Viglen CRT monitor intermittent jumping
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    Re: Viglen CRT monitor intermittent jumping
    Originally posted by R_J
    I would try replacing C318 and the other small elec. next to it
    Ive ordered a full set of the lower voltage (Non PSU) caps incluing the 100uf 25v C318 and all the others. Might as well replace these while I can get to them.
      • 30977
      MAME has expanded to emulate vintage pc's and home computers - even sat recievers (to a degree)
      it merged with MESS.
      • roadrash
        • Oct 2015
        • 490
        • U.K.
        Just replaced all these caps. Are these ones i took out a good make? But i was short of one 470 110v so had to use a 16v one. I'm sure I read that its ok to use a higher voltage. Just to put together and test it now.
        • R_J
          • 9535
          I hope you ment 10 volt not 110v and yes 16 volt will work just fine for a 10 volt.
          • roadrash
            • Oct 2015
            • 490
            • U.K.
            Some good news and some bad news here... Ive just had it powered up and it seemed to be ok, tube heater all lit etc no smells no smoke hahahha. Then I hooked it up to the computer to check the picture and if its jerkin/jumping still. But there was no picture. I immediately removed the PCB again to check everything even though I had spent a long time after finishing it just checking every joint again and double checking all caps were in the right polarity. When I checked all seemed ok again but then I noticed one of the off cuts from a cap was magnetically stuck to the PCB. I cant believe this and I was so careful to put all these in the bin. I checked my bench was clean as well after finishing. Anyway I am so sad that after being so careful its spoilt. I hope it can be rectified even if I have to replace every IC.
            Damn I feel gutted, just shows you can never be too careful. Now where do I start checking? It might not have been that off-cut and maybe could be a bad NEW cap. Should I check them before fitting them?
            ps. Yes RJ i did mean 10v hahha
            • R_J
              • 9535
              I would always change a few caps at a time, then check the operation,
              Does the monitor have high voltage? if it does, turn the screen control up a bit (located on the flyback) and see if you get a raster.
              Check if you have the 115 volt screen supply on the neck board (it is marked)
              Where was the cutoff attached?
              The only component I know of that is magnetic is the horizontal linarity coil located near the yoke connection.
              Check that all the plugs are connected back correctly
              Sometimes people question the usefullness of a scope, this would have been the perfect time to use it to locate the jumping video problem and replace only the bad component.
              • roadrash
                • Oct 2015
                • 490
                • U.K.
                #27
                I will remember that in future.
                [Quote]Does the monitor have high voltage? if it does, turn the screen control up a bit (located on the flyback) and see if you get a raster.[quote]
                How do i know if high volts are there? I hear static crackle when i power it up. Still not sure where screen control is (still learning here).
                Yes it is. It did get detached and unsoldered during removing a cap but i resoldered it back.
                I cant temember know and wish i took a photo.
                All are connected
                Might have to find one if i am going to fix a lot of crt's.
                • roadrash
                  • Oct 2015
                  • 490
                  • U.K.
                  #28
                  Talking of a scope, until I can find a good quality scope would one of these little hand scopes make do?
                  Review here:
                  https://www.elektormagazine.com/news/review-mini-scope
                  • R_J
                    • 9535
                    Here is a picture that might help locate the screen control.
                    By turning up the screen control it should display a white raster, that will indicate you have High voltage, and horzontal and vertical deflection.
                    If you have those, then the loss of video is in the video signal path somewhere. Make sure the transistors or ic's in the signal path have voltage, maybe the short took out a supply resistor for one of the low voltages
                    Do you have any voltage on R219 for example?
                    I have marked what look like voltage regulator ic's and a couple resistors, If those are regulators, do they have there voltages in and out?
                    I have never used one of those scope boards, It might be ok for audio or low frequency data, (its only 200Khz) It might work for tracing the video signal.
                    • roadrash
                      • Oct 2015
                      • 490
                      • U.K.
                      #30
                      Yes have a raster when U turn it up a bit
                      R219 has 8.4v and the other resistor you marked has 18.4v
                      One IC has 4.93v at one leg and the other 11.88v
                      I was wondering do I have to have the CRT connected to the PCB to check these sort of voltages? Its was a bit tricking getting into some of those bits without touching something else by accident or getting a shock which I did a bit. I will put some rubber gloves on I think next time. haha only a little kick nothing that would kill you or shock your heart into starting again..lol....
                      • roadrash
                        • Oct 2015
                        • 490
                        • U.K.
                        #31
                        oscilloscope wise would that cheap one get up by because if not I can get a scope like this one here which is only 50 miles away from me:
                        https://www.ebay.co.uk/itm/tektronix...ezj:rk:50:pf:0
                        Its whether I will get the use out of it to justfy spending 40 odd pounds or more for it by the auction end plus fuel getting it. I would love a scope but would i ever use it enough. If the cheap one would suffice its not such a big outlay.
                        • R_J
                          • 9535
                          If I was working on it I would connect the crt, and lay the monitor on its face or its side so I could access the botom of the board.
                          I marked two ic's, I suspect one you measured 4.93v is likely a 5 volt regulator that syupplies the ic's in that area. The other ic I marked also looks like a regulator as it has the center pin at ground.
                          Without a scope how can you tell where the video signal is being lost? Did you connect another monitor to be sure you have a signal?
                          That scope you linked to would work fine, just make sure the trace is nice and bright.
                          If the trace is dim its worth nothing.
                          I took your picture number 20181015_123005 and flipped and rotated it. that way the components match the bottom picture 20181015_205603. then with them side by each you can figure out what components connect to the traces.
                          My scope is always on my bench, I use it on almost every job I do. I use it for tracing audio & video signals, checking the ripple in pwer supplies, checking lvds signals in lcd monitors.
                          I rarely pull caps to check them, I check the circuit with the scope and if the cap. is bad I will see lots of ripple, then I can check it or replace it. If the caps job is for coupling a signal I would hope to see the same signal on both sides, if one side was low I would suspect the cap was bad.
                          • petehall347
                            • Jan 2015
                            • 4426
                            • United Kingdom
                            #33
                            on all crtv.s i remember working on the board slides out to work on . always had a mirror set up so i could see the screen . to access solder side i might turn the unit upside down and screen towards the mirror .
                            • R_J
                              • 9535
                              I should also mention, make sure the CRT ground strap is always connected to the chassis, and there should also be a ground connection to the crt board. you do not want the crt floating at 15-20kv.
                              You can leave the degausing plug disconnected if you need to
                              • petehall347
                                • Jan 2015
                                • 4426
                                • United Kingdom
                                #35
                                just remembered my neon screwdriver was my friend with crt .
                                • roadrash
                                  • Oct 2015
                                  • 490
                                  • U.K.
                                  #36
                                  Re the scope.. I have a choice of 3 that I can get.
                                  I prefer ths one (a tekronix) but depends on what it sells for;
                                  https://www.ebay.co.uk/itm/tektronix...z/273511259703
                                  Next one is this one a GOULD ADVANCE:
                                  https://www.ebay.co.uk/itm/GOULD-Adv...y/153227035640
                                  and finaly this ISO-TECH but is a 20mhz bandwidth ok?:
                                  https://www.ebay.co.uk/itm/ISO-TECH-...g/153226078874
                                  are all of these useful to help repair CRT monitors etc?
                                  • roadrash
                                    • Oct 2015
                                    • 490
                                    • U.K.
                                    #37
                                    Just bought this beauty. Collecting it tomorrow.
                                      • 30977
                                      looks familiar - similar to a telequipment d83.
                                      what is it?
                                      • R_J
                                        • 9535
                                        Now remember if you are going to use it to repair a smps or when connecting to the hot side of any chassis an isolation transformer must be used.
                                        • roadrash
                                          • Oct 2015
                                          • 490
                                          • U.K.
                                          #40
                                          Ive got it but have to wait until friday to use it a no probes. Is a isotech iSR440. Nice bright display. Attachef some pictures. What do you think?
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • wattage
                                            AOC AG493UCX 49-inch monitor - Firmware request
                                            by wattage
                                            Hello Badcaps Community,
                                            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                            Yesterday, 04:41 PM
                                          • ant3202
                                            HP 27es - LED monitor - Monitor Flashing On - Off
                                            by ant3202
                                            Hi Everyone
                                            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                            https://www.badcaps.net/forum/troubl...lashing-on-off
                                            The monitor is HP 27es LED Monitor
                                            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                            The monitor will randomly blackout and display no signal and will recover again.
                                            Sometimes need to power and off again to restore the display but...
                                            03-20-2025, 07:30 PM
                                            Wise Wing F199 19'' LCD monitor - recapped
                                            by momaka
                                            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                            When I saw the Craigslist post, I wasn't...
                                            08-24-2020, 10:58 AM
                                          • sew333
                                            Pc shutdown, monitor flickered with no signal after 10 seconds
                                            by sew333
                                            My pc:
                                            10850K stock 4800mhz stock Kraken X73 good temps
                                            2x16 GB DDR4 GSKILL 3000mhz XMP
                                            Seasonic Tx-850 Ultra Titanium
                                            Gigabyte Rtx 3090 Gaming OC
                                            Aorus Z490 Pro Gaming
                                            1 TB SSD
                                            4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                            Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                            Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                            Power...
                                            02-22-2022, 10:27 AM
