Problems with Samsung 740N monitors
Re: Problems with Samsung 740N monitors
i think this is the best i can do...'till all are one. -
They are good compared to some we get to see (or not see)
If you have still got it in bits I have had another look at the PS base and the soldering on one of the diodes D107 looks a bit brown at one end. The board also looks a bit browner in that area so perhaps you can reflow all 4 diodes. Also one of the caps you have replaced the lower one in the picture has a bit of solder between the legs - can you clean it off and also the right leg in the picture the solder doesnt look just right if you can check it ( May just be shadow )Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
OK 4525GEH is a mosfet- data sheet is attached.
In the 2 seconds to black guide there is a test for mosfets.
Ohms test so doesnt need to be connected or swithced on.Attached FilesPlease upload pictures using attachment function when ask for help on the repair
the whole area around those diodes is yellowish...like some glue or some lacker (dunno the word for it) spilled or smthn. will clean it up tomorrow and resolder the diodes just in case. it doesnt look like it burnt, but rather it heated up pretty well, so something leaked.
about the solder between the legs, its not a solder but a thin scratch line where my screwdriver slipped :P don't ask its clean no touching between the contacts.
its not a shadow but a rather stupid light play. that pin is somewhat blueish from my tweezers that i used to shorten the contact from the capacitor. and its giving the impression of a loose contact...
will take another pic in the morning at work, when its all done
ty for the great help mate'till all are one.Comment
OK You replaced two caps - if they were leaking it could be electrolyte stain. While on the subject - Why did you change the two caps - bulged /leaking or what.
I suppose I am asking why didnt you change the other biggish cap next to them and also
do you have a source where you can you get the other caps ( But not The BIG Cap) on that board to replace if neccessary. I have been following another thread where member is in Serbia and it seems a bit of a problem. Speak again tomorrow.Please upload pictures using attachment function when ask for help on the repair
both were bulged, and one was leaking, well... yeah, leaking...
i can get all the capacitors i need, the firm has them :P, and a local tv shop can get me anything i mostly need. i didnt change the other caps as they looked ok, but i can test them if u like on the cap meter at work.
on the first note, im not getting ANY reading of the AP4525GEH. nothing on any combination of pins.On taking a very close look, it looks like it was heated too much and died. i will check that too under a magnifier tomorrow.
ty again.
till tomorrow
md'till all are one.Comment
Well,we have a part to blame... the ap4525 mosfet died.
I have resoldered the diodes and checked all caps on the capmeter.just in case.
Will try to find it here localy,if not gotta order it.
Will write when i solder the new one.
Ty for the great help
Md'till all are one.Comment
If you cant find one there are alternatives - see here
http://www.edaboard.com/thread253214.html
There are probably others as wellPlease upload pictures using attachment function when ask for help on the repair
well...it works. kinda.
After changing the MOS, it started normal, and worked for 1h, than just went black. On&Off and its working again. While typing this it did it two more times.
(the signal on the button stays blue and ON, like it has signal and everything, but the display is black... its def not a lamp as there is no picture in background)
Its producing a strange little squeeek noise, like something is shortcircuted or smthn..cant describe. but only at startup...'till all are one.Comment
Good so far then. Sounds like bad joints
Did you resolder the diodes? next would be to go over the board with
a magnifying glass and look for possible bad joints and resolder them. Especially on the transformers - probably do them anyway.
Try wriggling components and looking for movement on the underside of the board.
See of you can pinpoint where the sound comes from I know you say you tested the caps but it could still be one that is on its way out.Please upload pictures using attachment function when ask for help on the repair
the 3x 820uF gave 821, 803, and 828uF...the others were around the same as stated capacity.
i will look for loose contacts tomorrow at work with a mag glass, and resolder everything i see....
i did the diodes earlier, but will do it once more...
ty for pinpoints, will check it all out'till all are one.Comment
Ok if you dont find anything or it doesnt fix it I would consider replacing all the caps.
If two had gone as far as bursting, others of same make and series will not be far behind.Please upload pictures using attachment function when ask for help on the repair
probs are, these two are the only of the kind, and the rest are diff
well, we shall see tomorrow,if nothing, i'll change em all'till all are one.Comment
I replaced 3 caps 820u by 2x1000u + 1x470u and 3A pico fuse by a small copper wire (I cannot found it in my location). My monitor don't working. Power led on but it off every 3 second, the panel flash after power led off (off time about 0.5 second). I check the board but it in good condition (I think may be 4502C burned but it look good). The voltage on 13V pin oscilated from 14.5-18.3V, in on/off pin about 0.3-2.5V. Oscilating same with power led ligh time. No picture on display. I remove fuse (copper wire) and check again. The power led don't flash, on/off pin about 2.5V but 13V pin is 18.3V. The picture shown on display, (no back ligh of course). What is this problem here? May the 4502C burned?Comment
Hi - please update your profile with country and mains voltage.
It could be that BOTH 4502c need replacing or it could be a cold joint somewhere.
Any sort of fuse with the correct rating would be better than wire - if you have read this thread you will see others have caused more damage doing that.
There is also someone who had the same 18.x voltage problem.
We can help a lot more if you please post good clear pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
https://www.badcaps.net/forum/attach...1&d=1290283049
https://www.badcaps.net/forum/attach...7&d=1280167246Please upload pictures using attachment function when ask for help on the repair
Pico Fuse - On the 740N- Some boards have one some dont- some do but its covered in glue.Please upload pictures using attachment function when ask for help on the repair
Hi - is the Dark brown area on the bottom or the board where you have replaced caps?
Is the brown burnt or is it just flux?
If it is flux can you clean it off with something like an old toothbrush and some
isopropyl alcohol so we can see the traces.Please upload pictures using attachment function when ask for help on the repair
Was going to ask you to check inverters but just spotted you already did.
It may be a faulty backlight or wiring ,do you have any spare CCFL bulbs.
Did you read this:https://www.badcaps.net/forum/showthread.php?t=10419
start at post 19Last edited by selldoor; 07-23-2012, 04:29 AM.Please upload pictures using attachment function when ask for help on the repair
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by vincentedelHello,
I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some timeβlike after playing a gameβthe text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...-
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
- Loading...
