Mag LT916s Model 900p 19" LCD dropping like flies
+ More Options
Posts
  • Nama
    • May 2009
    • 127
    #81
    Re: Mag LT916s Model 900p 19" LCD dropping like flies
    Yes is was a Small bit of solder You are spot on thank you.
    ^Learning to walk on rice paper without leaving a trace,
    • PlainBill
      • Feb 2009
      • 7034
      I have a lighted magnifier I use to examine all solder work for errors. It tends to reduce embarrassing mistakes that would otherwise prove to be damaging.
      PlainBill
      • chronJob
        • Jun 2009
        • 8
        #83
        My screen comes on bright for 2 seconds just like everyone else, so I doubt it is my CCFL's but all my caps look perfectly fine. they are the crap ones so i guess iwill replace them anyway, im headed to the 'shack now. can someone please verify that the transistor on the bottom input IC board #13 which has 3 pins only the two outer pins are soldered to the board the middle one is cut, but the soldering job on the IC undernieth it does look like it was from the factory and done by a machine so this is probably suppose to be like this. part 1084-18ce 493c3
        I have heard my caps could be bad even though they are not bulging and oozing... going up in voltage from 25v to 35v on the 470 µf caps is a bonus right? even if "going-out" CCFL's were pulling too much power?
        • EGuevarae
          • Nov 2008
          • 1336
          Welcome to Badcaps.net.
          Don't go to the Shack to buy caps. They are not suitable for this kind of applications. Also, the chip you are describing with just two pins soldered, must have the back of the IC (kind of heatsink) soldered. That is the same as the middle pin. A pic would help you to get the help you need more often than not.
          • ASUS ROG Maximus IX Code
          • Intel Core i5-7600K 3.8GHz
          • Windows 10 Pro x64
          • GeForce GT1050
          • chronJob
            • Jun 2009
            • 8
            #85
            will these caps I got from radio shack at least get me up and running to make sure this is the problem. I am impatient, lol. any other type of store that would sell caps locally in a metropolitan area? I live in kansas city. picture is coming, let me get some more lighting and ill take one with my phone. thanx for the quick reply
            • EGuevarae
              • Nov 2008
              • 1336
              I guess as a test material, they MAY BE used. If the specs differ a lot from the originals, I can't tell if they will last or if the unit will work as intented, but as a test to see if only the caps are your problem, I guess you can use them. As for parts, order from Digikey.com if you post the info on your caps, in no time someone will tell you what replacement parts you should buy.
              • GeForce GT1050
              • chronJob
                • Jun 2009
                • 8
                #87
                My caps look ok...?
                this looks odd though, but looks almost factory... ?
                • chronJob
                  • Jun 2009
                  • 8
                  #88
                  BTW the radio shack brand are XICON the match the 470uf rating, and are 35v instead of 25v. it doesnt give a temperature rating but says ±20%
                  • chronJob
                    • Jun 2009
                    • 8
                    #89
                    temprature rating says up to 85º C on the package, guess i should install a CPU fan on the back too. does tolerance have anything to do with its ESR rating?
                    • chronJob
                      • Jun 2009
                      • 8
                      #90
                      I just noticed one other thing on the inverter board, in the center, grounded to the heat sync looks like a transistor, (3 prongs at the bottom) when i flip the board over the 3 connections look a little tarnished and not shiny like all of the other IC connections. ???I can post a pic of that too if you want?
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        My caps look ok...?
                        Yes but they can go without visual indication
                        It is OK. Center pin & back of IC are the same. If you look up teh datasheet for the IC using the numbers on it you will see what I mean.
                        • GeForce GT1050
                        • chronJob
                          • Jun 2009
                          • 8
                          #92
                          these are the pics to the trnasistor... (i think the flat black thing with 3 progs at bottom,) on back of board the solder points are discolored where as all other are shiny
                          http://jason.dominatesthe.net/img/a1.jpg
                          http://jason.dominatesthe.net/img/a2.jpg
                          • chronJob
                            • Jun 2009
                            • 8
                            #93
                            Great News!!!! It works!!!
                            None of my caps showed sign of excesive heat, bulging or oozing...
                            First I replaced the 6 470uF Fuhjyuu 25v caps with the radio shack Xicon 470uF 35v caps. And still only powered on for 2 seconds. So then I proceeded to replace the other Fuhjyuu caps (the 2 x 100uF and the 220uF) with 3 more Xicons, and now it runs perfectly. Thanks so much for the help, I had bought this monitor on craigs list with out testing it first and spent $50, im glad it wasn't a total loss, I ended up spending another $20 on caps and a soldering iron but it was worth it.
                            • EGuevarae
                              • Nov 2008
                              • 1336
                              Those might be C10 & C11. They are on the inverter side.
                              Keep in mind that while your caps work they might not endure a long time because they are not the specs they should be. if it ever fails again, now you know what part(s) to blame.
                              Also, Fuhjyuu caps are a change-on-sight part in that applications.
                              It was fun and very didactic, and the feeling to bring back from the dead something is great, right?
                              "cheers:
                              • GeForce GT1050
                              • created2praise
                                • Jun 2009
                                • 4
                                #95
                                hi folks,
                                I am just a newbie here.
                                Nice to find a forum like this since I have a MAG LCD.
                                Same problems, backlight ON for few minutes then blank.
                                Since browsing this page tells CAP issues, I replaced all but one 100uF 400V.
                                I checked and it run good for 5 hours. Now, After a day.. symptoms were the same again. Think I need also to replace the 100uF 400V cap. Hope it solves the issue.
                                Be happy if you have better suggestions and explanation why the thing happened.
                                Best regards to all!!
                                • EGuevarae
                                  • Nov 2008
                                  • 1336
                                  Originally posted by created2praise
                                  hi folks,
                                  Unless the unit has been on a power surge situation, it rarely fails (regarding the 400v cap). What did you use as replacements?
                                  • GeForce GT1050
                                  • created2praise
                                    • Jun 2009
                                    • 4
                                    #97
                                    Thanks for the response. I have used Robicon Caps as replacement which I bought at a local electronic shop. What do you mean power surge? Old 100uF 400V was of Xunda caps which I red was of bad quality.
                                    • EGuevarae
                                      • Nov 2008
                                      • 1336
                                      Hope Robicon is Rubycon spelled incorrectly and not an actual brand.You forgot to give the series also.
                                      Power surge? like an electric storm... lights out, then back, and monitor is dead. You didn't say that, so I assume your unit is not in that case ...
                                      • GeForce GT1050
                                      • created2praise
                                        • Jun 2009
                                        • 4
                                        #99
                                        I'm not quite sure regarding the brand of CAP Robicon if its from Rubycon. It is not because of power surge. First symptom was the "2 seconds problem" that is why I chose to replace CAPS. Is it worth replacing the 400V? or is there any sorce of the problem that I need to check?
                                        • EGuevarae
                                          • Nov 2008
                                          • 1336
                                          Leave that big boy alone. POst a pic of both sides of your board to see if something is suspicious ....
                                          • GeForce GT1050
                                          • x_orange90_x
                                            by x_orange90_x
                                            01-29-2025, 09:24 PM
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
