Benq G2255 doesn't power on - amber power light when plugged in
  • rddube
    Aspiring Expert
    • Jun 2013
    • 954
    Re: Benq G2255 doesn't power on - amber power light when plugged in
    Ok, here is the first tests.
    Originally posted by Dumah Brazorf
    What measure pin 1 and 16 in this case?
    Dumah, you are going to see what I get on pin 1 and 16 in the photos.
    For Will:
    Lights come on nice and solid, no flickering no tint, just white light top and bottom.
    First I show you my setup, so you can admire
    Next are the photos for pin 1, then pin 2, 3 and 16 respectively. 1, 2 and 16 look smooth, but pin 3 is pretty spiky. I took 2 photos of pin 3 so you could see the amplitude, especially on photo 2.
    So what next, do I next, do I flip the board and do the tests, or is there something wrong with pin 3?
    Tks a million!
    • Dumah Brazorf
      • Jun 2013
      • 179
      • Italy
      #122
      Swap the lamps. If pin2 became spiky and pin3 smooth there's something wrong with a lamp.
      • rddube
        Aspiring Expert
        • Jun 2013
        • 954
        Ok Dumah, will do the tests this afternoon as I have to flip around and reinstall my alligator clip on C803 to short pin 5. Right now I have to go get my grand daughters to bring them to Toys'r us, order from my wife!
        Will probably wait for Will's advice too. Since pin 3 is current feedback for one of the lamps, could it not be a component on the line from the lamp to pin 3 that could be causing this? We'll know for sure once I do the test.
        Thanks for your advice.
        • rddube
          Aspiring Expert
          • Jun 2013
          • 954
          For Will:
          Tks a million!
          Sorry gentlement, while setting up to do the test with the CFL's plugged in the opposite sockets, I realized that the tests above were done on pins 2, 3, 4 and 16...not pin 1. So the photos are for pins 2, 3 and 4 instead of 1, 2, 3.
          I tried repeating the test this time with the CFL's the other way, this time on the right 1, 2, 3, pins, but for some reason my oscilloscope doesn't show me a stable sine wave, it jumps all over the screen - same thing for all 3 pins. There must be something I am doing wrong? The CFL's light up as before however. Will try again and see what gives. Sorry for the error in the previous post.
          • will62
            • Dec 2016
            • 229
            • usa
            #125
            Well, I posted some things to check next, before reading your comment above. I've edited all out except asking for a new pic. Hopefully you get some stable waves with lamps swapped. If not, go back to original setup and probe pin 1. I think that's all we're missing. Rename pics with correct pin #'s.
            Can you take a complete pic with light under the board, similar to the ones you put up earlier?
            • rddube
              Aspiring Expert
              • Jun 2013
              • 954
              Ok, found my problem with the waves jumping...this oscilloscope has alligator clips so the ground is fine, but the probing wand I had to make out of a copper wire (solid) and I was holding the wire instead of the plastic covering the alligator clip, creating disturbance I guess.
              Here are the real pins 1, 2, 3 and 16, with the CFL's connected as original. I noticed that I have a hold function on the oscilloscope so I used it to take the pictures, hope that's ok.
              Will get to redo pin 1 with other setup, will rename the photos and reupload everything including a photo of the whole board with light under, right after lunch.
              • rddube
                Aspiring Expert
                • Jun 2013
                • 954
                ok, redid all the tests CFL's inverted and CFL's in their original position and here are the photos of the scope.
                I noticed pin 16 was changing frequency quite a bit, so I took a little video (hope it's ok to post it here, if not I will remove it no problem - had to put it in a zip file because the extension is not allowed) to show the movement of the wave.
                • will62
                  • Dec 2016
                  • 229
                  • usa
                  #128
                  Good job on the pics and video. Those voltages (min,max,pp) are all over the place, and not following the lamps to different connections. The waves also don't look like what is expected based on the datasheet (pic on post#114). Note that the "LI" waves center on 0V and the "OV" waves center on 6V. Keep in mind that we don't have the datasheet for MP10091ES. I am looking at the datasheet for MP1009. I have seen specs that refer to the 10091 as being from the 1009 series, but we already know they have different pin-outs, and they probably also have different internal parameters.
                  I wonder if some of the wave changes are related to when they were measured. We know that the chip is seeing something that it doesn't like in the first couple of seconds. Just to be sure, Can you please redo the tests, but start each test from power being off. Try to press hold as quickly as possible on each test. No need to take new pics, just give me min, max & pp for each pin at startup. If pin 16 is doing what you show in the video, I don't doubt that it is causing the shutdown. There's a couple of ways to check that, and we'll try those next.
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 954
                    Ok, here are the readings for pins 1, 2, 4 and 16 (I also jotted down the frequency):
                    Frequency Min Max PP
                    Pin1: 59.19Khz -37.58V 5.23V 42.52V
                    Pin2: 71.49Khz -37.58V 6.64V 44.23V
                    Pin3: 71.036Khz -37.58V 7.85V 45.44V
                    Pin16: 71.78Khz -37.58V 3.22V 42.81V
                    Hope these make sense. I put power on and as quickly as possible pressed the hold button on the scope.
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 954
                      Will, this pinout seems to be the one of the MP10091ES, taken from a Philips service manual attached. The critical components for IC801 is an MP10091ES.
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 954
                        Ok, here is a photo of the whole board with lights shining under it.
                        • will62
                          • Dec 2016
                          • 229
                          • usa
                          #132
                          Yes, the diagram of the MP10091ES that I put the voltages on, came from a Philips SM, maybe the same one you attached above. Problem is that we don't have the datasheet for the chip. Parameters could be different, so waves on pins 16, 1, 2 & 3 could also look different.
                          This is going to be tedious, but I think that it is necessary to move forward. Let's lift 2 pins at a time, so we can narrow down the connector that the problem is coming from. But, when you lift a pin, the chip is not going to be happy with no input, so you'll have to use a jumper to "borrow" the input from the other pin. The OV1(p16) and LI1(p2) go to connector 801. The OV2 and LI2 go to connector 802. So, to start:
                          Lift pin 16, jumper from pin 1 to lifted pin 16.
                          Lift pin 2, jumper from pin 3 to lifted pin 2. (jumper can be solder bridge on 2&3)
                          Now you have voltage and current monitoring from connector 801 removed. Remove the pin 5 jumper and power up. Do lights come on? If not, resolder pins, and lift pins 1 and 3 (jumpers stay, and they need to go to lifted pin, not it's pad). Power up again, any change?
                          Thanks for the pic, really clears some things up.
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 954
                            Ok, Will, did the first test Lift Pin 16 jumper from pin 1 to lifted pin 16. Lift pin 2, jumper from pin 3 to lifted pin 2. Removed jumper on pin 5, put power and the lights come on and stay on.
                            I had the lights plugged the inverted way, as I wanted to have the power board upside down so as to not touch my jumpers. So the problem would be connector 801?
                            • will62
                              • Dec 2016
                              • 229
                              • usa
                              #134
                              Now try inverting the connectors. Light still come on? If not, we have a lamp or connector problem. If yes, we have a connector 801 circuit problem.
                              I think that it is an over voltage reading on pin 16. Resolder pin 2 and remove jumper between 2&3. Try powering up again. If lights come on, we don't have a current monitoring problem. We can focus on the components that are used to measure the voltages.
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 954
                                Inverting connectors, both lights come on and stay on.
                                I am trying to see how this relates to the connector 801 circuit...can you trace it on the photo for me to understand?
                                Tks Will, you are a genius!!
                                Will have to remove the board to do the second test (i.e. resolder pin 2 and remove jumper between 2&3 (I presume I leave the jumper on 1 and 16?). Will get back to you in a few minutes.
                                • will62
                                  • Dec 2016
                                  • 229
                                  • usa
                                  #136
                                  Yes, leave jumper on 16 & 1. Once we narrow it down, I'll try to explain what I think is happening.
                                  • rddube
                                    Aspiring Expert
                                    • Jun 2013
                                    • 954
                                    ok, with jumper 2 to 3 off, pin 2 soldered down, the lights turn on for a few seconds (2 seconds) and turn off.
                                    • will62
                                      • Dec 2016
                                      • 229
                                      • usa
                                      #138
                                      Well, that shot my over-voltage theory to heck. Now, we need to confirm if it is an over-current problem. You'll have to resolder pin 16 and remove 1-16 jumper. Re-lift pin 2 and replace 2-3 jumper. If light comes on now, we have a current problem. If not, we have a problem with a common component between voltage and current monitoring.
                                      • rddube
                                        Aspiring Expert
                                        • Jun 2013
                                        • 954
                                        The lights come on and stay on with the 2-3 jumper (pin 2 lifted) and the 1-16 removed and pin 16 resoldered. What do we have to check?
                                        • will62
                                          • Dec 2016
                                          • 229
                                          • usa
                                          #140
                                          OK, the chip is shutting down due to an over-current reading on the connector 801 circuit. I haven't had a chance to go over the updated under lighted pic yet. It may be sometime tomorrow before I have a chance to get back to you. In the mean time, cold solder joints are sometimes hard to see. You might start at transformer secondary pin 7 and resolder every through-hole component from there down to and around cn801 (including cn801).
                                          We know where the problem is now, so you can resolder pins and remove jumpers.
                                          • huzo
                                            HP 470 G5 blinking amber light no power
                                            by huzo
                                            The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                            So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                            I've tried flashing the bios...
                                            interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                            06-08-2023, 04:08 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • lapfix
                                            HP OMEN NO power no light
                                            by lapfix
                                            HP OMEN : DAG35DMBAD0
                                            NO power ,no short ,no corrusion
                                            Consumption : when charger plg in = 0.004 amp
                                            Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                                            when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                                            No light at power button led
                                            All coils resistances :
                                            Pl 2001 =3v measured with kohm.
                                            pl 2004 = 5v measured with kohm
                                            pl 6001 = 49.7ohm
                                            pl 4012 = vccsa = 24.4 ohm
                                            pl 3001 =...
                                            Today, 07:48 AM
                                          • zwect
                                            Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
                                            by zwect
                                            I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
                                            Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
                                            Here is the original BIOS dump from the 25R256JVEN chip.
                                            09-11-2024, 05:54 PM
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
