Viewsonic VP201s
+ More Options
Posts
  • Wrog
    • Oct 2009
    • 472
    Viewsonic VP201s
    Hi all, excellent forum and resource here, thanks to everyone who shares their knowledge and experience! I've had a great time reading through the many threads and learned more than I ever expected. Here's the situation:
    Viewsonic VP201s powers up to a black screen (green power LED is on).
    Cracked open the monitor and found the following:
    1. Power supply area seems fine, Nichicon caps. None that I can see are bulging or leaking. Did not test output voltage levels of the power supply (18V).
    2. Tested the inverter fuses, and found F1 to be blown (F2 was OK). Local shops don't carry 63V/2A surface mount fuses, but did have a 2A pico fuse that I can solder in its place. The caps on the inverter board are Rubycon and physically appear to be fine.
    3. In the mainboard area, there is a lot of what looks like some sort of rust-colored substance (maybe corrosion?). I've highlighted in red areas that seem to be the worst, like around the screws and IC954. I haven't taken the board off to check the bottom to see what that looks like yet to find the source.
    I'll post back later with more details, but if anyone has suggestions on what the substance could be in the picture, I'm interested in finding out what caused F1 to blow in the first place to prevent it from occurring again (even if replacing the fuse ends up working). Thanks for any input.
  • Wrog
    • Oct 2009
    • 472
    Re: Viewsonic VP201s
    Update: The bottom of the mainboard is more of the same rust-colored "corrosion" that can be scraped away by fingernail. It's particularly concentrated around the connector to the inverter and also by the DVI connector (marked with red rectangle). Guidance on the direction to go to troubleshoot this would be great, unless I should just replace the fuse and fire it up! Looking at IC954 (first picture above), I'm going to guess this is a big problem and it likely needs to be replaced (it's virtually covered in the rusty stuff).
    • PlainBill
      • Feb 2009
      • 7034
      The inverter fuse blowing for no obvious reason is fairly common on these monitors. I used a variable power supply to apply power slowly before replacing the fuse. Alternate approach is to check for shorted transistors before applying power.
      PlainBill
      • EGuevarae
        • Nov 2008
        • 1336
        The inverter fuse blowing for no obvious reason is fairly common on these monitors....
        Also clean the corrosion-like brown thing as it can cause problems.
        Resolder the inverter's transformer and all suspected points on the inverter.
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • Windows 10 Pro x64
        • GeForce GT1050
        • ecking767
          • Oct 2009
          • 492
          Clean your board with alcohol, an old toothbrush and a rag.Soak the rag with alcohol and place the rag over the board and then gently brush on top of the rag clean the board where you have soak the alcohol. repeat if necessary. your board will be nice and clean looking !!!
          • Wrog
            • Oct 2009
            • 472
            Thanks everyone for your input, looks like I have some work to do. A friend of mine gave me a Gateway FPD2185W to look at so I've got that cracked open too. I'll likely have questions about that one I'm sure.
            • Wrog
              • Oct 2009
              • 472
              Chalk up another success story! Replaced surface mount fuse F1 on the inverter and it fired right up. The replacement fuse part I ended up using was Digikey P/N F1457CT-ND, which is a Littelfuse 0466002.NR 63V 2A Fast Acting 1206. The toughest part was getting the darn thing open (that, and waiting 4 days for the parts to arrive!)
              Thanks again everyone for your help. Now on to the Gateway FPD2185W...
              • Moving Target
                This is my first post on this forum and I would like to compliment the administrators and members on the quality of the posts and information residing here. I have a similar problem to that mentioned by Wrog. I have twin Viewsonic VP201s monitors that have worked well for over five years. One started "timing out" after a while (black screen and no power on LED light). If I shut it off and waited a minute or two it would turn back on and run for another hour or two. I started relying on the other monitor until it just blacked off with the LED still lit. I have taken both units apart and managed to make one work by switching the inverter board from the "intermittent" monitor to the one that shut off but retained the LED power light. Given the info in this and other threads on the site, it is likely that one or both of the inverter board fuses are bad. I would rather replace one or two fuses than spend $100 for a new board for a 6 year old monitor. Does anyone have pictures that identify the inverter board fuses? Is the part number that Wrog specified the one to use and where might I order them? If and when I get the inverter board fixed can someone give me a possible diagnosis for the intermittent power off problem? The capacitors on the board all look good and I'm not sure where to start. All advice and counsel would be appreciated! Thanks, Moving Target
                • selldoor
                  Slow Learner
                  • 7870
                  Hi - The fuses will be marked F1 F2 on the inverter board, If you post a picture of your board I can mark them on it for you.
                  Do you have a multimeter?
                  • Rtech
                    • Jul 2010
                    • 1095
                    The intermittent Power off, could either be Power Supply OR main Board,so you will need to identify which one is Faulty, as you have 2 of the same type,then by switching over the working inverter board,and then substituting the Power Supply and Logic in turn you can identify the fault down to the correct board,and then move on from there.
                      Is this the board you have? The Green PICO Fuse.
                      http://s807.photobucket.com/albums/y...onic%20VP201B/
                      • Moving Target
                        Gentlemen - Thanks for the quick replies. I'll need to get the bad inverter board back from an acquaintance that was looking it over so I can take some photos, but it appears to be the same board that is seen in Budm's pictures. Is the fuse that is the possible problem the green component on the left side of the board?
                        Budm - Great shots of the case dis-assembly and the components. I figured out how to open the monitors with no damage myself, but if I had seen your pictures they would have spared me a lot of apprehension.
                        selldoor - I do have an inexpensive multimeter. Will that work?
                        Rtech - I switched the inverter board from the unit that was having intermittent power problems to the unit with the bad board. Now that monitor is up and running and is not shutting down. It appears that the intermittent problem is not on the inverter board as you imagined. I'll have to do some more testing with the second monitor, but how difficult is it to diagnose a problem with the power supply or main board and fix it? Will the expense mean it would be wiser to retire it?
                        Thanks again for your shared experience.
                        • selldoor
                          Slow Learner
                          • 7870
                          An inexpensive meter will do fine as long as it measures volts and ohms and is
                          fairly accurate.
                          Yes its the green torpedo where it says F1.
                          I think what Rtech means is that even when you change the fuse, if the set made up of possibly faulty boards does not work, you will still not know if the fault is Inverter Board or the power board. You can reduce the amount of testing by trying the inverter board back in the monitor that now works, as if it does it may the power board that is faulty. (or main board)
                          Similarly if you have not tried already you could try the Power board and indeed
                          the main board and so determine which board or boards are faulty.
                          We can then advise on some quick easy tests to determine if its an easy fix,
                          so its too early now to retire any board.
                          • pepinlady06
                            • May 2013
                            • 10
                            • usa
                            I have a question about the viewsonic vp201s inverter board can someone help me plz
                              What kind of questions? Which version of VP201S do you have? Pictures of the boards, etc?
                              • pepinlady06
                                • May 2013
                                • 10
                                • usa
                                don't know how to post a picture of it on the back it says delta 2994721100 dac - 18B013 and there is no green pico fuse on it
                                  So, what are you looking for? What is the question? Does it have label on the board like F1?
                                  Here is how to post the pictures:
                                  https://www.badcaps.net/forum/showthread.php?t=1868
                                  • pepinlady06
                                    • May 2013
                                    • 10
                                    • usa
                                    well it powers on but no picture and there is a small brown spot on the back of the inverter board don't if that's the problem should i replace this one?
                                      You need to find out if you do have power supply voltage feeding the inverter board or not by measuring the DC voltage on the both ends of the fuse using the chassis as the Ground ref point, also need to find out if the inverter board also getting the BL_ON (INV_ON) signal or not.
                                      • pepinlady06
                                        • May 2013
                                        • 10
                                        • usa
                                        here is a picture don't know good it is
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • jshhh
                                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                          by jshhh
                                          Hi guys,
                                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                          Anybody know how to remove this type of fuse?
                                          (The fuse is toward the bottom of the image labeled F2)...
                                          06-17-2025, 01:35 AM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
