Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
  • dt2rz
    • Oct 2010
    • 30
    Re: Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
    It looks domed in that picture but actually there are no domed caps on any of the boards. Sorry, camera is not so good.
    • mathog
      • Mar 2010
      • 2655
      If the electrolytic caps in the secondary part of the power supply are any of the known bad brands replace them anyway. (Unless you have an ESR tester and can verify that they are within specification in situ.)
      Also, if you have a known good CCFL with the same type connectors use it to replace the tubes in your monitor one by one. Specifically, plug that tube from the "good" display board into the socket on your inverter board, and leave the corresponding "test" lead on your Acer board hanging loose. (Don't take the panels apart and swap the tubes, at least, not yet!) All it takes is one CCFL that is too old to cause these symptoms. Unless you are very unlucky only one tube will have aged that far, so by systematically replacing all of them you can eliminate that possibility. or identify the bad tube.
      • dt2rz
        • Oct 2010
        • 30
        Power board is fitted with rubycon caps. I don't have any spare items (CCFL)
        to test further. I borrowed a DMM from a friend of mine and I wanted to test
        the power board outputs. How can I go about testing for the power outputs?
        • mathog
          • Mar 2010
          • 2655
          Rubycon is one of the better brands. Even so, read the numbers off the cans and look up the specs for this particular set. Or post the numbers here.
          Before you do anything else you need to verify that +5 and +12V on the power supply board are good. There may be some test points available, for instance, the legs of the capacitors, if you can reach them. If not, there are some unused through holes on the power supply board. If you follow the traces on the back you can probably find empty pads that are at ground (definitely) and +5 and +12V (probably). Solder bits of wire to the pads on the back, through the holes, to bring the voltage points to the top of the board, then you can put the DIMM on those after you wire everything back together like it was in your first posted picture, but without the power supply shield. The +12V supply may not be regulated all that well but should be >= 12V (it could be 13, for instance). The +5V should be very close to 5V. This will only be in the few seconds from turn on until the screen blanks. After that these voltages will drop.
          It would really help if you could scrounge up one more good CCFL somewhere. You can waste a lot of time trying to debug the electronics when they are working properly and a bad CCFL is at fault. Also, there are 6 CCFLs in that display, so more chances to go wrong. If any one of those 6 is bad you would see what you see. Some people have been successful with the cheap CCFL light kits from Fry's and elsewhere (around $10). In both directions, testing the CCFL tubes with the light kit inverter, and testing the inverter with the light kit CCFL tube. Problem is, the kit sockets never match up with those in the LCD display. If you want to spend real money, lcdparts.net has a couple of inverter testers, one is around $100 and the other $37. I do not know how well they work since I have never used either one.
          • babiloof
            • Oct 2010
            Hi everyone! :> This forum is awesome, helpded me alot...
            Anyway I also have this monitor, and i would like your advise...
            First the backlight didnt work then i replaced 4 caps that looked to be faulty.
            Then the backlight worked but the left side of the screen is darker and i can hear a noise :o
            Originally posted by bonney
            If Q5 and Q6 are weak they give you half brightness on the left side same if you dont use P5504EDG P2804BDG
            Should i replace them ?
            Should i replace any other caps ?
            Maby the backlight is broken ?
            • bonney
              • Oct 2008
              • 74
              #26
              Hi change all 10 caps first
              • dt2rz
                • Oct 2010
                • 30
                #27
                This is where i'm at right now. Just waiting for the caps i ordered from Digi-key and give it a try.
                • gybruss
                  • Oct 2010
                  • 5
                  #28
                  Acer AL2416W
                  Inverter TDK P/N TBD292LF
                  10 capacitors 100uf 35v miniature
                  Fuse F2 marking M
                  Q4 faulty P2804BDG
                  Q6 can go faulty P5504EDG
                  Q3 faulty P2804BDG
                  Q5 can go faulty P5504EDG
                  Hi, i replace the 10 caps, found f1 is blown, witch of the Q do i need to replace?
                  Can anyone tell me where to buy these parts?
                  thanks
                  • bonney
                    • Oct 2008
                    • 74
                    #29
                    You need to replace Q3,Q4 Niko-Sem P2804BDG Q5,Q6 Niko-Sem P2804BDG and the fuse
                    • gybruss
                      • Oct 2010
                      • 5
                      #30
                      Thanks, bonney,
                      juste to be clear , you said the same part numer for all the 4Q's on the last reply? Is there a part number for the fuse? noobee here on ordering parts, and i need a store where to order the part, i live in canada, so a canadian site if you happen to know one?
                      thanks
                      • bonney
                        • Oct 2008
                        • 74
                        #31
                        Yes my mistake
                        Q5,Q6 Niko-Sem P5504EDG
                        • dt2rz
                          • Oct 2010
                          • 30
                          #32
                          Replaced the following parts on the inverter board:
                          -10 caps with 100uf 25v 85*c 2000 hour Chemicon SMG
                          -Q3 & Q4 with FDD6690, i can't find original P2804BDG
                          -Q5 & Q6 with FDD6685, i can't find original P5504EDG
                          Result is still the same. I tried checking the CCFLs one by one and all are
                          lighting up fine. Can somebody guide me in testing the power supply. Here
                          are some more pics of the power supply...
                          • bonney
                            • Oct 2008
                            • 74
                            #33
                            on your inverter there are two fuses have you power to them ?
                            • bonney
                              • Oct 2008
                              • 74
                              #34
                              PIN NO. Function Function
                              1 +24Vcc Inverter Vcc
                              2 +24Vcc Inverter Vcc
                              3 +24Vcc Inverter Vcc
                              4 +24Vcc Inverter Vcc
                              5 +24Vcc Inverter Vcc
                              6 GND Inverter GND
                              7 GND Inverter GND
                              8 GND Inverter GND
                              9 GND Inverter GND
                              10 GND Inverter GND
                              11 N.C N.C
                              12 Backlight
                              on/off
                              Backlight On/Off control signal, connected to CNS1#11
                              13 Dimmer Brightness control, connected to CN1#12,bright
                              max.=3.3V,min.=0V.
                              14 N.C N.C
                              they are the connectors to your inverter
                              • dt2rz
                                • Oct 2010
                                • 30
                                #35
                                Thanks bonney! The 2 fuse on the inverter board are ok. I'll post results after
                                checking.
                                • dt2rz
                                  • Oct 2010
                                  • 30
                                  #36
                                  Here are the results i got:
                                  1 +24Vcc Inverter Vcc ====== 23.9V
                                  2 +24Vcc Inverter Vcc ====== 23.9V
                                  3 +24Vcc Inverter Vcc ====== 23.9V
                                  4 +24Vcc Inverter Vcc ====== 23.9V
                                  5 +24Vcc Inverter Vcc ======= 23.9V
                                  6 GND Inverter GND
                                  7 GND Inverter GND
                                  8 GND Inverter GND
                                  9 GND Inverter GND
                                  10 GND Inverter GND
                                  11 N.C N.C
                                  12 Backlight on/off ====== 2.7V
                                  13 Dimmer Brightness control ====== 2.5V
                                  14 N.C N.C
                                  Here's for the logic board:
                                  1 +5Vstb ======= 5V
                                  2 GND
                                  3 GND
                                  4 GND
                                  5 +5Vcc ======= 5V
                                  6 +5Vcc ======= 5V
                                  7 +5Vcc ======= 5V
                                  8 +12Vcc {audio power (n/a option)}
                                  9 GND
                                  10 Power on ======= 2.7V
                                  11 Backlight on/off ======= 2.7V
                                  12 Dimmer ======= 2.5V
                                  • bonney
                                    • Oct 2008
                                    • 74
                                    #37
                                    I'm not sure a like your transistor's double check the data sheets
                                    have you tested the old ones?
                                    • dt2rz
                                      • Oct 2010
                                      • 30
                                      #38
                                      No i can't because i burnt the transistors while removing them from the board
                                      with the soldering iron. Nothing changed with the issue after replacing the parts
                                      so maybe the problem is somewhere else?
                                      • bonney
                                        • Oct 2008
                                        • 74
                                        #39
                                        looks like you have to go to ebay
                                        • dt2rz
                                          • Oct 2010
                                          • 30
                                          #40
                                          Yeah i guess that's the next hard step, finding expensive discontinued parts
                                          Thanks for trying to help though.
                                          • black6host
                                            Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                            by black6host
                                            Good day!
                                            I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                            I'm going to replace the caps and I'll be the first...
                                            02-06-2024, 08:22 PM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                            by momaka
                                            03-12-2025, 03:42 PM
                                          • keepread
                                            Dell monitor PSU vs Dell laptop PSU
                                            by keepread
                                            Hi there!
                                            Someone gave me their old monitor, it's Dell S2715ht.
                                            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                            10-30-2025, 04:45 PM
                                            Westinghouse L2210NW LCD monitor - bad caps repair
                                            by momaka
                                            Here's another LCD monitor repair: Westinghouse L2210NW.
                                            Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                                            I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                                            Pictures of the monitor outside/case after a brief...
                                            01-11-2021, 01:14 AM
