacitors good for the inverter board?
                              What will be a good replacement for smd fuse F2 marked "M" from digikey?
                              Thanks for help
                              • severach
                                • Aug 2007
                                • 1055
                                First choice: FDD8451 DMP4051LK3
                                Second choice: DMN4030LK3 FDD4243
                                I haven't found a pair that runs as cool as the original Nikos but these do work.
                                sig files are for morons
                                • wenter
                                  • Aug 2010
                                  • 65
                                  #136
                                  Are the capacitors good choice for replacement?
                                  What smd fuse should I use to replace F2?
                                  • wenter
                                    • Aug 2010
                                    • 65
                                    #137
                                    Does anyone know the replacement for fuse F2? It has "M" imprinted on it.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Thanks for help
                                      Tell you what. Provide a decent picture of F2 and the length and I might be able to help you. The meaning of the letter can vary, depending on the manufacturer and series of the fuse.
                                      PlainBill
                                      • wenter
                                        • Aug 2010
                                        • 65
                                        #139
                                        Here is a picture of a "M"-marked F2 fuse. It is about 1mm wide and about 3mm long.
                                        I think somewhere in the thread was information that it is 2A fuse, how do you think?
                                        • alexanna
                                          • Mar 2010
                                          • 1346
                                          #140
                                          Your fuse may be marked with a “W” rather than an “M”
                                          This fuse in the link is rated at 24v volts and is a fast blow to me 4 amps does not seem excessive for an inverter fuse. Do the dimensions match up?
                                          http://search.digikey.com/scripts/Dk...T-ND&x=16&y=19
                                          Please see if we can get someone else to conferm this as a possibility
                                          • black6host
                                            Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                            by black6host
                                            Good day!
                                            I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                            I'm going to replace the caps and I'll be the first...
                                            02-06-2024, 08:22 PM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                            by momaka
                                            03-12-2025, 03:42 PM
                                            Westinghouse L2210NW LCD monitor - bad caps repair
                                            by momaka
                                            Here's another LCD monitor repair: Westinghouse L2210NW.
                                            Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                                            I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                                            Pictures of the monitor outside/case after a brief...
                                            01-11-2021, 01:14 AM
                                          • eryjus
                                            by eryjus
                                            05-10-2023, 11:21 AM
