Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
  • PlainBill
    • Feb 2009
    • 7034
    Re: Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
    As has been mentioned occasionally, one of the more useful pieces of bench equipment is a power supply such as the PS305D; a 30V 5A variable supply. You can apply voltage slowly while monitoring current and avoid letting the magic smoke out of expensive components. They aren't cheap, and the shipping cost will bring tears to your eyes, but they sure are nice to have around.
    PlainBill
    • Lumberjack777
      • Dec 2010
      • 464
      #182
      Originally posted by kehall
      Nice thought but not quite - I need a working monitor to find out what the correct operating current is, and although I've repaired 2 of these already which were just cap replacements, they have now gone, and the only one left (that I get to keep for my troubles!) is waiting for replacement FETs on one side so I can't remove the good side fuse to test as it doesn't stay on long enough for a reading, and doing that where a short caused the blow is a bad idea.
      Does anyone have a monitor they've just fixed and would be prepared to lift the fuse and measure the current so we know for sure rather than all this guesswork?
      I agree with other people saying it does indeed look like an M (straight side strokes) rather than a W (angled side strokes).
      It doesn't help that Bourn's use different codes to other people... i.e. another standard uses J for 1.25A fast blow (Bourn's M), and S for 4A (W with Bourn's - their 'S' is 2A!).
      As a blind man's test I've bought some J's so when the FETs arrive from China (still waiting on them) I guess we'll see if 1.25A is enough to cover operations, if so, I'd suggest everyone with 4A ones replace with 1.25A to ensure continued safe failure condition.
      Regards,
      Keith
      LOL. I fully agree. This is slightly confusing. A picture I saw, and attached, was definitely white fuses with an "M" marking.
      The one I repaired had fuses that were black and I'm 99% sure they were "W". But..... that inverter had been previously repaired, and it's possible the person put the black "W's" in there.
      Please keep us informed if those 1.25A fuses work. For at least a week or so would be a good burn in time. Thanks
      L-J-7
      • kehall
        • Mar 2011
        • 14
        #183
        MOSFETs installed today and installed the "J" 1.25A Fast Blow fuse and works perfectly.
        I would say at this point that 4A is overrated, and indeed they are 'M' marked not W. (I'd have expected 1.25A to be completely underrated and blow immediately otherwise).
        Will soak for next 24 hours.
        Keith.
        • kehall
          • Mar 2011
          • 14
          #184
          Just a final update - the monitor worked perfectly with the replacement 1.25A fuse.
          • jetadm123
            • 2169
            #185
            Interesting, since a lot of other designs use 3-4 amp fuse. Man, why can't these guys just stamp the numerical value on the fuse? Oh yeah, that would be too easy.
            • Chyenne
              • May 2011
              • 14
              #186
              Just registered to share my story with this monitor.I had no experience at all fixing hardware on this level but this thread alone practically got me an almost free LCD. Thank You!
              It had the same problem: 2 seconds acer logo, then no backlight
              1.) replaced all 10 caps with EEUFC1V101B (the original looked fine and the problem persisted)
              2.) tested the mosfets and fuses for continuity
              - one mosfet had continuity between the top and any leg (changed only that one)
              - one fuse was blown (replaced it with a 1.25A fuse which worked for about an hour and blew; then replaced that with a 4A fuse)
              It has been working for a week now.
              If you are living in germany and have, like me, no understanding of the specifications of transistors, tversatzteile.de is selling P5504EDG and P2804BDG.
              I have to say i'm very impressed by the quality of this forum and this little project won't be the last
              • opperhoof
                • May 2011
                #187
                I have an AL2416W as well which almost exploded. It was running, and out of nowhere a hard BANG or PLOF. Screen still running, so I was looking around in my room what just broke. Than 10 seconds later an other bang, and the monitor went black.
                When I press the power button the ACER logo appeared very soft. When I connect my laptop to the screen it does not diplay any image. (not even as soft as the logo).
                Then I opened it up. The top 4 caps which are glued together were broken. The bottom came out. I replaced those with 100uF antel caps and a the fuse f3 was broken as well so I replaced that one with a 1.25A fuse.
                When I power on the monitor the screen stays black. Not even a ACER-logo. I hear a small tick somewhere around the connector of the 4th ccfl.
                If I power up the monitor with the inverter board disconnected I still don't see the acer logo appear, but the click is obvious gone.
                What to do now?
                • alexanna
                  • Mar 2010
                  • 1346
                  #188
                  After your repair and testing are all the inverter fuses still good?
                  • opperhoof
                    • May 2011
                    #189
                    Yes they are.
                    I can buy a new inverter board for just 30 euros (like 50 USD). But how can I test if my screen works with the new inverter? Should my screen produce a picture without inverter board?
                    • alexanna
                      • Mar 2010
                      • 1346
                      #190
                      I would say yes there should be an image, however on some monitors it can be difficult to see.
                      If you do not have a way to power on at least one of the backlights to check for an image, you might try playing a movie you may be able to get some type of indication is its working
                      • opperhoof
                        • May 2011
                        #191
                        There is indeed an image. Very dark, but with a flashlight I can see it, so I think I am gonna buy the new inverter board.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #192
                          See if the mosfets on the inverter board are shorted or not.
                          --- begin sig file ---
                          --- end sig file ---
                          • alexanna
                            • Mar 2010
                            • 1346
                            #193
                            It would probably be a good idea to verify you have 24V going to the inverter
                            • opperhoof
                              • May 2011
                              #194
                              Where can I measure that? (i.e. which wires are + and -?)
                              • alexanna
                                • Mar 2010
                                • 1346
                                #195
                                A screw that attaches the inverter board to the monitors metal frame work would be your ground.
                                The supply voltage is going to be different but this link should give you a idea what to look for and how to test, just be very careful when you measure
                                http://www.lcdparts.net/howto/U_PIN.aspx
                                When you use the ohmmeter have the inverter unpluged an no voltage supplied
                                • fa28
                                  • Jan 2010
                                  • 6
                                  #196
                                  Where can I get a 1.25A 24v fuse the same size to replace the M fuse, (3.20mm x 1.60mm x 0.60mm). I ordered one from digikey and didn't check the size and it was (1.00mm x 0.50mm x 0.40mm). Searching again, all the 1.25A 24V fast smd fuses seem to be this small, same at Mouser.
                                  • jetadm123
                                    • 2169
                                    #197
                                    1) go to digikey.com and type in "1.25V 1206 fuse" and click search
                                    2) click on the "fuses" link
                                    3) at bottom of page, click on "view page" button. A listing of the available fuses will appear. Choose something that's fast blow, 32V or above (since the input voltage is at 24V).
                                    • singion
                                      • May 2011
                                      #198
                                      hi guys
                                      found this place a few days ago after looking for a fix for my screen
                                      the story so far is about a week ago while using the screen i saw a puff of smoke come from the top and the left side went darker than the right
                                      so i opened it up and 1 p5504edg was fried and also bad caps at least 7 bottom bulged
                                      i have replaced all the caps and also replaced all the p5504's and the p2804's
                                      turned screen on and it worked fine fixed
                                      but there was a loud buzz coming from the back , i then went into the onscreen menu and changed the setting
                                      the one to the left of movie ( graphic i think option was) and suddenly the screen went blank and i am now stuck with this issue.
                                      i get about 2 second of picture hear a tiny click and screen goes blank
                                      do i now need to try and change these "m" fuses
                                      yours Singion
                                      ps first time i fixed something at this lvl so my solder work ant great should i try resoldering any else first
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #199
                                        "2 seconds to black" is documented in posts #13 and #14 at
                                        https://www.badcaps.net/forum/showthread.php?t=10419
                                        Concentrate on
                                        1) bad caps especially if you did not replace all the electrolytic caps or used the wrong ones
                                        2) poor soldering
                                        3) bad inverter transformer
                                        4) bad ccfl and/or wiring
                                        • singion
                                          • May 2011
                                          #200
                                          got the screen on again and the nasty buzz apears to be coming from the p2804 next to the p5504 that blew up (replaced all so the new one is noisy) old one i presume was also noisy as the buzz was present before)
                                          this is what i purchased
                                          http://www.chsinteractive.co.uk/elec...nce-8x11mm.htm
                                          will try and resolder my caps a bit better
                                          Cheers Singion
                                          • black6host
                                            Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                            by black6host
                                            Good day!
                                            I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                            I'm going to replace the caps and I'll be the first...
                                            02-06-2024, 08:22 PM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                            by momaka
                                            03-12-2025, 03:42 PM
                                          • keepread
                                            Dell monitor PSU vs Dell laptop PSU
                                            by keepread
                                            Hi there!
                                            Someone gave me their old monitor, it's Dell S2715ht.
                                            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                            10-30-2025, 04:45 PM
                                            Westinghouse L2210NW LCD monitor - bad caps repair
                                            by momaka
                                            Here's another LCD monitor repair: Westinghouse L2210NW.
                                            Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                                            I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                                            Pictures of the monitor outside/case after a brief...
                                            01-11-2021, 01:14 AM
