Samsung Syncmaster 245BW
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    #241
    Re: Samsung Syncmaster 245BW
    I believe it's fine to post links here. Anyway a 5W resistor in that spot isn't going to get too hot but 70C is a low operation temp for a power resistor so you did good.
    A working TV? How boring!
    • antok86
      • Feb 2011
      • 15
      #242
      okay my monitor displays real quick then goes black. i can see my computer and the OSD real quick then it goes black and the blue light stays on. i got it torn down and i dont see any bulging caps or melted resistors. what can i check next/
      • antok86
        • Feb 2011
        • 15
        #243
        i took RB805, RB806, & RB807 out to measure and they all read at about 68 ohm
        • PlainBill
          • Feb 2009
          • 7034
          Post pictures of the power supply / inverter board, or list the brands and series of the caps. The most likely cause of the problem is bad caps. I know you don't think any are bulging, but I've heard that story before.
          The next suspect is the CCFLs. A broken wire, broken tube, or bad transformer will do it too.
          PlainBill
          • antok86
            • Feb 2011
            • 15
            #245
            • PlainBill
              • Feb 2009
              • 7034
              Oh, Farkle!! I forgot to mention 'Do not post inline'. Retiredcaps will kill me.
              I need a picture of the left 1/3 of the inverter, please. And as high resolution as possible. I really need to see the detail of at least two transformers and the board above and below them. Do not post it inline, attach it using 'Manage Attachments'.
              PlainBill
              • antok86
                • Feb 2011
                • 15
                #247
                it wont let me edit! =(
                • PlainBill
                  • Feb 2009
                  • 7034
                  I know. People were editing posts to change suggestions, etc. so Topcat put a 10 minute limit on editing.
                  ANYWAY, I got my head out of the nether regions and realized the very first post in the thread has adequate pictures of the inverter. I know you can take better, but that isn't necessary unless my instructions are too confusing.
                  Most boards have an orientation. In the case of the inverter, I call the edge with the connector to the power supply as 'down', the edge with the connectors to the CCFLs as 'up'. Conveniently, most of the printing is oriented in that direction.
                  When the board is oriented that way, T1 is located at the upper left, T12 at the upper right. I don't see any clear indication of numbering for the transformer pins, so I will arbitrarily say that the pin in the upper right corner of each transformer is pin 1. (Notice that pin is actually two pins soldered to the same pad.) That pad is connected to the CCFL connector. Pin 2 will be on the bottom right, and numbering continues clockwise. Pin 9 is another double pin and is at the upper left.
                  Pins 5&6 and 7&8 are obviously the ends of the primary winding. Pins 3&4 apparently do not connect to anything. Set your DMM on the 2K ohm scale and measure the resistance between pin 1 and pin 2 of T1. I would expect something in the 1000 ohm range. If it appears to be open, try between pins 1 and 3, 1 and 4, and 1 and 9. If you don't get any reading, increase to the 10K ohm range. If still no luck, try T2.
                  IF I was right about pins 1 & 2, measure the resistance between pins 1 and 2 of each transformer, and report the results. The readings should match to within 3%.
                  PlainBill
                  • lamouche1
                    • Feb 2011
                    • 12
                    similar problem here with a 245bw for now no 24v no 5.3v rb805 reads open i'm digging in it for now to find something else burned qm802 reads good.
                    • lamouche1
                      • Feb 2011
                      • 12
                      fixed i replaced all the 68ohms resistor by new ones everythings fine now thanks alot
                      • antok86
                        • Feb 2011
                        • 15
                        #251
                        Code:
                        Thanks bill I'll try to follow your instructions when I get home
                        Can I use 68ohm 1/5 watt resistor?
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Code:
                          @##%#$%@!!! Different problem!!! You have 'Two Seconds to black'. They have a dead 24V supply.
                          PlainBill
                          • antok86
                            • Feb 2011
                            • 15
                            #253
                            i know...but i took out my resistors to measure and i dont know if i can put the original resistors back in. And i can get 68 ohm 1/2 watt locally
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              #254
                              Well, the originals were 1 watt as the other members described. And they burned. What do you think will happen to 1/2 watt ones?
                              • antok86
                                • Feb 2011
                                • 15
                                #255
                                Originally posted by plainbill
                                i know. People were editing posts to change suggestions, etc. So topcat put a 10 minute limit on editing.
                                Anyway, i got my head out of the nether regions and realized the very first post in the thread has adequate pictures of the inverter. I know you can take better, but that isn't necessary unless my instructions are too confusing.
                                Most boards have an orientation. In the case of the inverter, i call the edge with the connector to the power supply as 'down', the edge with the connectors to the ccfls as 'up'. Conveniently, most of the printing is oriented in that direction.
                                When the board is oriented that way, t1 is located at the upper left, t12 at the upper right. I don't see any clear indication of numbering for the transformer pins, so i will arbitrarily say that the pin in the upper right corner of each transformer is pin 1. (notice that pin is actually two pins soldered to the same pad.) that pad is connected to the ccfl connector. Pin 2 will be on the bottom right, and numbering continues clockwise. Pin 9 is another double pin and is at the upper left.
                                Pins 5&6 and 7&8 are obviously the ends of the primary winding. Pins 3&4 apparently do not connect to anything. Set your dmm on the 2k ohm scale and measure the resistance between pin 1 and pin 2 of t1. I would expect something in the 1000 ohm range. If it appears to be open, try between pins 1 and 3, 1 and 4, and 1 and 9. If you don't get any reading, increase to the 10k ohm range. If still no luck, try t2.
                                If i was right about pins 1 & 2, measure the resistance between pins 1 and 2 of each transformer, and report the results. The readings should match to within 3%.
                                Plainbill
                                readings from 2k setting
                                t1- 1191
                                t2- 1185
                                t3- 1178
                                t4- 1195
                                t5- 1189
                                t6- 1190
                                t7- 1181
                                t8- 1181
                                t9- 1191
                                t10- 1187
                                t11- 1180
                                t12- 1181
                                • antok86
                                  • Feb 2011
                                  • 15
                                  #256
                                  i noticed this...not sure what it is or if something was supposed to be there. monitor was never opened
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    #257
                                    It looks like a pot covered with goop. Manufacturers frequently do that.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      t1- 1191
                                      t2- 1185
                                      t3- 1178
                                      t4- 1195
                                      t5- 1189
                                      t6- 1190
                                      t7- 1181
                                      t8- 1181
                                      t9- 1191
                                      t10- 1187
                                      t11- 1180
                                      t12- 1181
                                      The numbers indicate the transformers are probably not shorted.
                                      What brand (and value) are the 4 yellow caps on the inverter?
                                      PlainBill
                                      • antok86
                                        • Feb 2011
                                        • 15
                                        #259
                                        PlainBill
                                        says "SAM YOUNG" 220uf 35V
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          Replacing those are the next step. From Digikey P12411-ND Panasonic EEU-FM1V221 would be my suggestion.
                                          PlainBill
                                            09-07-2024, 05:50 AM
                                          • soopacrucial
                                            Samsung Syncmaster 740BF repair
                                            by soopacrucial
                                            Hi folks,
                                            I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                                            Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                                            10-29-2024, 02:40 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
